Author Topic: [Daniella] First preview release  (Read 9588 times)
Offline LAZA
  • Jr. Mitglied
  • I'm new (to Manjaro). Be nice!
  • Branch: testing
  • Desktop: Xfce
  • GPU Card: Radeon R7 260X
  • GPU driver: video-catalyst - 15.201.1151-0.6
  • Kernel: 4.6
  • Skill: Intermediate
Re: [Daniella] First preview release
« Reply #30 on: 09. March 2016, 22:35:07 »
Okay, here some though from me about Manjaro Xfce 16.06 pre1 installing in a VM:
VM:
- 1 SSD (64 GB) for /boot, / and Swap and 1 HDD (512 GB) for /home
Boot:
- booting normal Kernel without unfree packages
After some minutes (or seconds?) i get alerted about 1 update.
Installation:
- Bar with NTP on/off should be colored, after some back and forth i see the difference but a nice green would make it more intuitive
- manuell partitioning: searching for swap... (also a bit unintuitive)
- - would also be nice for Manjaro beginners to lighten up the best choice if mount point and size is choosen (different on SSD and HDD)  - just a wish!   :-X
- as password for user is "P@ssw0rd" still accepted (reasonable password), even it is a bit short an a slight modification of a dictionary word..
Installation itself works smooth and complete in German (y)
Reboot:
- without problems
Appearance:
- nice, intuitive Icons, a bit colored  (very good imho)
 - Adobe Flash Player is alert-red   ;D
- all other panel icons "pleasent reserved"
- background is not my color... a bit to dark or scattered or ...
Adjustment
- very nice, only the icons for "finetuning of windows" and "GTK+-Theme..." (purple, really?) could be less colorful
- Installation of Kernel 4.5-rc6 needed a long time to download but was finished successfull
- updated worked flawless
After rebooting to use Kernel 4.5 i got 6 more language updates --> flawless  (y)
A bit strange:
Starting LibreOffice all is in english (menu, side bar, ...) - so the german language file is not installed after this...   :-\
Then changed the mirrors to testing...
56 packages to update ---> flawless
Pamac:
The bars in the options are also grey/white - a bit of green would be helpful
I installed some games from community and AUR - all good.
Thanks for this great pre-release!
Frank
P.S.: "Widelands" seems to be a maintainer-less package...   :(
Dell X58 = Xeon W3680 @ 3.33 GHz + M391B5673FH0-CH9 - 12 GB @ 1.33 GHz
   - Asus R7260X-DC2OC-1GD5 DirectCU II OC
   - **/** = SP900 64 GB SSD + **/home** = ST3000VX000-1ES1 + **/pub** = 2x WD2003FYPS-2
   - Pioneer BDR-208D
   - Samsung S32D850T
Offline antoniovj1
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: Nvidia GeForce GT 240
  • GPU driver: non-free
  • Kernel: linux38-x64
  • Skill: Novice
« Reply #31 on: 10. March 2016, 14:36:44 »
Hi, I'm testing the new manajro release and I found two problems, that I also found in previous versions.
The first, the brightness keys doesn't work. I solved this by adding acpi_osi= at the line "GRUB_CMDLINE_LINUX_DEFAULT" at the file /etc/default/grub and then running update-grub.
The second problem that I also found in previous versions, is when I close the laptop lid, the laptop is not suspended ( I have set the suspend option in the "Power Settings"). I couldn't solve this, any help is welcome. ;D
Thanks!!! The preview looks pretty well.
I resolve  suspend problem by installing the 3.10 Kernel version and editing the file "/etc/systemd/logind.conf" with HandleLidSwitch=suspend. But is not a good solution  :'(
In other distro ( Antergos ) I can suspend the laptop normally ( but I like more Manjaro and I'm trying to find a solution ).
Offline Ham Radio
  • Vollwertiges Mitglied
    • EZ Computer Solutions
  • Branch: Stable
  • Desktop: KDE 5
  • GPU Card: nVidia GeForce 620
  • GPU driver: Non-Free
  • Kernel: Linux 4.1-x64
« Reply #32 on: 10. March 2016, 20:54:03 »
What branch is this based on? Stable, testing, or unstable?
Offline LordKravex
  • Neuling
    • Knight Technologies LLC
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: ATi Radeon 7700HD
  • Kernel: 4.4.5-1-x64
  • Skill: Advanced
« Reply #33 on: 11. March 2016, 21:12:54 »
Love this preview release.
I have found one issue that I can replicate on three different machines:
When locking the screen for more than a few minutes, the display will not come back up with the login prompt. The computers continue to run (Num Lock, Caps Lock keys still work normally), the display will just not come back up.
The three machines I have tried are all 64-bit, one is a laptop (Dell Inspiron 3520), two are desktops (Compaq Presario SR5152NX and White Box)
Thanks for your hard work!
LordKravex
Offline Atsuri
  • Neuling
  • Long-time Arch veteran :)
    • Linux Blog
  • Branch: stable / testing
  • Desktop: XFCE / JWM
  • GPU Card: nVidia GeForce 9400M (laptop) / ATI Radeon Xpress 300 (desktop)
  • GPU driver: Mesa / nvidia
  • Kernel: linux 44-x64
  • Skill: Advanced
« Reply #34 on: 13. March 2016, 22:18:47 »
As far as I could tell, -dev versions are based on 'testing' or 'unstable' and this one is based on 'unstable'. For reference, check /etc/pacman-mirrors.conf :).
Downloaded 'Daniella' few days after it was released and changed repositories to 'testing' as I am not so daring to run 'unstable'. I always enjoyed the black-green rogue-ish theming combo (I'm a black-green deck Magic: The Gathering player!) and 'Daniella' really nails it. It has the right amount of gee-whiz, still very light on resources. Good selection of wallpapers as well.
So far I had zero problems and I'm constantly awe-struck how solid Arch-based distributions are :). Big thumbs up from me!
GNU/Linux will prevail! :)
Offline alxgvr
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: nVidia
  • Kernel: 4.4.2
« Reply #35 on: 15. March 2016, 11:53:57 »
I use iris-light theme and ultra flat icons. Great!
If you will change icons theme, please leave "power off, suspend, logout, restart" buttons.
They look amazing in current circle theme.
Offline tulliana
  • Core Team
  • Forever Manjaro
    • http://bilgegunluk.com
  • Branch: unstable - testing
  • Desktop: KDE5 Plasma
  • GPU Card: Nvidia GeForce GT 630M
  • GPU driver: free-nonfree
  • Kernel: Unstable
  • Skill: Advanced
« Reply #36 on: 16. March 2016, 08:24:17 »
Window decoration is not beautiful. Menda Window decoration is beautiful. Or we intend to use the breeze window decoration.
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #37 on: 16. March 2016, 11:12:28 »
Hi @tulliana , see this
https://github.com/manjaro/release-plan/issues/36   ;)
Stefano
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Ripo
  • Neuling
  • I'm new. Be nice!
    • Robertotolin.com
  • Branch: stable
  • Desktop: Manjaro XFCE
  • GPU Card: AMD RV630
  • GPU driver: free driver
  • Kernel: linux4.4-x64
« Reply #38 on: 16. March 2016, 18:01:28 »
LordKravex
Same here with a Samsung N150P. The scrren don't comes back.I have also problems with shutdown from the menu. It hangs. Shutdown from the terminal works.
MacPro 3.1 early 2008
2x Intel Xeon E5462 (8 cores)
Kingston 120 Gb SSD
8 Gb ram
Offline niyasc
  • Neuling
  • I'm new. Be nice!
  • Desktop: GNOME
« Reply #39 on: 17. March 2016, 20:32:41 »
Screen shot tour.
Hi,
I have published one screenshot tour of Manjaro 16.06 Preview 1.
http://www.open-source-feed.com/2016/03/manjaro-1606-preview-1-screenshot-tour.html
Offline Ham Radio
  • Branch: Stable
  • Desktop: KDE 5
« Reply #40 on: 17. March 2016, 21:35:33 »
I installed the KDE edition of this preview and it's been great! Thanks!
Offline marko94
  • Branch: Unstable
  • Desktop: Xfce 15.12-pre3 Capella
  • GPU Card: Intel HD Graphics 3000
  • GPU driver: Free
  • Kernel: 4.4.0-1
  • Skill: Novice
« Reply #41 on: 20. March 2016, 00:54:58 »
Is it stable ? I mean for daily usage ? :) thx
Offline Ham Radio
  • Branch: Stable
  • Desktop: KDE 5
« Reply #42 on: 20. March 2016, 01:14:36 »
Yes, the changes are just to the theme, and installation program. The ISO itself is based on the stable repo's.
Offline Salinko
  • Held Mitglied
  • Branch: manjaro-xfce-16.06-pre1-x86_64 (unstable)
  • Desktop: Xfce 4.12.3
  • GPU Card: Gigabyte HD7870 GHz Edition
  • GPU driver: radeon free
  • Kernel: 4.5.0-2-MANJARO x86_64
  • Skill: Novice
« Reply #43 on: 21. March 2016, 13:16:01 »
Unfortunately the bluetooth update today has broken something, at least on testing. When trying to connect a headset I get an initial connection then the whole stack goes tits-up.
Journalctl:
Code: [Select]
Mar 21 21:46:59 beano systemd[1]: bluetooth.service: Main process exited, code=dumped, status=11/SEGV
Mar 21 21:46:59 beano systemd[1]: bluetooth.service: Unit entered failed state.
Mar 21 21:46:59 beano systemd[1]: bluetooth.service: Failed with result 'core-dump'.
Mar 21 21:46:59 beano kernel: Bluetooth: hci0 SCO packet for unknown connection handle 4102
Mar 21 21:46:59 beano systemd-coredump[2556]: Process 2358 (bluetoothd) of user 0 dumped core.
                                              Stack trace of thread 2358:
                                              #0  0x000000000042467e n/a (bluetoothd)
                                              #1  0x0000000000420fb9 n/a (bluetoothd)
                                              #2  0x00007f7fc4d7dc3a g_main_context_dispatch (libglib-2.0.so.0)
                                              #3  0x00007f7fc4d7dfe0 n/a (libglib-2.0.so.0)
                                              #4  0x00007f7fc4d7e302 g_main_loop_run (libglib-2.0.so.0)
                                              #5  0x000000000040ba48 n/a (bluetoothd)
                                              #6  0x00007f7fc4344710 __libc_start_main (libc.so.6)
                                              #7  0x000000000040c1c9 n/a (bluetoothd)
dmesg:
Code: [Select]
[  453.158463] Bluetooth: hci0 SCO packet for unknown connection handle 4102
[  453.158467] Bluetooth: hci0 SCO packet for unknown connection handle 4102
[  453.168379] Bluetooth: hci0 SCO packet for unknown connection handle 4102
[  453.168397] Bluetooth: hci0 SCO packet for unknown connection handle 4102
Offline eemponet
  • Neuling
  • lulz
  • Skill: Novice
« Reply #44 on: 25. March 2016, 01:24:38 »
same here... i believe after the upgrades it didnt happened anymore.
