Author Topic: Want numlock on and start conky scripts at login  (Read 1559 times)
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Desktop: KDE Plasma 5x
  • GPU Card: Nvidiot GeForce GTX 970
  • GPU driver: non-free
  • Kernel: 4.4
  • Skill: Novice
« on: 04. April 2016, 22:22:13 »
Hi,
When I login in deepin, I can't obtain numlock on.
Then I can't remove the computer and trash icon in desktop (tried with dconf without success)
And I want my conky scripts starts in login. And I can't make it with the .config/autostart directory
Do you have some solutions about this ?
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
Re: Want numlock on and start conky scripts at login
« Reply #1 on: 05. April 2016, 04:29:50 »
Hi,
You're the person with Guru in your forum profile. Please let us know how you fix it. :D
Regards
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
« Reply #2 on: 05. April 2016, 06:55:25 »
install 'numlockx" and add command "numlockx on" to startup.
Quote
Don't describe with crayons, show us the exact dconf key, exact contents of your .config/autostart/<conky's autostart file> so that novices can help you.
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #3 on: 05. April 2016, 08:31:36 »
For numlock: That's shitty, why deepin have an option to make it automaticaly and you have to use numlockx in start by yourself.... If I need to do it, I go to openbox.
For conky that's a script calls another script: http://pastebin.com/LU8zsKcK
For Trash and Computer 2 command lines:
dconf write '/com/deepin/dde/desktop/show-trash-icon' false
dconf write '/com/deepin/dde/desktop/show-computer-icon' false
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #4 on: 05. April 2016, 08:35:33 »
Regards
If you are guru you know all about all desktop environments.... Ok ok
That's not my fault if chinese make great looking DE and a shitty code, don't respects the standards.
Offline badbodh
  • Held Mitglied
  • Branch: Testing
  • Desktop: Xfce, i3
« Reply #5 on: 05. April 2016, 10:26:09 »
i won't guess what's in "~/.conky/ConkyBar/conky_start.sh" , do tell if your script runs fine when you exec it manually. Use
Code: [Select]
sh /home/<user>/.conky/ConkyBar/conky_start.sh If it does work, create a *.desktop file in .config/autostart , add usual entries. And use "Exec = sh /path/to/your/script.sh". Being a Guru yourself, i assume you've chmod-ed your script a nice +x.
As for desktop icons, they belong to nautilus. look into org>gnome>desktop>background instead.
Quote
On the contrary i've never used deepin in my life, yet i can guess what the solution is. That's called "standard compliance".
« Last Edit: 05. April 2016, 10:43:34 by badbodh »
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #6 on: 05. April 2016, 12:42:16 »
Code: [Select]
1. Desktop shortcut method failed, Already did it
2. Great you're the big boss but you fail. Already did it, look at this screenshot: http://i.imgur.com/TA0bXII.png
Your are kidding about my level or judgement but your "solutions" FAILS.
Edit: And I didn't forgot about the execution authorize (chmod +x ....). I'm not a moron. And I'm putting down my level if there is a problem
« Last Edit: 05. April 2016, 12:49:17 by Elrondo47 »
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #7 on: 05. April 2016, 12:50:51 »
I also don't like that they criticize you for having Guru in your skill field. But you are a bit too harsh in your criticizm of a DE which is still under development. Which might explain their remarks which are meant with humour, I would guess, as well as your remark. ;)
« Last Edit: 05. April 2016, 12:52:34 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #8 on: 05. April 2016, 12:56:13 »
The reason is I was angry about the different remarks about myself. I only searcheded for help.
Now my skill is novice, no more probs now I think
Edit: If I can't solve it, I will go to MATE (more stable I think)
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #9 on: 05. April 2016, 13:07:24 »
badbodh tried to help, but he is a bit funny guy, but actually friendly, so don't be angry at him.
MATE as ISO might be a bit outdated, but you can install it as a parallell session with pacman, or you might want to try Cinnamon.
As for Deepin, when there will be fixes Manjaro will be among the first to get them, right after Arch.
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #10 on: 05. April 2016, 13:13:25 »
Usally I purge all .config files and remove deepin completly. And install mate
Offline withjaro
  • Held Mitglied
  • 360
  • Branch: unstable
  • Desktop: openrc
  • GPU Card: geforce7150/ATIx2300
  • GPU driver: free
  • Kernel: linux4xxx-x64
  • Skill: Novice
« Reply #11 on: 05. April 2016, 13:18:00 »
Its true badbodh....  will selflessly deep cleanse your apartment..  when you pop out to the grocery store...  but they will steal all your chocolate biscuits.
I wouldnt worry,some hardware manufacturers have differering key placing..  and to be honest auditting keymappings is maybe one of those setup rituals that none of us get around to...  nice thing is,once you understand them,you can position them as you which - not one of us is POSIX default ;)
< insert your own inspiring quotation - and smile :) >
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #12 on: 05. April 2016, 14:33:33 »
Migrated in Mate successfully.
- Conky started great with my script :)
- Mate with dconf-editor didn't pissed me off for removing icons
- Less Ram impact
- Compiz in MATE runs very fast and stable (A miracle for compiz)
- Numlock directly at login
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #13 on: 05. April 2016, 15:17:23 »
- Less Ram impact
Glad you solved it Deepin is very young and unstable at this moment in time.
Don't worry about the comments they are only funning with you and are a very friendly bunch.
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline Elrondo47
  • Jr. Mitglied
  • Yo L4m4s :)
  • Branch: stable
  • Kernel: 4.4
  • Skill: Novice
« Reply #14 on: 05. April 2016, 15:21:39 »
Ok. Image of problem solved :)
