Author Topic: USB wifi dongo desn't work after Manjaro 1603 update  (Read 958 times)
Offline netbug
  • Neuling
  • I'm new. Be nice!
  • Desktop: Deepin
  • GPU Card: VMware
  • GPU driver: VMware
  • Skill: Novice
« on: 05. April 2016, 16:21:57 »
Running Manjaro Deepin Desktop on a Old PC with a Belkin USB wifi dongo (F7D2101). It worked fine with the installation. After updating the Manjaro 160330, USB Wifi doesn't work any more. Looking at logs, looks like it is using a driver for chipset rtl8712u instead of rtl8192su after the update.
How can I fix this?
# dmsg
[   44.956747] r8712u: module is from the staging directory, the quality is unknown, you have been warned.
[   45.177502] r8712u: register rtl8712_netdev_ops to netdev_ops
[   45.177521] usb 1-1: r8712u: USB_SPEED_HIGH with 4 endpoints
[   45.180734] usb 1-1: r8712u: Boot from EFUSE: Autoload OK
[   50.470223] usb 1-1: r8712u: CustomerID = 0x0000
[   50.470227] usb 1-1: r8712u: MAC Address from efuse = 94:44:52:eb:35:0e
[   50.470229] usb 1-1: r8712u: Loading firmware from "rtlwifi/rtl8712u.bin"
[   50.470294] usbcore: registered new interface driver r8712u
[   50.628148] r8712u 1-1:1.0 wls34u1: renamed from wlan0
[   50.661661] NetworkManager[558]: segfault at 8 ip 00000000004ca4d6 sp 00007ffe6ee2a3b8 error 4 in NetworkManager[400000+1c5000]
[  170.903065] r8712u 1-1:1.0 wls34u1: 1 RCR=0x153f00e
[  170.909030] r8712u 1-1:1.0 wls34u1: 2 RCR=0x553f00e
[  171.053548] IPv6: ADDRCONF(NETDEV_UP): wls34u1: link is not ready
[  574.575921] QDBusConnection[70939]: segfault at 0 ip           (null) sp 00007f525f0a4a28 error 14 in dde-lock[400000+1bd000]
# mhwd -lh
> USB devices:
                          TYPE            BUS   CLASS  VENDOR  DEVICE   CONFIGS
                           Hub        1-0:1.0   10a00    1d6b    0002         0
            Network controller        1-1:1.0    0200    050d    845a         0
                           Hub        2-0:1.0   10a00    1d6b    0001         0
                         Mouse        2-1:1.0   10503    0e0f    0003         0
                           Hub        2-2:1.0   10a00    0e0f    0002         0
# lsusb | grep RTL
Bus 001 Device 002: ID 050d:845a Belkin Components F7D2101 802.11n Surf & Share Wireless Adapter v1000 [Realtek RTL8192SU]
« Last Edit: 05. April 2016, 16:27:44 by netbug »
Offline netbug
  • Neuling
  • I'm new. Be nice!
  • Desktop: Deepin
  • GPU Card: VMware
  • Skill: Novice
Re: USB wifi dongo desn't work after Manjaro 1603 update
« Reply #1 on: 06. April 2016, 16:59:33 »
I reproduced the issue in a VMware VM hooking up with the same USB dongle. However, I couldn't reproduce the issue if I update the packages menually. I guess it probably is a hardware compatibility issue.
I replaced the dongle with a RALink one. Everything works just fine. C:-)
