Author Topic: Drag and drop from xarchiver doesn't work, calendar GUI invisible  (Read 793 times)
Offline arunj
  • Neuling
  • I'm new. Be nice!
  • Skill: Intermediate
I recently switched to Manjaro LXQt 2016.03 from Lubuntu. My system is up-to-date. Facing 2 problems:
1. I noticed that PCManFM-qt shows a menu when files are dragged for moving. However, drag and drop from xarchiver (or file-roller/engrampa) doesn't work. Is this a known issue?
2. My calendar dates are almost invisible irrespective of the theme I use. This is how it looks:
Any help is much appreciate. Many thanks in advance!
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: Drag and drop from xarchiver doesn't work, calendar GUI invisible
« Reply #1 on: 24. April 2016, 15:24:20 »
Hi arunj,  :)
1) yes, some drag-and-drop problems. To see in the next 0.11 if they are solved, devs work also on that
2) it's not my last ISO (16.04). RIght click on the panel, configure panel, and uncheck (custom styling) font color. I did a bug report about that, imho calendar and panel font color must be separate.
« Last Edit: 24. April 2016, 15:27:16 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #2 on: 24. April 2016, 16:09:30 »
i never used xarchiver with drag and drop.
i chose xarchiver-gtk2 as my derfault archive manager. then, i could right click on any archived file and choose "extract here" or "extract to folder...". this works very well.
this might not be a perfect solution for you, but a workaround.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #3 on: 24. April 2016, 18:42:20 »
It's also xarchiver-gtk2.
Offline arunj
  • Neuling
  • I'm new. Be nice!
« Reply #4 on: 25. April 2016, 10:34:00 »
Thanks for clarifying @Esclapion!
