Author Topic: error: target not found: manjaro-livecd-systemd  (Read 1326 times)
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
  • Kernel: linux38-x86
« on: 29. March 2016, 12:29:46 »
Hi,
Trying many times using manjaro-tools to build manjaro installer but always stuck on those two lines:
error: target not found: manjaro-livecd-cli-installer
what I missed?
Thanks in advance,
-iip-
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Desktop: LXQT/Plasma5, openrc & eudev
  • Kernel: x86_64
  • Skill: Advanced
Re: error: target not found: manjaro-livecd-systemd
« Reply #1 on: 29. March 2016, 12:45:13 »
Are you using git iso profiles?
Make sure your git repo is up to date.
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
« Reply #2 on: 29. March 2016, 13:09:33 »
I worked with profiles from https://github.com/manjaro/manjaro-tools-iso-profiles
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
« Reply #3 on: 29. March 2016, 13:12:45 »
do a git pull
You need to regularly update your local git repo when using git.
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
« Reply #4 on: 29. March 2016, 13:31:00 »
do a git pull
I just did a git pull after you reply, and the result still the same
Offline Strit
  • Maintainer
  • Manjaro Torrent Maintainer
    • Strits.dk
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: GTX 760 OC
  • GPU driver: Non-free nvidia 361
  • Kernel: 4.4.8-1-MANJARO
  • Skill: Intermediate
« Reply #5 on: 29. March 2016, 13:33:14 »
The packages are no longer in the repo, so you have to edit your profiles and remove does packages from the package list of live-cd.
Desktop PC: Manjaro XFCE 15.12 (stable, kernel 4.4)
Private Laptop: Manjaro Strit 16.03 (unstable, kernel 4.6)
Work Laptop: Manjaro Strit 16.03 (stable, kernel 4.4)
Netbook: Arch Linux XFCE/LXqt (i686, kernel 4.0)
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
« Reply #6 on: 29. March 2016, 13:56:06 »
Do you know where I should edit the package profile? I search in both /usr/share/manjaro-tools and manjaro-tools-iso-profiles recursively but no luck
Thanks in advance,
Offline Strit
  • Maintainer
    • Strits.dk
  • Branch: Stable
  • Desktop: XFCE
« Reply #7 on: 29. March 2016, 13:58:27 »
It should be in manjaro-iso-profiles-git under the shared folder.
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
« Reply #8 on: 29. March 2016, 14:20:53 »
hmm...I can't find those package in that sub folder...
Offline Strit
  • Maintainer
    • Strits.dk
  • Branch: Stable
  • Desktop: XFCE
« Reply #9 on: 29. March 2016, 14:30:03 »
For me it's in the "manjaro-tools-iso-profiles/shared/Packages-Live[-Xorg]" text files. This is taken from the git version.
Offline artoo
  • OpenRC Team
  • Branch: Unstable
  • Kernel: x86_64
  • Skill: Advanced
Offline iip
  • Neuling
  • Branch: testing
  • Desktop: mate
  • GPU Card: nvidia
  • GPU driver: free
« Reply #11 on: 30. March 2016, 08:52:20 »
Finnaly I found the problem, build iso still using my old deleted chroot folder, even if I delete .config/manjaro-tools/manjaro-tools-iso-profiles.conf, if I run again the run_dir still refer to trash folder on /home/iip/.local/share/Trash/files/manjaro-tools-iso-profiles, after I emptying the trash, and remove the configuration...it seem works now.
thanks for all the help,
Best regards,
-iip-
