Author Topic: [stable] Manjaro Lxqt 16.04 released !  (Read 10932 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
Re: [stable] Manjaro Lxqt 16.04 released !
« Reply #30 on: 06. April 2016, 21:48:51 »
I've ran into a few issues :(
1) Compton use a lot of cpu power (nvidia driver)
2) splash screen non-existent?
3) plank and conky don't respond to icon theme changes
1) it's the reason for which it is not activated by default
2) i don't use plymouth because without it's lighter and quicker
3) i don't use both  ::)
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Fatboy
  • Sr. Mitglied
  • "Spiral out. Keep going..."
  • Branch: stable
  • Desktop: Xfce, KDE plasma 5
  • GPU Card: nVidia GeForce 210
  • GPU driver: 340.xx
  • Kernel: Manjaro Kernel 4.4 LTS
  • Skill: Intermediate
« Reply #31 on: 06. April 2016, 22:07:55 »
Haha fair enough. It's still an awesome build though. Will try it on my laptop once my xfce HDD dies :)
"I'm reaching for the random or whatever will bewilder me. Whatever will bewilder me."
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #32 on: 06. April 2016, 22:44:31 »
if you want an overview of available Qt apps, have a look here:
https://wiki.manjaro.org/index.php?title=List_of_Qt_Applications
i also recommend not to install any kde4 apps (=kdebase-runtime). it is just ridiculously large.
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • Kernel: linux46 - x64
« Reply #33 on: 07. April 2016, 09:09:17 »
Here's how to enable numlockx and disable dcreen saver
Numlockx
For those on desktop computers and want numlockx enabled at bootup.
I think numlockx package is included in 1604, but if not, install it.
Then go...  Preferences --> LXQT settings --> Sessions Settings --> Autostart --> Add -->
Code: [Select]
Name = Numlockx
Command=/usr/bin/numlockx
Wait for system tray = check
Reboot to take effect.
Disable Screen Saver
o Preferences --> LXQT settings --> Session Settings --> Basic Settings --> Uncheck Power Management
o Preferences --> LXQT settings --> Power Management --> Disable All Tabs
o Open up /etc/X11/xorg.conf.d/90-mhwd.conf
Set false in "DPMS" "false" at Monitor section
Code: [Select]
Section "Monitor"
Identifier   "aticonfig-Monitor[0]-0"
Option     "VendorName" "ATI Proprietary Driver"
Option     "ModelName" "Generic Autodetecting Monitor"
Option     "DPMS" "false"
Add this to file below Monitor section
Code: [Select]
Section "ServerFlags"
# disable low-level screensaver and screen DPMS poweroff
    Option "BlankTime"  "0"
    Option "StandbyTime" "0"
    Option "SuspendTime" "0"
    Option "OffTime"  "0"
EndSection
Well, not as easy to fix as in Openbox/Fluxbox (Kde/Plasma easiest) but fixed nevertheless.
« Last Edit: 07. April 2016, 10:06:29 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #34 on: 07. April 2016, 12:01:03 »
For the screen saver, you can't disable that by power management ?
It's based on openbox, so it must be the same or simpler.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #35 on: 07. April 2016, 16:57:00 »
No, this doesn't work. Try it. Within 13 minutes, screen will blank out.
Also see https://forum.manjaro.org/index.php?topic=18720.msg171165#msg171165
I had tried all these while. Finally found this solution.
What I had been doing before this is to put a bash and manually run it when I start lxqt.
Putting this bash in start up also won't work. I had tried lots other things too, but had to manually bash it.
And as I said, I can do this automatically in Openbox and Fluxbox, even though all (including LXQT) use openbox, but not in LXQT.
« Last Edit: 07. April 2016, 17:09:15 by gohlip »
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #36 on: 07. April 2016, 17:16:56 »
thanks for the tip with the screensaver, i will test it in a couple of hours and report back.
have you reported that bug on lxqt's github page?
about numlock: there is a setting since lxqt 0.10, which works on my system: Main Menu --> Settings --> LXQt Session Configuration --> Keyboard and Mouse --> Keyboard --> ...
if that does not work, here is a guide about numlockx: https://wiki.manjaro.org/index.php?title=Minimal_LXQt_installation#Activating_Num_Lock
before lxqt 0.10, i just added "numlockx on" command to the autostart. "on" is the default value, but "numlockx off" and "numlockx toggle" work, too.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #37 on: 07. April 2016, 17:28:40 »
Yes... numlock..... there had been many versions of lxqt and some have different methods..for example..
https://forum.manjaro.org/index.php?topic=14875.msg135947#msg135947
https://forum.manjaro.org/index.php?topic=13257.msg119686#msg119686
But I guess each iteration of LXQT has improvements and changes which is good and I thought maybe we let LXQT 'settle down'. It the beginning stage, these might not be 'bugs' but developmental stages. But you may be right, this screensaver thing can be considered a bug. Wonder what Escapion think? After all, he's the head honcho here on this.
Cheers.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #38 on: 07. April 2016, 22:06:15 »
I do not know where it comes from.  ??? There is no screensaver integrated lxqt.
I read this afternoon a jwm user complaining about the same thing. So, I think to a common part.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #39 on: 08. April 2016, 05:49:55 »
Hope you find it. If there's anything you want me to test, just let me know.
Thanks and good luck.
Offline leledumbo
  • Sr. Mitglied
    • Pascal Warrior's Journey
  • Branch: stable
  • Desktop: KDE
  • GPU Card: Intel HD 4400 + nVidia GeForce GT 740M (HP notebook), Intel HD 5500 + nVidia GeForce GT 940M (ASUS notebook), nVidia GeForce GT 220 (desktop)
  • GPU driver: non-free
  • Kernel: linux-latest-x64 and linux-latest LTS-x64
« Reply #40 on: 09. April 2016, 11:55:17 »
Trying pacman -Syu from 16.03 installation, it doesn't turn into 16.04 :/
Do I need full reinstall?
Manjaro Net edition 64-bit + Self installed KDE
Kernel latest supported + latest LTS
HP Pavilion 14-n038tx
Asus A455LB-WX034D
Self built desktop
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #41 on: 09. April 2016, 12:04:55 »
The substance of the distro are the packages. Just take a look at the Stable Updates thread, download the list of updated packages and compare it with your package versions. If you see no difference - everything is alright.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline leledumbo
  • Sr. Mitglied
  • Branch: stable
  • Desktop: KDE
« Reply #42 on: 12. April 2016, 10:53:00 »
I check lsb_release -a output, it's still 16.03 even after yaourt -Syua + reboot.
Asus A455LB-WX034D
Self built desktop
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #43 on: 12. April 2016, 16:06:12 »
the title of this thread refers to date of release of the latest manjaro lxqt.
people, who do not have the latest prerelease version of manjaro installed probably see "15.12" when they do a lsb_release -a.
that number is just not important. manjaro is a rolling release and you have the latest version whenever you do a "# pacman -Syu".
if you want to use the themes and settings of the latest manjaro release, just create a new user on your system.
Offline leledumbo
  • Sr. Mitglied
  • Branch: stable
  • Desktop: KDE
« Reply #44 on: 13. April 2016, 14:51:51 »
I just knew this fact. I thought whenever pacman -Syu (when there's an update batch of course) is done, it's also updated. But apparently not, good to know.
Asus A455LB-WX034D
Self built desktop
