Author Topic: allservers question  (Read 977 times)
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
  • GPU driver: non free
  • Skill: Intermediate
allservers question
« on: 09. March 2016, 22:16:51 »
If I type
<#pacman-mirrors -g> at the command line it  returns <bash: pacman-mirrors: command not found>  I understand the pacman-mirrors -g is for Arch and will not work in Manjaro. I am not 100% on that but have read it more than one place.  It says the mirrors have been refreshed when returned from using allsercers but I do not believe it as nothing changes in /etc/pacman.d/mirrorlist.
IF I use reflector it will rank the ones I have uncommented.
The kicker is (I think..) that pacman-morrorlist may have used to be a depenency of reflector therefor throwing everything off.
I wish I wasn't so picky as to how I try and keep my system tweaked to the highest point of efficiency and optimized as best I can and then It wouldn't matter so much.It is not like I have anything close to slow mirrors but...Well some of you know what I mean.
Can anyone clarify my little muddled mind?
Thanks!
Offline Jeannie
  • Held Mitglied
  • Skill: Novice
Re: allservers question
« Reply #1 on: 09. March 2016, 22:20:25 »
Hitten by the door in the back when I left Manjaro.
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #2 on: 09. March 2016, 22:31:11 »
$ pacman -Qo `which pacman-mirrors`
/usr/bin/pacman-mirrors is owned by pacman-mirrorlist 20160301-1
therefore:
pacman -S pacman-mirrorlist
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
« Reply #3 on: 09. March 2016, 22:40:25 »
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
« Reply #4 on: 09. March 2016, 22:42:03 »
pacman-mirrorlist I have. I get command not found with it also.
I wanted to be able to use the allservers script like I used to but I can and guess I will use rank mirrors or reflector. Unless I am just really missing something here. That's a possibility also.
« Last Edit: 09. March 2016, 22:46:36 by glsmaxx »
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #5 on: 09. March 2016, 23:14:25 »
That screenshot appears to indicate you're running Arch. That's pretty poor form not to mention it (and your first post suggests you're running Manjaro, not Arch).
If you have pacman-mirrorlist installed in Manjaro, you have /usr/bin/pacman-mirrors. If you're getting "command not found" it suggests your PATH is set incorrectly.
If "which pacman-mirrors" returns nothing, try "locate pacman-mirrors". You didn't say whether you actually reinstalled pacman-mirrorlist, but I'll assume you did.
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
« Reply #6 on: 10. March 2016, 14:03:07 »
It is a Manjaro install. Not Arch. I use Archey3 instead of screenfetch.  That's all.
Offline Rob
  • Core Team
  • Alias: Korrode
  • Branch: Unstable
  • Desktop: Xfce+Compiz
  • GPU Card: nVidia GTX560Ti
  • GPU driver: non-free
  • Kernel: linux314 x64
  • Skill: Advanced
« Reply #7 on: 10. March 2016, 14:18:12 »
With a "Kernel Release" tag that reads 4.1.19-1-lts instead of 4.1.19-1-MANJARO?
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
« Reply #8 on: 10. March 2016, 14:30:18 »
Yes, you are correct. It IS Arch!
My apologies!
My mistake for sure!
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #9 on: 10. March 2016, 14:42:44 »
My apologies!
You been nailed.
Rob, Jonathon, good hammer-job. ;)
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline glsmaxx
  • Jr. Mitglied
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: nVida
« Reply #10 on: 10. March 2016, 21:17:07 »
I really didn't think I would get caught trying to slip the Arch Linux machine in here.
Guess the next time I spend a week trying to get over on you guys ()Who have never made an honest mistake) I will have to get up much earlier OR stay @ a Holiday Inn Express.
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #11 on: 10. March 2016, 21:40:10 »
You been nailed.
I wouldn't say that - it was still a case of working out why 'pacman-mirrors' wasn't there. The fact that it's because he's not running Manjaro is just the reason, nothing more than that.
It's also nice if Arch users say they're using Arch in the first place so we know there will be subtle differences. In this case I think it was an honest mistake (although how you don't know what OS you're running...  ::))
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #12 on: 11. March 2016, 02:11:36 »
1. As an Archer, I thought it interesting that Arch wasn't mentioned 'til after the fact.
2. As one that follows the Arch Forums, I thought the accidental 'mirroring' effect was absolutely comical!*
3. The fact a solution was immediately posted was wonderful. :)
*To explain to the uninitiated, problem question posting in the Arch Forums is limited to Arch-only questions. All others are immediately binned and the poster educated. The response by Rob & Jonathon 'mirrored' the response of Arch Forum moderators who often find similar questions posed and a long thread generated--sometimes even by Manjaro users--and which elicit a very similar first response once it is discovered to be a non-Arch problem. The DIFFERENCE is, here in the Manjaro Forums, we don't care--we want to help fix the problem. (We are a kinder and gentler forum. Which is good. Especially for people like me.)  BUT it really helps talking apples/apples. ;)
Regards
EDIT: Oh my goodness. This was my one-thousand-oneth post in the Manjaro Forums. Good people. Good distro. Good discourse. :D
« Last Edit: 11. March 2016, 02:19:47 by c00ter »
