Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
131 (85.1%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
10 (6.5%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
13 (8.4%)
Total Members Voted: 154
Author Topic: [Update] 2016-03-11 - OpenSSL, Kernels, GTK2, Firefox, Chromium, Wine  (Read 11858 times)
Offline beardedragon
  • Held Mitglied
  • Branch: Stable OpenRC & Testing Systemd
  • Desktop: Xfce 4.12.3 (Gtk 2.24.28)
  • GPU Card: NVIDIA GK208 [GeForce GT 720/PCIe/SSE2]
  • GPU driver: 4.5.0 NVIDIA 361.42(non-free)
  • Kernel: 4.4-6 & 4.6-rc5-MANJARO-x86_64
  • Skill: Advanced
Stable updates went well, no issues, Thanks Team.
Robert Collard Madison, WI
Lenova K450e  8GB RAM
ManjaroLinux 15.12 Capella
Offline Jon
  • Neuling
  • Branch: stable
  • Desktop: KDE
  • GPU Card: GeForce GTX 960
  • GPU driver: nonfree
  • Skill: Intermediate
I run into problems with ruby, cause by the openssl update.
Ruby was not working completely, so i did this:
http://stackoverflow.com/a/15219553
Ruby worked again and i could work with rails. But if i try to connect with any service that requires ssl i get this:
SSL_connect returned=1 errno=0 state=SSLv3 read server certificate B: certificate verify failed
any fixes?
Ran into the same issue. That SO answer is outdated, you shouldn't need to do any of that for OpenSSL support now. You need to fully remove RVM to fix this, reinstalling with rvm reinstall will not work. So you should just run rvm implode then reinstall RVM and Ruby.
Offline memorylost
  • Vollwertiges Mitglied
  • Branch: stable+aur
  • Desktop: Xfce
  • GPU Card: nVidia GTX 660
  • GPU driver: non-free
  • Kernel: linux4.1-x64
  • Skill: Novice
Code: [Select]
tput: No value for $TERM and no -T specifiedI reported this but meanwhile I found fix: https://forum.manjaro.org/index.php?topic=32018.0
For anyone having that problem, what does
Code: [Select]
echo $TERM output?
Also manjaro-base-skel package got updated recentely with new .bash_profile and .bashrc, create another admin user with manjaro settings manager.
Logon with that user and try the tests again.
Offline blade
  • Jr. Mitglied
  • Branch: Unstable
  • GPU Card: NVIDIA GeForce GT 650M
  • Kernel: 4.5.x-1-MANJARO
  • Skill: Advanced
Code: [Select]
echo $TERM output?
Output of
Code: [Select]
echo $TERM is
Code: [Select]
xtermI create new user, install pacli package again and try to install some package to see if the problem is fixed. Result is the same error so only workaround for now is to remove pacli. I never need this interactive interface for pacman and I don^t experience any problem if I remove it.
I just checked why this happend and found that pacli create two folders in /etc/pacman.d/ (hooks and hooks.bin) with two files (pacli-description.hook and pacli-description.sh).
« Last Edit: 12. March 2016, 23:22:01 by blade »
Offline oliver11
  • Neuling
  • Branch: testing
  • Desktop: Gnome
I can confirm this issue:
Mouse pointer is invisible over gnome-shell overview and top bar
https://bugzilla.redhat.com/show_bug.cgi?id=1316010
Offline CyberWolf2k14
  • Held Mitglied
  • Computers make very fast, very accurate mistakes.
  • Branch: Stable-sysd229-LightDM
  • Desktop: MATE/Cinnamon/GNOME
  • GPU Card: nVidia GeForce GT740
  • GPU driver: nVidia-NF-364.19
  • Kernel: 4.4.9x64 / 4.2.8.9x64 / 4.1.23x64
From Bugzilla, it looks like the attempts to fix are happening in Fedora GNOME 23, so maybe these fixes
will appear upstream sometime after that, then will arrive for those of us on the user end of it all.
PowerSpec Quad core Intel Core i5-4690K w/ 16GB RAM
Dual Boot = Win 7 Ult x64 and Manjaro 15.12 x64
"A computer lets you make more mistakes faster than any invention in human history...
with the possible exceptions of handguns and tequila".
Offline mbb
  • Neuling
  • This text is ... personal!
  • Branch: Stable
  • Desktop: i3
  • GPU Card: Mobility Radeon 9200
  • GPU driver: video-ati (free)
  • Kernel: linux314-x86
  • Skill: Novice
Hi!
3 machines were updated: 2 desktops with kde4 (one x64 and another i686, both using kde5 apps, except for plasma) and a laptop with i3 (i686).
The i686 desktop wasn't updated for a very long time (more than 400 packages were updated) and failed to boot with a "no init system found" error. The solution was to boot from a live media CD (v0.8.12 was used), chroot into the system and rebuild the initramfs image.
All went smooth on the other two machines.
Keep up the good work ;)
Offline Arcano
  • Neuling
  • From Argentina to the World
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: ATI Radeon HD 6310
  • GPU driver: Free
  • Kernel: linux44 - x64
Hi
Congrats to Manjaro Team!!!!
I've found a graphical bug in XFCE using pamac (gui)
Its only happen when it's refreshing repos db and I click on "details": freezes on "updating multilib".
If I don't open details don't freezes and finish the refreshing correctly.
I add the screenshot.
Hope my comment to be useful.
Sorry for my terrible English!
Regards from Argentina!!!
Offline Adr1an
  • Kudos to the Devs
  • Branch: Stable
  • Desktop: Gnome-LightDM
  • GPU Card: AMD/ATI
  • GPU driver: Free
  • Kernel: 344 LTS
So far here no issues, and a free, new kernel up and running. Again, many thanks.
Win7 & Manjaro Gnome dual boot; 2011 Dell Studio 15; Intel Core i5 M450 @ 2.40GHz × 4; 4GB RAM; AMD ATI Mobility Radeon HD 5400 series
Offline curtvaughan
  • Neuling
  • Branch: stable
  • Kernel: 4.4.8-1-MANJARO x86_64
  • Skill: Novice
Since updating this morning, I have fairly consistently experienced mouse freezes on my laptop while using the Chromium browser (have not tested enough on Firefox browser to notice yet). Here's my configuration:
Quote
System:    Host: manjaro-linux Kernel: 4.4.5-1-MANJARO x86_64 (64 bit gcc: 5.3.0)
           Distro: ManjaroLinux 15.12 Capella
Machine:   System: Dell product: Inspiron 3531 v: A01
           Mobo: Dell model: 0NJFRV v: A00 Bios: Dell v: A01 date: 05/06/2014
CPU:       Quad core Intel Pentium N3530 (-MCP-) cache: 1024 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 17314
           clock speeds: max: 2582 MHz 1: 938 MHz 2: 1483 MHz 3: 706 MHz
           4: 977 MHz
Graphics:  Card: Intel Atom Processor Z36xxx/Z37xxx Series Graphics & Display
           bus-ID: 00:02.0
           Display Server: X.Org 1.17.4 driver: intel
           Resolution: 1366x768@60.04hz
           GLX Renderer: Mesa DRI Intel Bay Trail
           GLX Version: 3.0 Mesa 11.1.2 Direct Rendering: Yes
Audio:     Card Intel Atom Processor Z36xxx/Z37xxx Series High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k4.4.5-1-MANJARO
Network:   Card: Qualcomm Atheros AR9485 Wireless Network Adapter
           driver: ath9k bus-ID: 02:00.0
           IF: wlp2s0 state: up
Drives:    HDD Total Size: 500.1GB (2.3% used)
           ID-1: /dev/sda model: ST500LT012 size: 500.1GB
Partition: ID-1: / size: 106G used: 6.9G (7%) fs: ext4 dev: /dev/sda7
           ID-2: swap-1 size: 4.17GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 48.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 151 Uptime: 1 min Memory: 319.3/3843.5MB
           Init: systemd Gcc sys: 5.3.0
           Client: Shell (bash 4.3.421) inxi: 2.2.35
Is this perhaps a known issue? Is there any way, short of a brute force reboot, to recover the mouse once frozen? Thanks for any help / suggestions.
Move from Rim to Hub; know the Wheel.
Offline iKreate
  • Neuling
  • Branch: Stable ( ManjaroLinux 15.12 Capella )
  • Desktop: Xfce 4.12.3 (Gtk 2.24.30)
  • GPU Card: amd r7970
  • GPU driver: fglrx
  • Kernel: 4.4.9-1-MANJARO x86_64 (64 bit)
  • Skill: Novice
Hi
i can confirm this to be true for me as well.
Offline omnimoon
  • Neuling
  • Former distrohopper
  • Branch: stable
  • Desktop: KDE / Xfce
  • GPU Card: Nvidia GeForce 940M / ATI Radeon HD 6310
  • Kernel: linux44-x64 / linux43-x64
  • Skill: Novice
Perfect update, no issues at all. Thank you team!!
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
Thank you @Arcano and @iKreate! I have just opened an issue at pamac's github about that.
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Richard
  • Sr. Mitglied
  • Louisiana in Venezuela
  • Branch: Stable x32
  • Desktop: Xfce
  • GPU Card: Intel 2nd Gen.
  • GPU driver: Intel
  • Kernel: linux41, 31
  • Skill: Novice
"It was a dark and stormy night," ... well, sort of.  :)
Last night, I downloaded and installed manjaro-xfce-15.12-i686 onto my desktop
Code: [Select]
System:    Host: h61h2-manj Kernel: 4.1.19-1-MANJARO i686 (32 bit gcc: 5.3.0)
           Desktop: Xfce 4.12.3 (Gtk 2.24.28) Distro: ManjaroLinux 15.12 Capella
Machine:   Mobo: ECS model: H61H2-CM v: 1.0 Bios: American Megatrends v: 4.6.4 date: 10/21/2011
CPU:       Dual core Intel Pentium G620 (-MCP-) cache: 3072 KB
           flags: (lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10381
           clock speeds: max: 2600 MHz 1: 1637 MHz 2: 1731 MHz
Info:      Processes: 153 Uptime: 4:15 Memory: 1331.9/1958.1MB Init: systemd Gcc sys: 5.3.0
           Client: Shell (xfce4-terminal) inxi: 2.2.35
Started the update from Update Manager which indicated about 780 updates
It ran all night and was almost finished this morning, except, it found an error and refused to continue?
Code: [Select]
error: failed to commit transaction (unexpected error)
  :P  Probably tired.
So, back to the wiki, the forum and the console.
Probably should have started here, but I've been away from Manjaro a while:
Code: [Select]
sudo pacman -Syuu
sudo pacman-mirrors -g
sudo pacman -Syuu
sudo pacman -Sy archlinux-keyring manjaro-keyring
error: required key missing from keyring
sudo pacman-key --refresh-keys
keyserver hkp://ipv4.pool.sks-keyservers.net:11371
sudo keyserver hkp://ipv4.pool.sks-keyservers.net:11371
pacman-key --populate archlinux
sudo pacman-key --populate archlinux
su
sudo su
somewhere along in here, I started the update again from the Update-Manager and it ran to completion.
Added the 4.1.* kernel which performs well on this desktop machine.
Continued setup: DoubleCommander, Slimjet & the Great-Suspender, Dropbox, axel, fsarchiver, wmctrl, etc.
Really nice job on 15.12.  8)  I like the Classic look. Implies stability, durability, polish. Works for Mint. :)
Congratulations to the developers, packagers, testers, and users.
ECS H61H2, Intel Pentium G620 2GB Aud Vid
Netbooks: Intel Atom N270, 1GB
MX15; Manjaro-15.12 w/4.1.*, x32
Linux Counter #208633.
Offline Quetzal
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: Intel HD 4400
  • GPU driver: free
  • Kernel: 4.5, 4.2, 3.18 (x64)
All is fine on my XFCE desktop. I have tried the experimental 4.5rc7 without any issue.
Good job as usual Manjaro team !  :)
