Author Topic: file location(s) for system tray icons  (Read 2077 times)
Offline minjaro
  • Neuling
  • Branch: stable
  • Desktop: the legendary fluxbox (openrc edition)
  • GPU Card: Intel 945 GM
  • GPU driver: i915
  • Kernel: 4.4.5-1 x86
  • Skill: Intermediate
« on: 01. April 2016, 09:05:39 »
where are the toolbar icons for pm-applet, nm-applet, cbatticon, etc?
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
Re: file location(s) for system tray icons
« Reply #1 on: 01. April 2016, 10:42:48 »
Try a file search tool to find them! nm-applet seems to be defined by the selected icon theme, pamac-tray is probably in hicolor icon theme. You can also open Pamac, select pamac package and look in the tab "Files".
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #2 on: 01. April 2016, 10:47:45 »
Code: [Select]
$ pacman -Ql pamac | grep "icons"
pamac /usr/share/icons/
pamac /usr/share/icons/hicolor/
pamac /usr/share/icons/hicolor/16x16/
pamac /usr/share/icons/hicolor/16x16/apps/
pamac /usr/share/icons/hicolor/16x16/apps/system-software-install.png
pamac /usr/share/icons/hicolor/24x24/
pamac /usr/share/icons/hicolor/24x24/status/
pamac /usr/share/icons/hicolor/24x24/status/pamac-tray-no-update.png
pamac /usr/share/icons/hicolor/24x24/status/pamac-tray-update.png
pamac /usr/share/icons/hicolor/32x32/
pamac /usr/share/icons/hicolor/32x32/apps/
pamac /usr/share/icons/hicolor/32x32/apps/system-software-install.png
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #3 on: 01. April 2016, 10:54:16 »
Code: [Select]
$ which nm-applet
/usr/bin/nm-applet
Code: [Select]
pacman -Qo nm-applet
/usr/bin/nm-applet is owned by network-manager-applet 1.0.10-1
and then
Code: [Select]
]$ pacman -Ql network-manager-applet | grep "icons"gives you a long list ;)
Different for:
Code: [Select]
$ pacman -Ql pa-applet | grep "icons"
This one doesn't bring it's own icons but must be calling for standard icons provided be the current icon theme - or if there isn't one, then the 'inherited' theme will be used - in most cases that's as eugen-b says hicolor.
« Last Edit: 01. April 2016, 10:58:49 by oberon »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #4 on: 01. April 2016, 11:00:21 »
Also: If the current icon-theme provides an icon then hicolor will be ignored.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #5 on: 01. April 2016, 11:15:55 »
By the way, it would be great to have also some bigger sized pamac-tray icons
I was once struggling to find a substitute in 48x48 size.
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #6 on: 01. April 2016, 11:21:22 »
Well, since we are packaging pamac ourselves that wouldn't be a problem at all. Just, someone has to provide the icons ;)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #7 on: 01. April 2016, 12:07:46 »
 Mensa-Circle includes pamac icons in svg! ...
