Author Topic: New Stable NVIDIA 364.19 With VULKAN API!  (Read 1224 times)
Offline wolfyrion
  • Sr. Mitglied
  • Branch: UNSTABLE
  • Desktop: PLASMA/KDE
  • GPU Card: ZOTAC AMP EXTREME EDITION 980
  • GPU driver: NON-FREE
  • Kernel: LATEST
  • Skill: Intermediate
« on: 22. April 2016, 19:36:27 »
New Official Stable driver with Vulkan API and lots of fixes!  ;D
http://www.nvidia.co.uk/download/driverResults.aspx/101848/en-uk
    Added support for the following GPUs:
        Quadro M6000 24GB
        Quadro M5500
    Fixed some locking issues in libnvidia-egl-wayland.so.
    Fixed several libnvidia-egl-wayland.so interaction problems with buffer management Wayland protocols.
    Fixed several EGL driver interaction problems with resizing windows in Wayland.
    Fixed a bug that caused some DRM PRIME configurations to fail when DRM KMS was enabled (i.e., nvidia-drm.ko's modeset kernel module parameter was set to "1").
    Fixed a bug that could cause a kernel crash when VDPAU was used while DRM KMS was enabled.
    Changed the default OpenGL installation type to use the GLVND GLX client libraries rather than the legacy non-GLVND libraries.
    Added initial support for Direct Rendering Manager Kernel Modesetting (DRM KMS).See the DRM KMS section of the README for details.
    Added a new kernel module, nvidia-drm.ko, which registers as a DRM driver with both PRIME and DRM KMS support.
    Added support for the following EGL extensions:
    EGL_EXT_platform_wayland
    to enable Wayland applications to run on NVIDIA's EGL implementation,
    EGL_WL_bind_wayland_display
    to enable Wayland compositors to run on NVIDIA's EGL implementation, and
    EGL_EXT_device_drm
    EGL_EXT_output_drm
    EGL_EXT_stream_consumer_egloutput
    to enable Mir and Wayland compositors to display their content through EGLDevice, EGLOutput, and EGLstreams.
    Added a Wayland platform library, libnvidia-egl-wayland.so, to allow Wayland compositors that support EGLDevice, EGLOutput, and EGLstreams to share EGL buffers with Wayland applications.
    Fixed a bug that could cause incorrect frame rate reporting on Quadro Sync configurations with multiple GPUs.
    Added support for the Vulkan API version 1.0.
    Improved X colormap precision from 8 significant bits to 11 on GeForce GPUs.Quadro GPUs already used 11 bits of precision.
    Added a new RandR property, CscMatrix, which specifies a 3x4 color-space conversion matrix.The matrix is applied after the X colormap and before the gamma ramp.This property is available on GF119 and newer GPUs.
    Improved handling of the X gamma ramp on GF119 and newer GPUs.On these GPUs, the RandR gamma ramp is always 1024 entries and now applies to the cursor and VDPAU or workstation overlays in addition to the X root window.
    Reworked how the NVIDIA driver registers with the Linux kernel's DRM subsystem for PRIME support.As a result, PRIME support requires Linux kernel version 3.13 or newer (previously, PRIME support required Linux kernel version 3.10 or newer).
    Improved the interactivity of applications that use a hardware cursor while G-SYNC is active.
Offline Mortem Bonum
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: NVIDIA GeForce GTX 960
  • GPU driver: Non-Free
  • Kernel: Linux-4.5
Re: New Stable NVIDIA 364.19 With VULKAN API!
« Reply #1 on: 22. April 2016, 20:20:02 »
I say if you really want the driver to be updated to this version I recommend installing another Arch based distribution ATM wolferyion (quite easy to do if you have home installed at a different partition) and testing it out there via the nvidia-beta AUR package for any bugs.If there is none or if it is relatively minor I suggest commenting on this github page:https://github.com/manjaro/packages-extra/issues/70 so the devs could see the feedback and possibly decide on whether to update it.
« Last Edit: 22. April 2016, 20:29:25 by Mortem Bonum »
Offline wolfyrion
  • Sr. Mitglied
  • Branch: UNSTABLE
  • Kernel: LATEST
« Reply #2 on: 22. April 2016, 21:00:00 »
Thanks didint know that, I posted there as well :)
Offline eduardo
  • Sr. Mitglied
  • Branch: testing
  • Desktop: KDE plasma 5
  • GPU Card: Intel HDGraphics 4400 / Nvidia Geforce 960M
  • GPU driver: non-free on nvidia
  • Kernel: linux44, linux45_RC
  • Skill: Novice
« Reply #3 on: 22. April 2016, 23:25:26 »
Just like happened with the 361 driver, this wont come to manjaro until the 1st bugfix update will arrive, so it will take time.. I hope this driver turns out to be very stable so it can be integrated very soon on manjaro.
On the other hand, Tomb raider will support only this new driver, and they highly probably also tested the 361. I just hope there wont be issues.
« Last Edit: 22. April 2016, 23:27:03 by eduardo »
