Author Topic: system update problem  (Read 854 times)
Offline bzuzul13
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« on: 07. April 2016, 20:22:34 »
I just install Manjaro Deepin edition and run into this
sudo pacman -Sy manjaro-system
error: failed to update core (unable to lock database)
error: failed to update extra (unable to lock database)
error: failed to update community (unable to lock database)
error: failed to update multilib (unable to lock database)
error: failed to synchronize any databases
error: failed to init transaction (unable to lock database)
error: could not lock database: File exists
  if you're sure a package manager is not already
  running, you can remove /var/lib/pacman/db.lck
[m@m-pcc ~]$
any help appreciated
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: system update problem
« Reply #1 on: 07. April 2016, 20:29:28 »
remove command is rm
check first that you don't have another pacman relevant instance running (Pamac window open), then run
Code: [Select]
sudo rm /var/lib/pacman/db.lckalso take a look at Wiki article about pacman troubleshooting
« Last Edit: 07. April 2016, 20:31:09 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
