Author Topic: [LXDE] Calamares Installer crashes on my hardware  (Read 445 times)
Offline ajhlinuxuser
  • Neuling
    • Ubuntu Forums user "stlu"
  • Branch: stable
  • Desktop: Xfce is my fav
  • GPU Card: Virtualbox VGA device
  • GPU driver: N/A
  • Kernel: linux37-x86
  • Skill: Intermediate
« on: 03. April 2016, 23:30:10 »
Same problem as https://forum.manjaro.org/index.php?topic=32300.0, except this time I encountered it with Manjaro LXDE 16.03 64bit.  Again, calamares runs fine under virtualbox, so it is a hardware issue.
Here is the error output:
Code: [Select]
$ sudo calamares
21:23:22 [1]: Calamares version: 2.1.0
Translation: Calamares: Using system locale: "en_US"
Translation: Qt: Using default locale, system locale one not found: "en_US"
21:23:23 [1]: Default font =====
Pixel size:    -1
Point size:    12
Point sizeF:   12
Font family:   "Sans"
Metric height: 19
21:23:23 [1]: Font height: 19
21:23:23 [1]: Available languages: ("ar", "ast", "bg", "ca", "cs_CZ", "da", "de", "el", "en", "en_GB", "es_MX", "es", "eu", "fr", "hu", "id", "is", "it_IT", "ja", "lt", "nl", "pl", "pt_BR", "pt_PT", "ro", "ru", "sv", "th", "tr_TR", "zh_CN", "zh_TW")
21:23:23 [1]: CalamaresApplication thread: 0x6ebab0
21:23:23 [1]: Using log file: "/root/.cache/Calamares/Calamares/Calamares.log"
21:23:23 [1]: Using Calamares settings file at "/usr/share/calamares/settings.conf"
21:23:23 [1]: Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
21:23:23 [1]: WARNING: the selected branding component does not ship translations.
21:23:23 [1]: Loaded branding component "manjaro"
21:23:23 [1]: Proposed window size: 1024 684
21:23:23 [1]: Initial locale  "en_US"
21:23:23 [1]: ViewModule loading self for instance "welcome@welcome"
ViewModule at address 0xa5a220
Calamares::PluginFactory at address WelcomeViewStepFactory(0x95a980)
ViewStep at address WelcomeViewStep(0x845880)
21:23:24 [1]: ViewModule loading self for instance "locale@locale"
ViewModule at address 0x970020
Calamares::PluginFactory at address LocaleViewStepFactory(0x970270)
ViewStep at address LocaleViewStep(0xaa71e0)
No layout variant specified on the command line
Trailing -variant option ignored
21:23:28 [1]: xkbmap selection changed to:  "us" - ""
21:23:28 [1]: ViewModule loading self for instance "keyboard@keyboard"
ViewModule at address 0xab12d0
Calamares::PluginFactory at address KeyboardViewStepFactory(0x7a0010)
ViewStep at address KeyboardViewStep(0xab1440)
21:23:33 [1]: LIST OF DETECTED DEVICES:
node capacity name prettyName
21:23:33 [1]: "/dev/sda" 159998146560 "ATA Maxtor 6L160M0" "ATA Maxtor 6L160M0 – 149.01 GiB (/dev/sda)"
21:23:36 [1]: "Osprober lines, clean:\n"
21:23:36 [1]: ViewModule loading self for instance "partition@partition"
ViewModule at address 0x2df6f10
Calamares::PluginFactory at address PartitionViewStepFactory(0x2e01200)
ViewStep at address PartitionViewStep(0x2e0d120)
21:23:36 [1]: ViewModule loading self for instance "users@users"
ViewModule at address 0x2e316c0
Calamares::PluginFactory at address UsersViewStepFactory(0x2e31640)
ViewStep at address UsersViewStep(0x2e31c30)
21:23:36 [1]: ViewModule loading self for instance "summary@summary"
ViewModule at address 0x2e5a2e0
Calamares::PluginFactory at address SummaryViewStepFactory(0x2e5a6d0)
ViewStep at address SummaryViewStep(0x2e5a720)
21:23:36 [1]: Module "partition@partition" already loaded.
21:23:37 [1]: QML import paths: ("/usr/share/calamares/qml", "/usr/bin", "/usr/lib/qt/qml")
21:23:37 [1]: LAST VS IS EVS!
21:23:37 [1]: Module "locale@locale" already loaded.
21:23:37 [1]: Module "keyboard@keyboard" already loaded.
21:23:37 [1]: Module "users@users" already loaded.
21:23:37 [0]: void Calamares::Module::loadConfigurationFile(const QString&) bad module configuration format "/usr/share/calamares/modules/umount.conf"
21:23:37 [1]: ViewModule loading self for instance "finished@finished"
ViewModule at address 0x2ef98c0
Calamares::PluginFactory at address FinishedViewStepFactory(0x2efff50)
ViewStep at address FinishedViewStep(0x2f015b0)
21:23:37 [1]: Need at least storage bytes: 5905580032
21:23:37 [1]: Need at least ram bytes: 322122547
21:23:37 [1]: enoughStorage, enoughRam, hasPower, hasInternet, isRoot:  true true true true true
21:23:37 [1]: Updating partitioning state widgets.
21:23:37 [0]: QCoreApplication::postEvent: Unexpected null receiver
21:23:38 [1]: Updating partitioning preview widgets.
21:23:38 [0]: QCoreApplication::postEvent: Unexpected null receiver
Gtk-Message: (for origin information, set GTK_DEBUG): failed to retrieve property `GtkRange::activate-slider' of type `gboolean' from rc file value "((GString*) 0x7a0460)" of type `GString'
21:24:02 [1]: CreatePartitionTableJob::createTable trying to make table for device "/dev/sda"
21:24:02 [1]: Suggested swap size: 4.30729 GiB
21:24:02 [1]: # Queue:
21:24:02 [1]: ## Device: "ATA Maxtor 6L160M0"
21:24:02 [1]: - "Create new msdos partition table on /dev/sda."
21:24:02 [1]: - "Create new 148174MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system ext4."
21:24:02 [1]: - "Create new 4410MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system linuxswap."
21:24:02 [1]: Updating partitioning preview widgets.
21:24:02 [0]: QCoreApplication::postEvent: Unexpected null receiver
21:24:32 [0]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
21:24:32 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sda\nCreate new msdos partition table on /dev/sda.\nCreate new 148174MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system ext4.\nCreate new 4410MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system linuxswap.\nSet partition information"
21:24:32 [1]: Gathering UUIDs for partitions that exist now.
21:24:32 [1]: QHash(("", ""))
21:24:32 [1]: Writing to GlobalStorage["partitions"]
21:24:32 [1]: "" mtpoint: "/" fs: "ext4" ""
21:24:32 [1]: "" mtpoint: "" fs: "linuxswap" ""
21:24:35 [1]: PartitionCodeModule has been asked for jobs. About to return: "Clear all temporary mounts.\nClear mounts for partitioning operations on /dev/sda\nCreate new msdos partition table on /dev/sda.\nCreate new 148174MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system ext4.\nCreate new 4410MB partition on /dev/sda (ATA Maxtor 6L160M0) with file system linuxswap.\nSet partition information"
21:24:35 [0]: Starting job "Clear all temporary mounts."
21:24:35 [1]: Opened mtab. Lines:
21:24:35 [1]: "proc /proc proc rw,nosuid,nodev,noexec,relatime 0 0"
21:24:35 [1]: "sys /sys sysfs rw,nosuid,nodev,noexec,relatime 0 0"
21:24:35 [1]: "dev /dev devtmpfs rw,nosuid,relatime,size=1017992k,nr_inodes=254498,mode=755 0 0"
21:24:35 [1]: "run /run tmpfs rw,nosuid,nodev,relatime,mode=755 0 0"
21:24:35 [1]: "overlay / overlay rw,relatime,lowerdir=/ro_branch/live-image:/ro_branch/mhwd-image:/ro_branch/lxde-image:/ro_branch/root-image,upperdir=/rw_branch/upper,workdir=/rw_branch/work 0 0"
21:24:35 [1]: "/dev/sr0 /bootmnt iso9660 ro,noatime 0 0"
21:24:35 [1]: "securityfs /sys/kernel/security securityfs rw,nosuid,nodev,noexec,relatime 0 0"
21:24:35 [1]: "tmpfs /dev/shm tmpfs rw,nosuid,nodev 0 0"
21:24:35 [1]: "devpts /dev/pts devpts rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000 0 0"
21:24:35 [1]: "tmpfs /sys/fs/cgroup tmpfs ro,nosuid,nodev,noexec,mode=755 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/systemd cgroup rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/usr/lib/systemd/systemd-cgroups-agent,name=systemd 0 0"
21:24:35 [1]: "pstore /sys/fs/pstore pstore rw,nosuid,nodev,noexec,relatime 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/cpu,cpuacct cgroup rw,nosuid,nodev,noexec,relatime,cpu,cpuacct 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/memory cgroup rw,nosuid,nodev,noexec,relatime,memory 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/pids cgroup rw,nosuid,nodev,noexec,relatime,pids 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/net_cls cgroup rw,nosuid,nodev,noexec,relatime,net_cls 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/cpuset cgroup rw,nosuid,nodev,noexec,relatime,cpuset 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/bfqio cgroup rw,nosuid,nodev,noexec,relatime,bfqio 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/freezer cgroup rw,nosuid,nodev,noexec,relatime,freezer 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/blkio cgroup rw,nosuid,nodev,noexec,relatime,blkio 0 0"
21:24:35 [1]: "cgroup /sys/fs/cgroup/devices cgroup rw,nosuid,nodev,noexec,relatime,devices 0 0"
21:24:35 [1]: "systemd-1 /proc/sys/fs/binfmt_misc autofs rw,relatime,fd=23,pgrp=1,timeout=0,minproto=5,maxproto=5,direct 0 0"
21:24:35 [1]: "hugetlbfs /dev/hugepages hugetlbfs rw,relatime 0 0"
21:24:35 [1]: "mqueue /dev/mqueue mqueue rw,relatime 0 0"
21:24:35 [1]: "debugfs /sys/kernel/debug debugfs rw,relatime 0 0"
Segmentation fault
