Author Topic: Installation Flash Player 20 on Firefox  (Read 1926 times)
Offline GoldenKeyRiver
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Deepin
  • GPU Card: Intel
  • GPU driver: free
  • Kernel: linux45
  • Skill: Novice
« on: 11. March 2016, 16:46:53 »
You can simply use commands:
yaourt -S chromium-pepper-flash
yaourt -S freshplayerplugin
First command installs Flash Player 20 on Manjaro.
Second command installs Firefox plugin.
Offline badbodh
  • Held Mitglied
  • Windows assumes I'm stupid, Linux proves it.
  • Branch: Testing
  • Desktop: Xfce, i3
  • GPU Card: Intel Mobile 4 Series
  • Kernel: linux41 64-bit
  • Skill: Intermediate
Re: Installation Flash Player 20 on Firefox
« Reply #1 on: 12. March 2016, 09:02:19 »
you forgot the third step. open "about:addons" > plugins > flash > "Never activate"
 :P :P :P :P :P :P
You can't feel the love till it hurts a little. Go rolling, go bleeding-edge !
Offline Odysseus
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: KDE
  • GPU Card: nVidia GeForce Go 7950 GTX
  • GPU driver: nVidia non-free
  • Kernel: linux44-x64
« Reply #2 on: 29. April 2016, 15:54:21 »
I've tried this, but it doesn't work for me. Even if I have the plugin activated all of the time, when I go to a flash enabled webpage I just see space instead. Are there any other steps you may be omitting?
Offline LizziAS
  • Vollwertiges Mitglied
  • Branch: Hyssop
  • Desktop: OB-OpenRC
  • GPU Card: 6520G
  • GPU driver: Catalyst
  • Kernel: Zen
« Reply #3 on: 03. May 2016, 11:21:30 »
Also there is pipelight which uses the Windows flash that has drm.
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Xfce (4.12.3)
  • GPU Card: AMD Radeon HD 8570 / R7 200 Series
  • GPU driver: Non-free (Catalyst)
  • Kernel: 4.6rc7 - x86_64
« Reply #4 on: 04. May 2016, 00:09:13 »
You don't need the chromium-pepper-flash if you have not installed the chromium.
So if you want the newer flash for firefox:
Firstly unistall the flash:
Code: [Select]
sudo pacman -R flashplugin
After that, install freshplayerplugin:
Code: [Select]
« Last Edit: 04. May 2016, 21:37:29 by kouros17 »
Offline manjar
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: E1-1200 with Radeon™ HD 7310
  • GPU driver: free
  • Kernel: linux 4.4.8.1
  • Skill: Novice
« Reply #5 on: 05. May 2016, 11:13:11 »
Quote
[/move]( Unsupported package: Potentially dangerous ! )
==> Edit PKGBUILD ? [Y/n] ("A" to abort)
==> n
==> freshplayerplugin dependencies:
 - pango (already installed)
 - alsa-lib (already installed)
 - freetype2 (already installed)
 - libevent (already installed)
 - gtk3 (already installed)
 - libgl (already installed)
 - v4l-utils (already installed)
 - ffmpeg (already installed)
 - cmake (already installed) [makedepend]
 - ragel (already installed) [makedepend]
==> Edit freshplayerplugin.install ? [Y/n] ("A" to abort)
==> n
==> Continue building freshplayerplugin ? [Y/n]
==> y
I'm a new user of linux..and manjaro.
Do I need to make other choices to properly install Flash player?
Also, do I need some additional plugin to make it work?
« Last Edit: 05. May 2016, 11:26:40 by manjar »
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #6 on: 05. May 2016, 11:46:59 »
Of course you need  chromium-pepper-flash the standalone version, in Firefox to use the   as freshplayer is just a wrapper PPAPI-host NPAPI-plugin adapter. The 1st step is to totally remover flashplugin and reboot then install chromium-pepper-flash freshplayerplugin open firefox and enable simple really.
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline manjar
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: XFCE
  • GPU driver: free
  • Skill: Novice
« Reply #7 on: 05. May 2016, 19:36:54 »
ok...so I need freshplayerplugin+chromium-pepper-flash?
« Last Edit: 05. May 2016, 19:38:25 by manjar »
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
« Reply #8 on: 05. May 2016, 22:41:29 »
i have firefox and chrome (not chromium, not chromium-pepper-flash) and installing only freshplayerplugin the latest flash running fine on firefox without chromium-pepper-flash.
Try to remove flashplugin, install freshplayerplugin as I mentioned before and if it doesn't work then install chromium-pepper-flash.  :)
« Last Edit: 06. May 2016, 01:34:07 by kouros17 »
Offline manjar
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: XFCE
  • GPU driver: free
  • Skill: Novice
« Reply #9 on: 06. May 2016, 11:49:28 »
I had to install chromium pepper flash to make it work
Offline Odysseus
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: KDE
« Reply #10 on: 06. May 2016, 13:53:39 »
I've tried at least a 1/2 dozen times, but can't get it to work. The old flash plugin for Firefox woks without issues. I thought that being able to use pepper flash would be even better since it's still actively developed. I can't figure out what I'm doing wrong.
The steps I take are to 1) uninstall flash. 2) install chromium-pepper-flash 3) install freshplayerplugin. I've even tried reversing the order for steps 2 and 3 with no luck. Every site that I know is flash enabled fail to work or flash test sites tell me I have pepperflash (can tell by the version number) installed, but I get only black or white boxes where the flash animation should render.
Do I need to change the referer so these sites think I'm using chrome? I'm at my wits end, but won't lose any sleep over it since standard flash plugin works, but I'd like to know why this isn't.
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
« Reply #11 on: 11. May 2016, 21:28:58 »
If you have installed the google-chrome then you don't need to install the chromium-pepper-flash but if you have not the google-chrome then you need to install it.
Offline LizziAS
  • Branch: Hyssop
  • GPU Card: 6520G
  • Kernel: Zen
« Reply #12 on: 15. May 2016, 04:54:58 »
are you sure you don't have a flash block plugin enabled?
why not try pipelight?
