Author Topic: Uninstalling a Package in root/pft  (Read 648 times)
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Desktop: KDE Plasma Version 5.6.3
  • GPU Card: Intel Quad Core i7-4790K - NVIDIA GeForce GTX 745
  • GPU driver: non-free
  • Kernel: 4.4.9-1 Manjaro
  • Skill: Novice
« on: 13. March 2016, 19:46:12 »
I installed PDFStudio 10 per instruction given on their website. In this case sudo PDFStudio_v10_3_0_linux64.sh.
FYI: (PDFStudio 8, and 9 is available in AUR, but not the version 10).
I installed it in the root/opt folder, because that's where the Octopi would have installed it. Now I'm trying to uninstall it, via clicking on the uninstall folder, but it tells me “Access denied to opt/pdfstudio10/uninstall”. I don't see any option to login as root, nor it asks for a password.  so how can I get in as root?
Offline blade
  • Jr. Mitglied
  • Branch: Unstable
  • Desktop: Xfce 4.12.3
  • GPU Card: NVIDIA GeForce GT 650M
  • Kernel: 4.5.x-1-MANJARO
  • Skill: Advanced
Re: Uninstalling a Package in root/pft
« Reply #1 on: 13. March 2016, 20:03:01 »
Have you tried again with terminal and sudo?
Code: [Select]
sudo /opt/pdfstudio10/uninstall/uninstall.sh
« Last Edit: 13. March 2016, 20:10:08 by blade »
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Skill: Novice
« Reply #2 on: 13. March 2016, 20:24:53 »
It tells me "sudo: /opt/pdfstudio10/uninstall/uninstall.sh: command not found". I see the uninstall folder, and it would let me click on it if I had the root password, but it doesn't even ask for a password. Any other suggestion?
I got it. I did the following:
cd /opt
sudo pdfstudio10/uninstall, and that did it.
Thanks blade for the tip.  :)
« Last Edit: 13. March 2016, 20:34:39 by fredhoud »
