Author Topic: [stable] Manjaro Lxqt 16.04 released !  (Read 10817 times)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • GPU driver: nonfree
  • Kernel: 4.4.6
  • Skill: Advanced
« on: 01. April 2016, 15:03:54 »
Manjaro-Lxqt 16.04 released
The Manjaro Community is proud to present our new Lxqt Edition.
Manjaro-Lxqt aims to be light, fast and resource friendly, yet at the same time complete and ready to use for all typical everyday office- and multimedia-needs.
Screenshots*
Clean :
*This nice wallpaper has been done by SambaNeko and used without modification.   :)
Dirty :
Main programs
- kernel 4.4.6 LTS, Manjaro settings manager, sddm, octopi, compton, redshift
- pcmanfm-qt, gimp, lximage-qt
- chromium (64 bits) or firefox (32), hexchat, transmission-qt
- abiword, qpdfview, gnumeric(64)
- mpv, smplayer(mpv based) with all skins and themes. 32 -> qastools, 64 -> pulseaudio and pavucontrol
- gparted, qisousb, lxtask, xsensors
- multilib enabled (64)
- capture tool + key Print Screen configured for taking screenshots (also with Alt or Shift)
This release comes with our advanced graphical installer Calamares as well as our CLI-installer. Stable branch was used to create these install medias.
Downloads
What is changed
- menu item  leave connected to i3lock with blur
- gnumeric added to 64 bits
- calendar is now readable
- shortcut reboot moved at the right
- new sddm theme futuristic
- a lot of enhancements for french translation
- lila-hd icons theme added to the 64 bits (and to AUR)
- bug on default applications solved
- by default, no notification if a removable disjk is connected
- speedcrunch replaced by kcalc
- smplayer-mpv replace by smplayer-svn (AUR), skins and themes added
- white backgrounds changed (FFFFFF -> F8F8F8) for less eyestrain
- incosolata replaces monospace
- root partially themed
- administrator terminal works now
- capture tool added to the menu
- brand new repository, named manjaro-lxqt
Known default
It can happens than you get the message "A stop job is running for ..." at shutdown or reboot, and must wait 1'30". This is not specific to lxqt, I have that too under fce.
In Lxqt, "Magic keys" are activated. So, instead of wait so long, you can press :
Alt + Print screen + B for reboot, or
Alt + Print Screen + E for shutdown.
Do only that in this case, in can be too hard on running applications.
« Last Edit: 09. April 2016, 12:33:52 by Esclapion »
Venez nous rejoindre sur l'IRC francophone
Patrice - Violence is the last refuge of the incompetent (Asimov)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Re: [stable] Manjaro Lxqt 16.04 released !
« Reply #1 on: 01. April 2016, 15:15:53 »
Well, the Krosoft theme from the previous release was more pain than joy. This one makes a Linux user feel @home.
The fast startup isn't anything new, is it?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #2 on: 01. April 2016, 15:37:23 »
No, I just wanted the measure on my new pc. I find it impressive.  ;)
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #3 on: 01. April 2016, 16:43:15 »
... and the krosoft theme has been a success : almost 30,000 downlads.  ^-^
Offline excalibur1234
  • Global Moderator
  • Branch: unstable
  • Desktop: net-minimal + LXQt
  • GPU driver: video-nouveau
  • Kernel: 4.6
« Reply #4 on: 01. April 2016, 21:39:14 »
one question:
i assume you already have included the new qt5.6 in this release?
you are right, this is not caused by lxqt!
if that happens regularly, please do the following:
open these files:
      /usr/lib/systemd/system
      /etc/systemd/system
      /etc/systemd/system.conf
and change the following line to your liking:
       "TimeoutStopSec="
Need more information? Search here:   Manjaro Forum   |   Manjaro Wiki   |   Arch Wiki
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #5 on: 01. April 2016, 21:54:01 »
I tried that, but it continues...  :(
Offline Fatboy
  • Sr. Mitglied
  • "Spiral out. Keep going..."
  • Branch: stable
  • Desktop: Xfce, KDE plasma 5
  • GPU Card: nVidia GeForce 210
  • GPU driver: 340.xx
  • Kernel: Manjaro Kernel 4.4 LTS
« Reply #6 on: 01. April 2016, 22:37:19 »
This looks super slick! Gonna try it out asap :)
"I'm reaching for the random or whatever will bewilder me. Whatever will bewilder me."
Offline kamowski
  • Neuling
  • I'm new. Be nice!
« Reply #7 on: 05. April 2016, 07:43:08 »
beatiful lila-hd icons, thanks
Offline AJSlye
  • Maintainer
  • Netrunner Rolling Edition moderator / maintainer
  • Branch: Stable / Testing / Unstable
  • Desktop: Netrunner Rolling
  • GPU Card: Intel
  • GPU driver: Intel
  • Kernel: 4.4.1-1-MANJARO x86_64 (64 bit)
  • Skill: Guru
« Reply #8 on: 05. April 2016, 14:13:38 »
I've noticed that for me, this seems to happens when I have a USB storage device attached at shutdown.
« Last Edit: 05. April 2016, 14:16:15 by AJSlye »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
« Reply #9 on: 05. April 2016, 14:40:25 »
Solved, see HERE.
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • Kernel: linux46 - x64
« Reply #10 on: 05. April 2016, 18:06:17 »
Nice..... Installed, working and reconfigured. Each edition better than the last. Thanks again.
I think I installed/reinstalled more LXQT than all the other Manjaro's combined.
« Last Edit: 05. April 2016, 18:15:26 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
  • Global Moderator
  • Branch: unstable
  • Kernel: 4.6
« Reply #11 on: 05. April 2016, 18:47:12 »
i agree. it is great to see all the theming esclapion comes up with.
i do not care about the look of my DE much, but esclapion seems to have an artistic streak.
also, i think lxqt is slowly picking up pace.
just look at the views of my wiki list of qt apps. a couple of weeks ago i looked at that number accidentally. i am impressed!
i think lxqt will become even more popular when ubuntu is released with unity8 (qt based DE).
Offline niyasc
  • Neuling
  • I'm new. Be nice!
  • Desktop: GNOME
« Reply #12 on: 05. April 2016, 19:29:25 »
Offline AJSlye
  • Maintainer
  • GPU Card: Intel
  • GPU driver: Intel
  • Skill: Guru
« Reply #13 on: 05. April 2016, 19:41:56 »
Next time you should add the SDDM Configuration Editor to the repository and ISO to make it easy to change the theme, auto login, etc.
https://github.com/hagabaka/sddm-config-editor
You know, you can change the default background of sddm just by adding a theme.conf.user file in the theme directory that points to a different background image?
Code: [Select]
[General]
background=/usr/share/wallpapers/{background image file}
« Last Edit: 05. April 2016, 19:43:31 by AJSlye »
Offline Esclapion
  • Support Team
    • manjaro
  • Branch: stable
  • Desktop: Lxqt
  • GPU Card: GTX 970
  • Kernel: 4.4.6
  • Skill: Advanced
