Author Topic: [stable] Manjaro Lxqt 16.04 released !  (Read 10931 times)
Offline pawelx
  • Neuling
  • No longer Ubuntu-based...
  • GPU driver: non-free
  • Skill: Intermediate
Re: [stable] Manjaro Lxqt 16.04 released !
« Reply #15 on: 05. April 2016, 22:50:15 »
My first impressions: I love it!
The only problem (also present in the previous edition) is that brightness keys don't work on my Lenovo laptop (I had to use xbacklight to turn down the brightness). Actually, the volume keys don't work either (although they did work on the previous edition).
« Last Edit: 05. April 2016, 22:51:46 by pawelx »
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
« Reply #16 on: 06. April 2016, 04:23:20 »
Go to Preferences --> LXQT settings --> Shortcut keys -->
Select the volume keys, modify and replace with your key board keys. (Mine works without needing this).
Same with brightness control.
Life is a sexually transmitted disease with a 100% mortality rate.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #17 on: 06. April 2016, 04:26:43 »
How do I set application windows to pop up in left, not in center?
In Openbox, I did this in Openbox config. In LXQT, couldn't find it here (or forgot where to find it).
In the past, both Openbox, LXQT and Fluxbox opens app windows to left and top. Now they pop up in center.
Thanks.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
« Reply #18 on: 06. April 2016, 05:02:02 »
Replying myself (after much twidling around)..
Go to ~/.config/openbox/rc.xml, add the line     "<center>no</center>" (starting line 27) to
Code: [Select]
  <placement>
    <policy>Smart</policy>
    <!-- 'Smart' or 'UnderMouse' -->
    <center>no</center>
Offline arunj
  • Neuling
  • I'm new. Be nice!
« Reply #19 on: 06. April 2016, 08:05:24 »
Awesome! I installed 2016.03 a week earlier. How do I upgrade to 2016.04?
Note: I have been using Ubuntu for years... just warming up with pacman and its ways.
Offline STiAT
  • Neuling
  • Skill: Novice
« Reply #20 on: 06. April 2016, 08:17:11 »
I'd guess by doing a "sudo pacman -Syu" since they say it's released.
I've another question: What's used for network management in the lxqt version?
Offline Fatboy
  • Sr. Mitglied
  • "Spiral out. Keep going..."
  • Branch: stable
  • Desktop: Xfce, KDE plasma 5
  • GPU Card: nVidia GeForce 210
  • GPU driver: 340.xx
  • Kernel: Manjaro Kernel 4.4 LTS
« Reply #21 on: 06. April 2016, 08:37:09 »
Gonna download this now and give it a spin! Whoohoo!
Stupid Question: Is it possible to make the task window labels disappear so that only the icons of the open application is showing? One can do this in XFCE and Cinnamon. Just curious
"I'm reaching for the random or whatever will bewilder me. Whatever will bewilder me."
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #22 on: 06. April 2016, 09:15:07 »
Yes, it is possible.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Fatboy
  • Sr. Mitglied
  • Branch: stable
« Reply #23 on: 06. April 2016, 09:26:43 »
Thanks eugen-b ;)
I am busy testing this release, and damn, it is amazing! Really enjoy the theming and such. The applications menu looks so pretty.
But my favourite part is alt+F2 :D
SUPER EXCITING! haha
Offline Fatboy
  • Sr. Mitglied
  • Branch: stable
« Reply #24 on: 06. April 2016, 09:28:49 »
Just a question, since I'm new to the Qt environment: Should one stay with Qt based apps? Are there any apps one should stay clear of that could induce system breakages?
I have a set of lightweight apps I usually install.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #25 on: 06. April 2016, 10:01:41 »
It is difficult to give a definitive answer, qt or not qt. I qould say qt apps are worth trying, but if you don't like the available ones, try a gtk2 app. I tried juffed and notepadqq from AUR but didn't like these text editors and switched to mousepad, but kwrite could also be ok if you need more coding functionality.
gtk2 looks and works fine, but gtk3 apps can sometimes look ugly, but they work.
The only hindrance to get rid of gtk3 entirely is nm-applet.
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #26 on: 06. April 2016, 12:37:27 »
Some applications are already gtk2, et 2 or 3 gtk3. root account is also half-configured for gtk2. I worked on that to avoid ugly look.
What's to avoid to have a light system are qt4 applications (qt4 is not installed) and kde applications (kdebase-runtime also not). But it will not break your system.
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline Fatboy
  • Sr. Mitglied
  • Branch: stable
« Reply #27 on: 06. April 2016, 12:56:40 »
@eugen-b and @esclapion Thanks for the advice :)
Great job @esclapion, this is really the best LXQt distro I have seen! Gonna install it today! Whoohoo!
Offline pawelx
  • Neuling
« Reply #28 on: 06. April 2016, 18:38:25 »
OK, thanks, I'll try that.
I just wish I had another computer to install it on, as I don't want to touch my current Manjaro installations (XFCE on the laptop and KDE on the desktop), though it looks it might work like a breeze on my rather low-end laptop.
Offline Fatboy
  • Sr. Mitglied
  • Branch: stable
« Reply #29 on: 06. April 2016, 21:29:00 »
I've ran into a few issues :(
1) Compton use a lot of cpu power (nvidia driver)
2) splash screen non-existent?
3) plank and conky don't respond to icon theme changes
