Author Topic: Manjaro JWM with OpenRC - trying to create ISO  (Read 1221 times)
Offline Holmes
  • Mirror Support Team
  • Brazilian and Hispanic Support Team
    • Manjaro Brasil
  • Branch: Stable
  • Desktop: Manjaro XFCE
  • GPU Card: Mobile Intel (R) 945
  • GPU driver: Non-free
  • Kernel: kernellinux
  • Skill: Novice
« on: 06. April 2016, 00:18:35 »
hi guys, i'm trying to create an iso Manjaro JWM with OpenRC but is in error, see:
Code: [Select]
resolving dependencies...
warning: removing 'polkit' from target list because it conflicts with 'polkit-consolekit'
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: tlp and pm-utils are in conflict
==> ERROR: Failed to install packages to new root
==> ERROR: Failed to install all packages
==> ERROR: A failure occurred in make_image_custom().
    Aborting...
 --> overlayfs umount: [/var/lib/manjaro-tools/buildiso/jwm/i686/jwm-image]
[holmes@manjaro-xfce Desktop]$
already i researched about it and found a solution.
can anybody help me?
vlw fwi, Holmes :)
==> Manjaro Brasil I Manjaro Hispano
==> IRC Manjaro Brasil: #manjaro-br I IRC Manjaro Hispano: #manjaro-es
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • GPU Card: Intel HD4000 + Nvidia 620M / Geforxe GTX 970
  • GPU driver: nonfree
  • Kernel: Latest
  • Skill: Intermediate
Re: Manjaro JWM with OpenRC - trying to create ISO
« Reply #1 on: 06. April 2016, 00:53:03 »
Code: [Select]
:: tlp and pm-utils are in conflictRemove tlp or pm-utils, you can't install both.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #2 on: 06. April 2016, 00:54:38 »
yes, i removed the tlp and i am running again...
vlw fwi, Holmes :)
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #3 on: 06. April 2016, 00:58:56 »
@kirek, other error:
Code: [Select]
error: failed to commit transaction (unexpected error)
    Aborting...
vlw fwi, Holmes :)
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
« Reply #4 on: 06. April 2016, 01:05:16 »
Check that you have enough disk space in /var, and if you recently updated your kernel, reboot.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #5 on: 06. April 2016, 03:40:36 »
@kirek,
it worked! howeverrealized a problem: lxdm is not working, see:
i have to use startx. do you have any idea?
vlw fwi, Holmes :)
Offline Kirek
  • Core Team
  • Branch: unstable
  • Desktop: Plasma 5
  • Kernel: Latest
« Reply #6 on: 06. April 2016, 07:35:39 »
What are the contents of "/etc/lxdm/lxdm.conf" ?
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
« Reply #7 on: 06. April 2016, 09:40:39 »
I wouldn't use tlp for openrc editions, because consolekit needs pm-utils to suspend/hibernate.
Do you packagelist like this:
Code: [Select]
>systemd tlp
>openrc pm-utils
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #8 on: 06. April 2016, 09:41:31 »
There has been a similar problem with LXDM on the previous version of LXDE profile, but Esclapion repaired it somehow.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #9 on: 06. April 2016, 09:55:37 »
Why and where do you add tlp?
Code: [Select]
## Power management
>openrc acpid-openrc
>systemd acpid
>openrc cpupower-openrc
>systemd cpupower
>systemd tlp
Packages-root is properly configured to work for both init systems.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #10 on: 06. April 2016, 12:19:22 »
hi all,
@kirek, content of the lxdm.conf in https://github.com/holmeslinux/Manjaro-JWM/blob/master/jwm-overlay/etc/lxdm/lxdm.conf. i saw nothing where i can change.
@artoo, tlp was in the package-jwm file, but have removed.
@eugen-b, i will do with Esclapion.
vlw fwi, Holmes :)
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #11 on: 06. April 2016, 12:55:09 »
I would also recommend a different DM.
Lxdm and consolekit need a patched lxdm, which is only available in AUR.
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #12 on: 06. April 2016, 16:45:56 »
@artoo, thanks for the feedback.
it is possible to add to repo of the Manjaro?
vlw fwi, Holmes :)
Offline Holmes
    • Manjaro Brasil
  • Branch: Stable
  • Skill: Novice
« Reply #13 on: 08. April 2016, 18:18:30 »
hi all, i use ligthdm!
resolved
vlw fwi, Holmes :)
