Author Topic: Issue running winecfg  (Read 1682 times)
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • GPU Card: intel and nvidia
  • GPU driver: non-free
  • Kernel: linux44
  • Skill: Novice
« on: 17. April 2016, 05:00:13 »
This is a really noobish question but I'am unable to run wine. I'm using the KDE version of manjaro, with linux44 and with the latest system upgrade.
When I'm trying to run winecfg the following error is displayed:
wine: '/home/gabriel' is not owned by you, refusing to create a configuration directory there
It runs with
Code: [Select]
sudo winecfg but I'm aware it's a terrible idea, I tried using
Code: [Select]
sudo chown -R gabriel:gabriel /home/  and sudo chown -R gabriel:gabriel /home/gabriel/
but winecfg insists on the same error. When I check /home and /home/gabriel    the ownership is of root, and group root. under the permissions (using dolphin) I tried adding my user but it didn't work.
What can I do? D:
EDIT1: I'm using dual boot with Windows, /home is shared. (edit to add information)
« Last Edit: 17. April 2016, 17:55:12 by jack_howels »
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: Issue running winecfg
« Reply #1 on: 17. April 2016, 05:32:35 »
Code: [Select]
sudo chown -R gabriel:gabriel /home/gabriel/*
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #2 on: 17. April 2016, 05:41:36 »
Thanks, but, still winecfg displays the same error.
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #3 on: 17. April 2016, 05:47:58 »
delete .wine folder in your home you also have to chmod -R +rwx your files and folders
« Last Edit: 17. April 2016, 05:50:19 by badbodh »
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #4 on: 17. April 2016, 06:17:34 »
Just in case, I don't have a .wine folder in home. I tried with:
Code: [Select]
[gabriel@..... ~]$ chmod -R +rwx /home
[gabriel@..... ~]$ winecfg
I assumed -R would be enough but just in case
Code: [Select]
[gabriel@..... ~]$ chmod -R +rwx /home/gabriel
Didn't work either, sorry and thanks again.
EDIT: I'm I missing something of chmod?
« Last Edit: 17. April 2016, 17:46:51 by jack_howels »
Offline ekmeek
  • Neuling
  • Branch: Stable
  • Desktop: i3
  • GPU Card: nVidia & Intel
  • Kernel: linux41-x86_64 & linux44-i686
« Reply #5 on: 17. April 2016, 14:02:29 »
Could you send:
Code: [Select]
ls -lha /home
ls -lha /home/gabriel
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #6 on: 17. April 2016, 14:15:54 »
chmod and chown /home/gabriel, not /home. /home is supposed to be owned by root. Other users will have their home folders too, you are owning all of those. This is misuse of admin powers :P
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #7 on: 17. April 2016, 17:46:23 »
 I used both chmod and chown on /home/gabriel too, but it didnt work, I mistyped on the second code sentence, I'll edit
All belongs to root and root group.
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #8 on: 17. April 2016, 22:35:07 »
paste the output of
Code: [Select]
id and get ready to be pwned.
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #9 on: 21. April 2016, 02:44:47 »
Mmm how would id help?
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #10 on: 21. April 2016, 03:52:20 »
Please do as you are told. Run 'id' and paste the output. Can't help unless you share necessary info.
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #11 on: 22. April 2016, 03:11:43 »
Sorry.
Code: [Select]
uid=1000(gabriel) gid=1000(gabriel) groups=1000(gabriel),6(disk),7(lp),10(wheel),56(bumblebee),90(network),91(video),92(audio),93(optical),95(storage),96(scanner),98(power)
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #12 on: 22. April 2016, 04:33:21 »
now give me the following
Code: [Select]
lsblk
parted -l
cat /etc/fstab
and point out which partition </dev/sdXY> contains your home directory.
Offline jack_howels
  • Neuling
  • Newbie
  • Branch: stable
  • Desktop: KDE
  • Kernel: linux44
  • Skill: Novice
« Reply #13 on: 22. April 2016, 06:28:35 »
/dev/sda4 is home partition, sda3 is / partition. I didn't create a swap partition
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #14 on: 22. April 2016, 06:42:44 »
chown/chmod/file permissions mean nothing on an ntfs partition. No wonder they didn;t work for you.
In order to have read/write in ntfs replace
Code: [Select]
defaults,noatime with
Code: [Select]
rw,auto,noatime,uid=1000in fstab. Reboot for effect
edit: i did not intend to put noexec, copied from my own fstab.
« Last Edit: 22. April 2016, 06:52:54 by badbodh »
