Author Topic: changing lock screen background  (Read 6533 times)
Offline Windowsfree
  • Vollwertiges Mitglied
  • Using Manjaro Gnome 3.20
    • D&B Computer Repair
  • Branch: Stable
  • Desktop: GNOME
  • GPU Card: Nvidia GT330M
  • GPU driver: free
  • Kernel: 4.4.6-1 LTS
  • Skill: Novice
« on: 24. April 2016, 16:02:01 »
Hello,
How can I change the lock screen background to an image other than what comes installed?
Thanks!
~Bob
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: changing lock screen background
« Reply #1 on: 24. April 2016, 16:31:08 »
depends on which locker you are using. You can set wallpaper for Gnome's gdm lock-screen within the control center > backgrounds
If you are using some other locker, do tell. Our help is as good as your information is.
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline Windowsfree
  • Branch: Stable
  • Desktop: GNOME
  • GPU driver: free
  • Skill: Novice
« Reply #2 on: 24. April 2016, 16:45:06 »
I'm using Gnome's gdm lock-screen, I don't see anywhere to search for other backgrounds from the control center> backgrounds.
~Bob
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #3 on: 24. April 2016, 17:03:41 »
copy wallpapers to /usr/share/backgrounds/gnome
Offline Windowsfree
  • Branch: Stable
  • Desktop: GNOME
  • GPU driver: free
  • Skill: Novice
« Reply #4 on: 24. April 2016, 18:13:41 »
I did that - but when i go to control panel to change backgrounds, they are not seen for the lock screen.   I can change the desktop without issue.
~Bob
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #5 on: 24. April 2016, 18:17:08 »
Use gnome-tweak-tools then, it should have
Offline stevelorenz
  • Neuling
  • Übung macht Meister!
    • my cookbook
  • Branch: stable
  • Desktop: Gnome 3.18.2
  • GPU Card: Intel Corporation Haswell-ULT Integrated Graphics
  • GPU driver: free
  • Kernel: linux44-x64
« Reply #6 on: 24. April 2016, 21:16:29 »
If you want to choose your pictures in settings, the picture should be put into the "XDG_PICTURE_DIR", there is a config file for this path placed in ~/.config/user-dirs.dirs. for example i use XDG_PICTURES_DIR="$HOME/photo", then the pics in this dir can be choosed as wallpaper  ;D
« Last Edit: 24. April 2016, 21:18:25 by stevelorenz »
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #7 on: 24. April 2016, 22:04:55 »
He should already have that by default. @Windowsfree can you show us a screenshot of your settings window - the one where you choose lock-screen wallpaper.
Offline Windowsfree
  • Branch: Stable
  • Desktop: GNOME
  • GPU driver: free
  • Skill: Novice
« Reply #8 on: 25. April 2016, 13:13:02 »
Ok, thanks for the input.  I will attempt to get a screenshot later today and post it.  I used the tweak tool to change it, just seems like it would be more user friendly (at least to me) to be able to change it on the change wallpaper screen.
Thank you again, I will probably post that much later today.
~Bob
Offline anika200
  • Sr. Mitglied
  • Branch: stable
  • Desktop: Gnome 3.20-x on PC, Antergos on laptop and another PC.
  • GPU Card: NVIDIA 750Ti, Intel Iris 5200, AMD
  • GPU driver: NV, AMD uses proprietary and the intel is free
  • Kernel: 4.4.8-1-MANJARO
« Reply #9 on: 25. April 2016, 20:11:15 »
If I right click on an empty area of the desktop I am presented with a menu of which one item is "Change Background", it is here where you can change wallpaper and lock screen settings.
If you are referring to the dark grey login screen, then there is no easy way to change that screen.
So yes, a right then left click is much easier then what you are doing now.  ;)
Offline Windowsfree
  • Branch: Stable
  • Desktop: GNOME
  • GPU driver: free
  • Skill: Novice
« Reply #10 on: 25. April 2016, 20:22:09 »
I am referring to the screen you get when you do your method.  The lock screen only shows a limited number of backgrounds.   I believe it would be great if you could search for other images to use from that screen.  This way you can preview the image also.  I can change it from the Tweak Tool but even after loading several images in the /usr/share/backgrounds/gnome, I don't see them on the screen to change wallpaper or lock screen images.
~Bob
Offline anika200
  • Sr. Mitglied
  • Branch: stable
« Reply #11 on: 25. April 2016, 20:55:05 »
If you click on Lock Screen you should get a window and at the top you see the word "Pictures", you can click on it and you should be presented with all the loose jpg, png files in the pictures folder as in the following http://paste.opensuse.org/view/raw/77707135 screen shot.
The images in the screen shot can be selected for the lock screen or wallpaper but they have to be in the ~/Pictures folder and not any other folder. If this is not the case for you then you should check on what stevelorenz has pointed out.
sheeze, this took forever to post because the attachment can only be 1024.
« Last Edit: 25. April 2016, 20:57:38 by anika200 »
Offline Windowsfree
  • Branch: Stable
  • Desktop: GNOME
  • GPU driver: free
  • Skill: Novice
« Reply #12 on: 25. April 2016, 22:38:56 »
I really appreciate the effort. That way will work.  I had my wallpapers inside a folder in the Pictures directory and I could not choose from there.  It seems the files have to be in the Pictures directory.
I wonder if this is something the developers could work on.
Thank you again.
~Bob
Offline anika200
  • Sr. Mitglied
  • Branch: stable
« Reply #13 on: 26. April 2016, 01:55:41 »
I hope so, I have been wondering about it now for some time though. It seems like a fairly attainable goal in my humble opinion, you know, low hanging fruit.  :)
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #14 on: 26. April 2016, 02:46:25 »
Nope. It's Gnome, aint gonna happen. Mark this topic as solved :D :D
