Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
28 (96.6%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 (0%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
1 (3.4%)
Total Members Voted: 29
Author Topic: [Update] 2016-03-08 - OpenSSL, Firefox, Chromium  (Read 3947 times)
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Xfce (4.12.3)
  • GPU Card: AMD Radeon HD 8570 / R7 200 Series
  • GPU driver: Non-free (Catalyst)
  • Kernel: 4.6rc7 - x86_64
  • Skill: Intermediate
Re: [Update] 2016-03-08 - OpenSSL, Firefox, Chromium
« Reply #30 on: 10. March 2016, 21:10:56 »
OK - finish it off with a `modprobe vboxdrv`. That got mine working again.
The same error:
Code: [Select]
[giorgos@manjaro ~]$ sudo modprobe vboxdrv
modprobe: ERROR: could not insert 'vboxdrv': Exec format error
Offline jonathon
  • Core Team
  • Technologist - Teacher - Tea drinker
  • Branch: Unstable
  • Desktop: MATE 1.14
  • GPU Card: Nvidia GTX680M
  • GPU driver: Bumblebee nvidia+intel
  • Kernel: 4.6.0-*-MANJARO x86_64
  • Skill: Advanced
« Reply #31 on: 10. March 2016, 21:25:31 »
That should have worked.  >:(
Did you definitely remove linux45-virtualbox-host-modules ? What's the output of `ls /usr/lib/modules/4.5.0-1-MANJARO/extramodules/` ?
« Last Edit: 10. March 2016, 21:27:56 by jonathon »
MSI GT70: Core i7-3630QM, 16GB, Nvidia GTX680M, Intel 2230, Manjaro-MATE-amd64-EFI
Lenovo X230: Core i5-3320M, 4GB, Intel HD4000, Intel 6205, Manjaro-MATE-amd64
Dell Studio 1749: Core i5 540, 8GB, ATi HD5650, Intel WLAN, Manjaro-Xfce-amd64
Let's go in the garden; you'll find something waiting.
Offline Kev.M
  • Jr. Mitglied
  • Branch: Manjaro Stable + Arch Stable
  • Desktop: Xfce
  • GPU Card: Mesa DRI Intel(R) Sandybridge
  • Kernel: 44 & 46
  • Skill: Novice
« Reply #32 on: 10. March 2016, 21:45:45 »
I just got another update few minutes ago, virtualbox with kernel 45 is running fine,
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
« Reply #33 on: 10. March 2016, 21:46:42 »
YOU ARE ABSOLUTELY RIGHT!
I had to remove linux45-virtualbox-host-modules before. Virtualbox running fine now with kernel 4.5rc7!
Thanks a lot jonathon!  :D
The steps are:
Code: [Select]
sudo pacman -R linux45-virtualbox-host-modules
sudo dkms remove vboxhost/5.0.14_OSE -k 4.5.0-1-MANJARO
sudo dkms install vboxhost/5.0.14_OSE
No errors messages anymore  :)
Code: [Select]
[giorgos@manjaro ~]$ systemctl status systemd-modules-load
● systemd-modules-load.service - Load Kernel Modules
   Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; stat
   Active: active (exited) since Πεμ 2016-03-10 22:34:18 EET; 10min ago
     Docs: man:systemd-modules-load.service(8)
           man:modules-load.d(5)
  Process: 218 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited,
 Main PID: 218 (code=exited, status=0/SUCCESS)
    Tasks: 0 (limit: 512)
   CGroup: /system.slice/systemd-modules-load.service
« Last Edit: 10. March 2016, 21:53:45 by kouros17 »
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #34 on: 10. March 2016, 21:49:34 »
@Kev.M, @kouros17, this is all good information. Depending on how things change with extramodules and DKMS this is going to prevent a heck of a lot of issues down the line.
This is why people running testing branch are awesome. :)
Looks like the linux45-virtualbox-host-module has been rebuilt for 4.5rc7 - you can use either that or DKMS, it's essentially the same - you just have to remember to reinstall the DKMS modules with each kernel update (I'm looking into this; it should really be automatic). I think `dkms autoinstall` might do the job but I need to test it.
« Last Edit: 10. March 2016, 22:24:59 by jonathon »
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
« Reply #35 on: 10. March 2016, 21:51:22 »
What about linux45-virtualbox-host-modules now? Should i reinstall them or not?
Offline jonathon
  • Core Team
  • Branch: Unstable
  • Skill: Advanced
« Reply #36 on: 10. March 2016, 21:54:01 »
Arg, that's in my edit. It's your choice - DKMS or extramodule, but not both.
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
« Reply #37 on: 10. March 2016, 21:55:38 »
I got it. :)
Thanks again jonathon!
Offline Kev.M
  • Jr. Mitglied
  • Desktop: Xfce
  • Kernel: 44 & 46
  • Skill: Novice
« Reply #38 on: 10. March 2016, 22:13:25 »
Thanks, I am only too happy to test if it helps. Its about all I can do,
so off to browse, watch movies and make sure they all work ;D
Offline beardedragon
  • Held Mitglied
  • Branch: Stable OpenRC & Testing Systemd
  • Desktop: Xfce 4.12.3 (Gtk 2.24.28)
  • GPU Card: NVIDIA GK208 [GeForce GT 720/PCIe/SSE2]
  • GPU driver: 4.5.0 NVIDIA 361.42(non-free)
  • Kernel: 4.4-6 & 4.6-rc5-MANJARO-x86_64
  • Skill: Advanced
« Reply #39 on: 11. March 2016, 01:28:23 »
Today's upgrade went well, see below.  ThanksTeam.
Code: [Select]
[2016-03-10 06:28] Upgraded linux45 (4.5rc6-1 -> 4.5rc7-1)
[2016-03-10 06:28] Upgraded pacli (0.7-1 -> 0.8-1)
[2016-03-10 06:28] Upgraded bmenu (0.4.2-3 -> 0.4.3-1)
[2016-03-10 06:28] Upgraded firefox-gtk2 (44.0.2-1 -> 45.0-1)
[2016-03-10 06:28] Upgraded imagemagick (6.9.3.0-1 -> 6.9.3.7-1)
[2016-03-10 06:28] Upgraded linux45-ndiswrapper (1.59-0.5 -> 1.59-0.6)
[2016-03-10 06:28] Upgraded linux45-nvidia (1:352.79-0.5 -> 1:352.79-0.6)
[2016-03-10 06:28] Upgraded linux45-r8168 (8.040.00-0.5 -> 8.040.00-0.6)
Robert Collard Madison, WI
Lenova K450e  8GB RAM
ManjaroLinux 15.12 Capella
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #40 on: 11. March 2016, 07:28:07 »
@Jonathon: that is the dilemma. Archs newer dkms package simply doesn't build the spl/zfs modules. Since Arch doesn't ship them, they don't care. Quick fix would be to drop spl/zfs. You can check also https://github.com/manjaro/packages-extra/issues/57
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #41 on: 11. March 2016, 09:18:04 »
Kernel 4.4.5 without problems.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline d7rk
  • Held Mitglied
  • Branch: testing
  • Desktop: Gnome // Openbox
  • GPU Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller and NVIDIA GF119M [GeForce 610M]
  • GPU driver: nvidia
  • Kernel: 4.4.8-1-MANJARO x86_64 (64 bit)
  • Skill: Novice
« Reply #42 on: 12. March 2016, 09:58:11 »
A little issue has been troubling me for a few updates. With kernel 4.4, I have a loading of the kernel modules failing: Microcode (intel) does not start with systemd.
I suspect it might be the reason with suspend doesn't work (although it might be utter bollo***).
Code: [Select]
   Loaded: loaded (/usr/lib/systemd/system/systemd-modules-load.service; static; vendor preset: disabled)
   Active: failed (Result: exit-code) since Sat 2016-03-12 06:43:09 GMT; 2h 4min ago
  Process: 218 ExecStart=/usr/lib/systemd/systemd-modules-load (code=exited, status=1/FAILURE)
 Main PID: 218 (code=exited, status=1/FAILURE)
Code: [Select]
systemd-modules-load[218]: Failed to find module 'microcode'
Code: [Select]
ls /etc/modules-load.d/
linux318-virtualbox-host-modules.conf  linux44-virtualbox-host-modules.conf  microcode.conf  modules.conf~
linux41-virtualbox-host-modules.conf   mhwd-gpu.conf                         modules.conf    thermald.conf
I don't have this problem with other LTS kernels 4.1 and 3.18, but with those kernels the internet connection (wifi) sometimes plateaus at 20 ko/s.
Code: [Select]
System:    Host: XXX Kernel: 4.4.5-1-MANJARO x86_64 (64 bit) Desktop: Openbox 3.6.1
           Distro: ManjaroLinux 15.12 Capella
Machine:   System: ASUSTeK (portable) product: U36SG XXX: 1.0
           Mobo: ASUSTeK model: U36SG v: 1.0 Bios: American Megatrends XXX: U36SG.202 date: 10/19/2011
CPU:       Dual core Intel Core i3-2350M (-HT-MCP-) cache: 3072 KB
           clock speeds: max: 2300 MHz 1: 1016 MHz 2: 962 MHz 3: 1047 MHz 4: 996 MHz
Graphics:  Card-1: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
           Card-2: NVIDIA GF119M [GeForce 610M]
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1366x768@59.37hz
           GLX Renderer: Mesa DRI Intel Sandybridge Mobile GLX Version: 3.0 Mesa 11.1.2
Audio:     Card Intel 6 Series/C200 Series Family High Definition Audio Controller driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.4.5-1-MANJARO
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express) driver: ath9k
           IF: wlp3s0 state: up mac: 74:2f:68:c4:b3:36
           Card-2: Qualcomm Atheros AR8151 v2.0 Gigabit Ethernet driver: atl1c
           IF: enp5s0 state: down mac: c8:60:00:1c:fc:8b
Drives:    HDD Total Size: 500.1GB (72.8% used) ID-1: /dev/sda model: ST9500423AS size: 500.1GB
Partition: ID-1: / size: 146G used: 134G (97%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 4.19GB used: 0.00GB (0%) fs: swap dev: /dev/sda4
Sensors:   System Temperatures: cpu: 49.0C mobo: N/A
           Fan Speeds (in rpm): cpu: 0
Info:      Processes: 174 Uptime: 2:12 Memory: 1800.9/7892.1MB Client: Shell (zsh) inxi: 2.2.35
Any idea?
Cheers,
