Author Topic: Issue running winecfg  (Read 1685 times)
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: Issue running winecfg
« Reply #15 on: 22. April 2016, 06:46:38 »
off the topic, it's really bad idea to use ntfs partition for /home
1. ntfs driver is very resource consuming and slow on linux
2. ntfs is prone to fragmentation, and makes case 1 even worse.
3. you can;t set permissions on individual files/folders. May create problems with recycle bin feature. And a few more complications i don;t remember now.
Since all user configs are in your /home, it will only slow your linux down. Use a native filesystem like xfs or ext4 for best results.
« Last Edit: 22. April 2016, 06:52:14 by badbodh »
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • GPU Card: intel and nvidia
  • GPU driver: non-free
  • Kernel: linux44
  • Skill: Novice
« Reply #16 on: 22. April 2016, 09:24:12 »
Wujuuu Thanks!!! It works, and probably it will help me fix other issues too, great!!
Off topic: damn, I didn't know about those issues, /home partition is shared with Windows, tha'ts why it is ntfs, I'll probably try to change it, as long as Windows reads it and doesn't have much issues with it. Thanks for the warning
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #17 on: 22. April 2016, 12:25:46 »
you can install ext2fsd , tiny program, sits quitely in your systray, mounts the ext2/3/4 partitions on windows. But use it in read-only mode, write isn;t very reliable and may corrupt your filesystem.
