Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
132 (62.9%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
30 (14.3%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
48 (22.9%)
Total Members Voted: 210
Author Topic: [Update] 2016-04-26 - Cinnamon 3.0, Pamac, Gnome 3.20, KDE, Virtualbox  (Read 28217 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
We are happy to announce our seventeenth update of Manjaro 15.12 (Capella)!
With this we updated Gnome and GTK to 3.20. This will break most of the themes, which will be fixed if and when their developers decide to update them. Some GTK 3.20-compliant themes are ready now - see further down this post.
It is recommended to use Adwaita or any theme which is already compatible with the new CSS style of Gnome. Most of the work is now going into our new default theme, Vertex-Maia.
So what changed so far:
 - some of our kernels got a new point-release
 - updated JDK8, Virtualbox and profile settings of our Manjaro editions
 - plasma framework is now at 5.21
 - plasma desktop is now at 5.6.3
 - KDE apps at 16.04
 - haskell and python updates
 - a lot of rebuilds due the gtk3 update
 - libreoffice is now at 5.1.2
 - firefox, thunderbird and calligra got updated
 - continues work on vulkan support
 - some updates to lib32 repository
Guillaume and Dustin worked together to get Gnome headerbar working with pamac. This gives pamac a new look and feel. Also additional improvements got added to our latest preview version of pamac. Install it via pamac-dev.
Archlinux upstream fixes are now from: Tue Apr 26 19:46:47 CEST 2016.
It is always good to check for updated packages, even we don't notify you about them. As usual people using our testing branch will help us to get snaps over to our stable branch almost smoothly. For notifications on daily bases please take a look at our mailing list:
https://lists.manjaro.org/pipermail/manjaro-packages/
Kind regards,
Philip Müller and the Manjaro Development Team
:: Current supported kernels
 - Linux310 3.10.101
 - Linux312 3.12.58
 - Linux313 3.13.11.39 [EOL]
 - Linux314 3.14.66
 - Linux316 3.16.7.27 [EOL]
 - Linux318 3.18.32
 - Linux319 3.19.8.19
 - Linux41  4.1.23
 - Linux42  4.2.8.8
 - Linux44  4.4.8
 - Linux45  4.5.2
 - Linux46  4.6-rc4
:: Package changes
 - stable community i686:  770 new and 751 removed package(s)
 - stable community x86_64:  770 new and 749 removed package(s)
 - stable core i686:  54 new and 54 removed package(s)
 - stable core x86_64:  54 new and 54 removed package(s)
 - stable extra i686:  1305 new and 1275 removed package(s)
 - stable extra x86_64:  1305 new and 1276 removed package(s)
 - stable multilib x86_64:  56 new and 55 removed package(s)
The new default Manjaro GTK theme, which is GTK 3.20 compatible, is Vertex-Maia
You can install it with:
Code: [Select]
sudo pacman -Sy vertex-maia-themes vertex-maia-icon-theme xcursor-maia
Then select it in your environment's appearance/theme settings area.
Troubleshoots
ufw
If you have issues with ufw not working anymore, you have to copy your custom rules to a different folder. Do it like this:
Code: [Select]
sudo cp -v /usr/lib/ufw/user.rules.pacsave /etc/ufw/user.rules
sudo cp -v /usr/lib/ufw/user6.rules.pacsave /etc/ufw/user6.rules
steam
Steam might not work due incompatiblity of libgpg. You my try followed command to "fix" it:
Code: [Select]
find ~/.steam/root/ -name "libgpg-error.so*" -print -delete
« Last Edit: 03. May 2016, 16:01:11 by Rob »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
Manjaro 16.06-pre3 will be based on this update-set.
Offline Airblader
  • Jr. Mitglied
  • I'm new. Be nice!
  • Desktop: i3-gaps
  • Skill: Advanced
The installation went through fine with ~200 packages. Here's the minor issues I encountered:
  • rofi changed its configuration syntax and hence the theme will be broken. Just look it up on the man page / website.
  • I use termite and used the CSS selector VteTerminal to set padding. With the VTE update, the selector is now vte-terminal.
Will update the list as I go along. Thanks for your work!
Offline Mozon
  • Support Team
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: HD 4600
  • GPU driver: free
  • Kernel: 4.6
  • Skill: Advanced
Update works fine butt there seems to be somthing wrong.
Left upper corner , no space betwenn Search, Goup, Status ect.
Is it a Problem of the font ?
I get the same issue on other system based windows .
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
@Mozon: pamac uses gtk3. Your theme doesn't support version 3.20. Please use another one which supports it.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
No issue here, also not with my theme (mediterranean).
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Bankman
  • Neuling
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: Nvidia GeForce GT755M
  • GPU driver: free
  • Kernel: Linux 4.5
  • Skill: Novice
Smooth update without problems  :)
Offline Mozon
  • Support Team
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: HD 4600
  • GPU driver: free
  • Kernel: 4.6
  • Skill: Advanced
@phlim ... thanks     so simple .... doesnt see the three in the forest ... sorry my fault.
Offline KabirGandhiok
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Gnome / Xfce
  • GPU driver: Free
  • Kernel: 41 / 44
  • Skill: Novice
Hi,
I'm unable to update. I got the updates notification on pamac and after hitting apply, I got some archlinux key error, so I canceled the updates and ran -
Code: [Select]
sudo pacman -Syy
sudo pacman -S manjaro-keyring archlinux-keyring
sudo pacman -Suu
sudo pacman -Syyu
but the updates had vanished and I got the "there is nothing to do message", so I ran pacman-mirrors -g but still no updates. Can anyone help me with this?
There are no logs of the error in pamac or pacman log, and I don't know where else I could look if you need to see what the error was exactly.
Thanks with this!
Offline lukstux
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: XFCE4
  • GPU Card: Intel Graphics 4000
  • GPU driver: OpenSource
  • Kernel: linux44-x64 LLTS
  • Skill: Novice
Can anyone tell me about the menda-theme, is it working fine after the update?
Thanks!
Offline Mozon
  • Support Team
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: HD 4600
  • GPU driver: free
  • Kernel: 4.6
  • Skill: Advanced
My Theme not longer work ..... and I found nothing silmilar.  :-[
any sugestions ?
Offline notfound
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Gnome
  • GPU Card: ATI
  • Skill: Novice
On Manjaro Gnome here. Every single update has disabled Steam. But this time, the "purge libraries" button didn't work. How can I get it to open? It's the same libGL errors as last time:
$ steam
Running Steam on manjarolinux 15.12 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(1459463254)
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
Offline wordler
  • Vollwertiges Mitglied
  • I can wire a plug
  • Branch: Stable
  • Desktop: Fluxbox & Xfce
  • GPU Card: Nvidia GT720 1gb ddr5
  • Kernel: linux4.4-x64
  • Skill: Novice
Wow! HUGE update  :o . Apart from needing to change theme, as mentioned, everything is working fine. Watching the terminal was like watching a movie! 196 upgraded packages, great job Manjaro Team, many thanks for all the work  ;D
Fear is the mind killer.
Offline cim
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: OpenRC XFCE
  • Skill: Novice
The GTK3 update (to 3.20) broke the default Numix-Manjaro XFCE theme for me, similar I assume to what others are reporting. Pcmanfm was a real mess. Downgrading GTK3 to 3.18.9-1 (which is what I had before the upgrade) and rebooting fixed the theme and the many affected applications displayed properly again.
The only problem I noticed with the GTK3 downgrade is that all the pamac package managing applications would immediately crash (with a libvte error). So I downgraded the vte3 and vte-common packages to version 0.42.5-1 (which is what they were before the upgrade) and that seemed to solve the problem. Pamac updater and package manager start fine now.
Edit: gtkmm3 also had to be downgraded for pavucontrol.
I'll wait to upgrade GTK3 until I see the new theme packages ready for upgrade as well.
« Last Edit: 27. April 2016, 03:52:45 by cim »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
Thanks!
Please read this and switch to vertex-maia. Thx.
