Author Topic: Applications for the next release?  (Read 6475 times)
Offline scachemaille
  • Held Mitglied
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU Card: nVidia GT 330M
  • GPU driver: Nouveau
  • Kernel: 4.8_x64
  • Skill: Intermediate
Re: Applications for the next release?
« Reply #60 on: 23. April 2016, 17:48:44 »
demand a qt5 version from hp :P
See not everyone has a hp printer, I do not think it should be added by default if it is the only reason for qt4 to be added. And you can always install it yourself. The driver only version without the gui, do you think you can use system printer settings instead to setup your printer?
I guess it talk about to install it by default, as it's not soon qt4 will be removed from repos, as there is a lot of application who still depend on it like as simplescreenrecorder, vlc, skype and other application
« Last Edit: 23. April 2016, 17:56:15 by scachemaille »
Offline torvic9
  • Sr. Mitglied
  • Hello world!
  • Branch: stable
« Reply #61 on: 25. April 2016, 11:50:26 »
I'll be switching to firefox when it becomes fully gtk3. Should not take long anymore, but probably not in this release. Unless I learn how to force uninstall packages from the iso chroot. Then I would totslly do firefox.
I thought Firefox is fully gtk3 already? At least starting from version 46, e.g. the one I prepared for you.
i3: i7-5820K | 32 GB | GeForce GTX 960, nvidia | linux44-custom
KDE: i7-920 | 12 GB | GeForce GTS 450, nouveau | linux44
Gnome: Thinkpad X200s | linux41
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Kernel: linux44-x64
« Reply #62 on: 25. April 2016, 12:24:17 »
Imho it should be. However, we are using the arvh upstream package in the repos: https://www.archlinux.org/packages/extra/x86_64/firefox/
When 46 hits repos, I hope it is gtk3 only, because it really works just fine without gtk2. Even 45 version.
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #63 on: 28. April 2016, 11:54:31 »
I think I'll setup an online repo myself so I can include firefox-gtk3. I figured I can probably use dropbox for that.
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #64 on: 02. May 2016, 13:46:07 »
Ok, I found something even better: lightforefox in aur. It is stripped down firefox. It even has chromium style omnibar, just the way I like it. I made a gtk3 version of it and uploaded it to dropbox. Also found out how to host repos in dropbox, so I should get out the next release this week if everything goes well.
Offline torvic9
  • Sr. Mitglied
  • Hello world!
  • Branch: stable
« Reply #65 on: 03. May 2016, 10:36:02 »
... Also found out how to host repos in dropbox ...
Can you elaborate please? I'm looking to setup a repo, too.
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #66 on: 03. May 2016, 11:01:17 »
I haven't tested it yet, but based on research it seems really simple.
1) create a local repo
2) put it in your Public dropbox folder
Done. Online repo is set up. To use it
3) get address of repo by right clicking one of the files in repo and choosing 'get a public link'. Replace the filename in the end of that address with '$arch'.
Source: https://bbs.archlinux.org/viewtopic.php?id=169037
Offline torvic9
  • Sr. Mitglied
  • Hello world!
  • Branch: stable
« Reply #67 on: 03. May 2016, 11:12:08 »
Sounds good, thanks!
Unforunately I'm limited to 80 kbyte/s upload speed...
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #68 on: 03. May 2016, 11:22:49 »
I hear some people also use google drive for that, if the limitation is due to dropbox.
Offline torvic9
  • Sr. Mitglied
  • Hello world!
  • Branch: stable
« Reply #69 on: 03. May 2016, 20:45:09 »
I can't get it to work with Dropbox. Maybe it's because the Public folder only works with Dropbox Pro?
Offline flippy
  • Vollwertiges Mitglied
  • AKA "day|flip" manjaro irc
  • Branch: Testing
  • Desktop: xmonad & bspwm
  • GPU Card: nVidia GeForce GTX 550 Ti
  • GPU driver: Nvida
  • Kernel: Got 64?
« Reply #70 on: 07. May 2016, 04:35:41 »
You could replace gedit with journal. It a lightweight gtk3 text editor. It look a little bit like gedit. I just don't know how much they are a like. But it just a idea if like to try it out.
https://aur.archlinux.org/packages/journal/
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #71 on: 07. May 2016, 06:35:04 »
Thanks, I'll check it.
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #72 on: 08. May 2016, 19:55:49 »
I could not get it to build from aur (even after fixing the parts that should have been arrays). Also, vala dependency seems rather big. I'll check it again later. However, I'll probably use gedit for this release.
Offline flippy
  • Branch: Testing
  • GPU driver: Nvida
  • Kernel: Got 64?
« Reply #73 on: 08. May 2016, 20:57:24 »
I had issue with the aur build to. So I just build it from source.
