Author Topic: how to install virt-manager (alternative to virtualbox)  (Read 821 times)
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
  • Skill: Intermediate
« on: 03. April 2016, 11:18:44 »
i wanted an alternative to virtualbox for a long time. yesterday, i have tested virt-manager.
i needed a little while until i could successfully install and use it. here is what i did:
- installed these packages:
Code: [Select]
sudo pacman -S virt-manager qemu ebtables dmidecode
- activated these services:
Code: [Select]
sudo systemctl enable libvirtd virtlogd
- rebooted
then, i could successfully create a new virtual machine and install ubuntu 16.04 in it.
during that process i had the following problems:
- NAT did not work. therefore, i had to manually select my ethernet card and bridge network connection.
- after a short while, virt-manager lost connection to 1 kvm/qemu module. luckily, virt-manager offered 2 such connections and the other one was stable.
p.s.: after writing this post, i just saw that "virt-manager-qt5" in the AUR got updated recently. i am testing it  and will report back!
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
Re: how to install virt-manager (alternative to virtualbox)
« Reply #1 on: 03. April 2016, 17:46:51 »
virt-manager continues to run fine (but requires gtk3).
somehow, i do not manage to setup a virtual hard disk with virt-manager-qt5. virt-manager-qt5 looks really complicated and much less intuitive. either i am too stupid to use it or it lacks the function to work properly (at least on my system).
well, i think i will test it again in a while. virt-manager-qt5 seems to make progress and is actively being developed.
