Author Topic: Which green do you want to see as Manjaro's face and its theme and icon sets?  (Read 2591 times)
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
Lighter greens are no good because you can't easily read white text on them.
...and before anyone says "just make the text black!" be sure you've forked our packages-community repo, modified our theme PKGBUILD's with changes to make selection text black, and submitted a pull request. :P
Offline Heart Of A Lion
  • Sr. Mitglied
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce, Enlightenment
  • GPU Card: ATi 7770 . . . . . . . CPU: AMD octacore 4GHz
  • GPU driver: Free (video-ATI)
  • Kernel: 4.6 (x64)
  • Skill: Intermediate
That's beautiful! 8)
btw. Are the shadows around your panels intentional? You do know that it is possible to remove them - I'm wondering if that would be even better, but I think it looks really great the way it is, too!
The shadows aren't intentional, however I do like the shadow under the vertical panel on the left side. I'd prefer to remove the shadow on the bottom panel for an even cleaner look.
I don't know how to remove the shadow though.
Does anyone know?
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
if you use compton for compositing, it's possible to shadow-exclude specific objects by using their x-properties, usually name or class. Name is better than class.
To know x-property of an object run 'xprop' in terminal and click on it. If the object steals focus, like xfce logout dialogue, oblogout then use 'sleep 5s && xprop' instead and launch that object within those 5 seconds, get ready to click. As soon as you click huge list of x-properties are printed in your terminal, find WM_NAME or WM_CLASS. Refer to compton manpage (run 'man compton') to see the syntax for shadow-exclude. Here's my config
Code: [Select]
shadow-exclude = [
"name = 'Notification'",
"WM_CLASS@:s = 'conky'",
"class_g ?= 'Notify-osd'",
"class_g = 'Cairo-dock'",
"class_g = 'Docky'",
"_GTK_FRAME_EXTENTS@:c",
"_NET_WM_STATE@:a = '_NET_WM_STATE_MAXIMIZED_HORZ'",
"_NET_WM_STATE@:a = '_NET_WM_STATE_MAXIMIZED_VERT'",
"WM_NAME@:s = 'xfce4-session'",
"name = 'Whisker Menu'",
"WM_NAME@:s = 'plank'",
"WM_CLASS@:s = 'VirtualBox'",
# "WM_NAME@:s = 'Top Expanded Edge Panel'",
# "WM_NAME@:s = 'Bottom Expanded Edge Panel'",
# "WM_NAME@:s = 'xfce4-panel'",
"WM_NAME@:s = 'Openbox Logout'",
"WM_NAME@:s = 'tint2'"
You can;t grab whiskermenu using xprop, ^ i got it working with trial and error :P
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
In Xfce you can simply switch off "shadow under dock windows" in xfce compositor. ;) Then of course, both panels will be shadow-less!
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
Wellp. At least my profile pic suits me  ::)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Personally, I use #557B14 :  , but with a dark background.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
My eyes like the dark jades best.
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline mgundogdu
  • Vollwertiges Mitglied
  • Learn and share and be nice with that!
  • Branch: Unstable
  • Desktop: Xfce
  • GPU Card: AMD/ATI RV710/M92
  • GPU driver: ATİ
  • Kernel: linux44-x64
  • Skill: Novice
I have confession  ;D
This fifth day with unstable and new theme I m getting like new color :D First impression make me a little irritate but using awhile it becomes more and more beautiful :D
I like metallic black like windows bars and corners
Buttons very good and original
and Maia icon set and color perfect fit with theme
Thanks a lot. Good job :D
« Last Edit: 26. April 2016, 18:17:26 by mgundogdu »
Open knowledge is what open data becomes when it’s useful, usable and used.
https://okfn.org/opendata/
