Author Topic: (Solved) what is esp flags?  (Read 8657 times)
0 Members and 2 Guests are viewing this topic.
Offline gabi12
  • Vollwertiges Mitglied
  • Branch: testing/unstable
  • Desktop: manjaro xfce
  • GPU Card: onboard intel HD 4000
  • GPU driver: free
  • Kernel: linux4.4.5-1
  • Skill: Novice
« on: 12. April 2016, 10:05:37 »
Hi, I wanted to try LQXt again and started the installaiton of version 16.04. But calamares askt me that I shoult set esp flag for my boot/efi partition. So what is esp flag and do I need it?
« Last Edit: 12. April 2016, 17:55:00 by gabi12 »
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
Re: what is esp flags?
« Reply #1 on: 12. April 2016, 12:34:05 »
This would be the boot flag for your uefi fat32 partition used to store your uefi firmware that is used to boot the system.
reference: http://www.linux.org/threads/gparted-partition-and-filesystem-flags.8112/
Quote
esp - [MS-DOS, GPT] This flag indicates an UEFI System Partition. GPT uses this flag as an alias for "boot". The UEFI firmware stores files on this partition.
Offline gabi12
  • GPU driver: free
  • Skill: Novice
« Reply #2 on: 12. April 2016, 16:08:50 »
But my partition had already the bootflag, but I have to have the fat32 partition 2 flags?
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #3 on: 12. April 2016, 16:54:06 »
The esp flag tells the system that this is a UEFI boot partition not just a general boot partition.
Offline gabi12
  • GPU driver: free
  • Skill: Novice
(Solved)Re: what is esp flags?
« Reply #4 on: 12. April 2016, 17:54:01 »
Ok thank you for your help, then I will install the new LXQt tomorrow.
