Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
131 (85.1%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
10 (6.5%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
13 (8.4%)
Total Members Voted: 154
Author Topic: [Update] 2016-03-11 - OpenSSL, Kernels, GTK2, Firefox, Chromium, Wine  (Read 11856 times)
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
Why don't you read the error mesaage, @hitman2?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline DK3
  • Vollwertiges Mitglied
    • TechHQ
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: Many (AMD,Nvidia,Intel)
  • GPU driver: AMD,Nvidia non-free
  • Kernel: 4.5.x
  • Skill: Novice
Update on 11 Machines without Problems.
Thx
DK3
- Management is, if 10 people are paid for something what 5 could do cheaper, if they are only 3 and 2 of them are ill.
- Computers are the most intelligent idiots whom there are.
Offline Nergal
  • Neuling
  • Branch: Stable
  • Desktop: KDE Plasma 5
  • GPU Card: Intel / nVidia GTX 970M
  • GPU driver: non-free
  • Kernel: 4.4.3-1
  • Skill: Novice
The usual, smooth update on two systems.
___________________________________
MSI GS60 Ghost Pro 3K- i7-4710HQ - 16GB
Offline aguador
  • Branch: Stable
  • Desktop: E20
  • GPU Card: Intel 945 GME; Radeon 9000; Nvidia 340xx
  • GPU driver: Free; free; free
  • Kernel: Linux314-net; Linux44-x86; Linux44-x64
  • Skill: Novice
Everything OK on three machines, except a minor glitch with Tomboy notes.
The two machines I updated yesterday gave the following warnings after when updating sg3_utils and Tomboy:
Code: [Select]
[2016-03-11 08:09] [ALPM] upgraded sg3_utils (1.41-1 -> 1.42-1)
[2016-03-11 08:09] [ALPM-SCRIPTLET]
[2016-03-11 08:09] [ALPM-SCRIPTLET] (gconftool-2:13902): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
[2016-03-11 08:09] [ALPM-SCRIPTLET] Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[2016-03-11 08:09] [ALPM] upgraded tomboy (1.14.1-2 -> 1.15.4-1)
[2016-03-11 08:09] [ALPM-SCRIPTLET] (gconftool-2:13914): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
While the update on the third machine today did not produce the warning, after rebooting all three machines, Tomboy, which had been set to launch at startup, started in search mode despite still having /usr/local/applications/tomboy.desktop set to:
Code: [Select]
EXEC=tomboy
from the default:
Code: [Select]
EXEC=tomboy --search
The update did not change the .desktop file, yet the program launched in search mode. Uninstalling Tomboy and reinstalling and re-editing the .desktop file solved the problem.
However, I still do not understand what was going on with the error/warning messages.
On another topic, I see that Manjaro Settings Manager now notifies of new kernels. However, I had to turn the notification off on one machine as the netbook kernel is still 3.14.
« Last Edit: 12. March 2016, 20:32:15 by aguador »
Offline hitman2
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: ati
  • GPU driver: free
  • Kernel: 4.0.9-1
  • Skill: Novice
Installing new kernel.
error: failed to start transaction (could not lock the database)
error: unable to lock the database: File exists if you are sure that the package manager is not running, you can remove /var/lib/pacman/db.lck
-> The process failed!
Offline blade
  • Jr. Mitglied
  • Branch: Unstable
  • Desktop: Xfce 4.12.3
  • GPU Card: NVIDIA GeForce GT 650M
  • Kernel: 4.5.x-1-MANJARO
  • Skill: Advanced
Code: [Select]
tput: No value for $TERM and no -T specified
Having the same issue on LXQT using octopi.
I reported this but meanwhile I found fix: https://forum.manjaro.org/index.php?topic=32018.0
Offline blade
  • Jr. Mitglied
  • Branch: Unstable
  • Skill: Advanced
Do this:
Code: [Select]
sudo rm /var/lib/pacman/db.lck or just restart your PC.
Offline hitman2
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: ati
  • GPU driver: free
  • Kernel: 4.0.9-1
  • Skill: Novice
Do this:
Code: [Select]
thanks now is instaled but i have one more problem.
how can i change from one kernel to another?
Offline blade
  • Jr. Mitglied
  • Branch: Unstable
  • Skill: Advanced
If you have multiple kernels installed you can make a choice in grub menu. Just go to advanced options and select what kernel you want to use.
Offline hitman2
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: ati
  • GPU driver: free
  • Kernel: 4.0.9-1
  • Skill: Novice
when I get to this menu my keyboard is off and I can not choose the kernel
Offline gadgetboi
  • Neuling
  • I'm new. Be nice!
    • da gadgetboi's blog
  • Branch: stable
  • Desktop: KDE, Deepin, Cinnamon
  • Skill: Novice
114 packages... seems like everything went smooth!
Thanks.
have you ever experience sudden dissapear of windows decoration on your KDE?  :-\
Offline gadgetboi
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Skill: Novice
Smooth for my XFCE-base laptop but not so in KDE :-[ ... this newest update (somehow) trigger my KDE old bug: sudden dissapear of window decoration. Need to get log off and on to make it right since "killall plasma" routine never works anymore
Offline gadgetboi
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Skill: Novice
just notice now. KGET need to be reinstalled since after update, it won't work. hope others won't have to be like KGET
Offline Foxwater
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce, KDE
  • GPU Card: ATi 7950
  • GPU driver: Free
  • Kernel: 4.1-x64
  • Skill: Novice
Smooth update both KDE & Xfce.  Updated Kernel on both machines without issue.  Thank you
There is only one corner of the universe you can be certain of improving, and that's your own self.
Aldous Huxley
Offline salome
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: XFCE
  • GPU Card: NVIDIA GT218 [GeForce 210]
  • GPU driver: Mesa / nouveau free drivers
  • Kernel: linux314-x64
Smooth update as usual, thank you!
