Author Topic: How install without this error ?  (Read 1617 times)
Offline inukaze
  • Jr. Mitglied
    • Inukaze
  • Branch: stable
  • Desktop: Xfce, Trinity , Lxde , Lxde/qt , E16 , E17 , E18 , E19 , OpenBox , KDE4
  • GPU Card: Intel 945G / Nvidia GeForce 6200 TurboCache / Nvidia nForce 630a
  • GPU driver: non-free nvidia
  • Kernel: Linux Distro Kernel x86 / x86_64
  • Skill: Advanced
« on: 15. April 2016, 02:51:46 »
Hi there , thank you for any help can gave me . the thing is , when i try to install someone packages , can't be installed if the "icons" exists .
I have 2 distros installed on my pc ( Debian & Manjaro ) .
This are my partitions :
Because i ever share my icons and themes for all distro i installed , on my older hardisk of 250GB i have 20 distros GNU/Linux and GNU/FreeBSD in total . because of that i share themes , icons , and opt software .
i try to install , some packages
The installed has failed , because the "icons" already exist.
Really this not have much sense for me , why not simply , replace icons , or if already exist , simply ignore it and continue with installation ?
« Last Edit: 15. April 2016, 17:41:16 by inukaze »
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • Kernel: linux314 x64
  • Skill: Advanced
Re: How install without this error ?
« Reply #1 on: 15. April 2016, 04:27:00 »
If you want pacman to just overwrite the existing files, you can use --force
Code: [Select]
sudo pacman -S --force virtualbox
Offline inukaze
  • Jr. Mitglied
    • Inukaze
  • Branch: stable
  • Skill: Advanced
« Reply #2 on: 15. April 2016, 16:21:15 »
Code: [Select]
I know that , but how i can modify the "pamac-manager" , for always use "--force" and "--noconfirm"
Because the mayor part of time , i search in "pamac-manager" , and select 20 packages or more , but none is installed because 1 packages detect the icons already exist.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #3 on: 15. April 2016, 17:04:39 »
You asked exactly that question in August, 2015. What were the answers you received then?
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline inukaze
  • Jr. Mitglied
    • Inukaze
  • Branch: stable
  • Skill: Advanced
« Reply #4 on: 15. April 2016, 17:42:05 »
No . the anothers just told me "its not recommend use force"
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
« Reply #5 on: 15. April 2016, 17:51:42 »
If pamac-manager is a binary file (which is likely) you cannot modify it, you need to modify the source code and compile it yourself. Take a look at /bin
I can recommend pacli instead. This one you can modify and add its menu entries to your liking.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #6 on: 15. April 2016, 20:55:45 »
So the software authors said it's a bad idea. What do they know, eh? Why take their advice, right? I'm sure you know better so you could just take the pamac source and add it yourself.
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #7 on: 16. April 2016, 04:28:31 »
He meant answers, not authors, in referencing his previous question in these forums. The answers, all by knowledgeable forum members, overwhelmingly said, "What, you like pain? Do not do this or you will bork your system!"
Maybe some folks have a mis-rememberin' problem?
Regards
