Author Topic: keyboard shortcut to close/minimize/maximize window  (Read 2839 times)
0 Members and 2 Guests are viewing this topic.
Offline cederlake
  • Neuling
  • I'm new. Be nice!
  • Desktop: Lxqt
  • GPU driver: free driver
  • Kernel: 4.4
  • Skill: Novice
« on: 22. April 2016, 15:34:16 »
Hello
How do you do that and how do I change the shortcut? I've managed to make shortcuts for chromium, mail etc. but I've haven't figured out how to close/minimize/maximize windows.
Cederlake
Offline crazyg4merz
  • Held Mitglied
  • Experience it, that's the way of learning!!
  • Branch: stable
  • Desktop: Gnome
  • GPU Card: Nvidia GTX 970
  • GPU driver: non-free
  • Kernel: Linux420-x64
  • Skill: Intermediate
Re: keyboard shortcut to close/minimize/maximize window
« Reply #1 on: 22. April 2016, 15:47:45 »
I don't think you can do that with lxqt. But you can do it in compiz wm. Maybe try using xfce + compiz combo?
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #2 on: 22. April 2016, 19:57:00 »
If you don't find the feature in LXQt, remember that it uses Openbox as WM and it has all kinds of well documented shortcuts.
A workaround would be installing wmctrl. Run wmctrl -h to see its options. Then assign wmcltrl commands with the target window :ACTIVE: to your shortcuts.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline napcok
  • Neuling
    • Manjaro PL
  • Branch: testing
  • Desktop: Plasma, Openbox, Fluxbox
  • Kernel: 4.4.4
« Reply #3 on: 22. April 2016, 20:15:29 »
You can edit ~/.config/openbox/rx.xml file.
Here  comes examples from my config:
Code: [Select]
<keybind key="W-Return">
      <action name="ToggleFullscreen"/>
    </keybind>
    <keybind key="W-B">
      <action name="ToggleDecorations"/>
    </keybind>
    <keybind key="W-d">
      <action name="ToggleShowDesktop"/>
    </keybind>
    <keybind key="A-F4">
      <action name="Close"/>
    </keybind>
    <keybind key="A-F5">
      <action name="Iconify"/>
    </keybind>
    <keybind key="A-F6">
      <action name="ToggleMaximize"/>
    </keybind>
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #4 on: 22. April 2016, 20:20:44 »
Check if Xfce shortcuts are installed. They would override Openbox ~/.config/openbox/rc.xml
For LXQt the shortcuts are defined in ~/.config/lxqt/globalkeyshortcuts.conf
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #5 on: 23. April 2016, 13:57:47 »
you can also set other stuff in your  ~/.config/openbox/rx.xml file.
i used it to set my internet browser to start always maximized. this is really handy. i also set it to always start without any window borders...
at the moment i am using kwin instead of openbox as window manager, but i liked openbox a lot. maybe i will return to it, if kwin has too many bugs...
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline cederlake
  • Neuling
  • I'm new. Be nice!
  • Desktop: Lxqt
  • Kernel: 4.4
  • Skill: Novice
« Reply #6 on: 05. May 2016, 00:30:12 »
Hello and sorry for answering late
I fixed it by changing the ~/.config/openbox/rc.xml.
It took some time for me to understand what to do but now it's working
