Author Topic: [How to] get Manjaro Cinnamon default desktop settings  (Read 3177 times)
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • Desktop: i3, Deepin, Cinnamon
  • GPU Card: Intel ValleyView Gen7
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
  • Skill: Intermediate
« on: 24. February 2016, 13:07:12 »
If you either have messed up your configuration and you would like to return to the default ::) O:-)
or
you have an older install of Cinnamon, or your own build of some kind
and
you would like to adopt the desktop settings of the latest Manjaro Cinnamon desktop ^-^:
This is the clean way to do it:
1. run
Code: [Select]
sudo rm -rf /etc/skel
2. install
Code: [Select]
sudo pacman -S manjaro-cinnamon-settings. The latest version 20160226-0.1 already pulls in all necessary dependencies, so you don't have to worry about any other packages... Also it installs a little script that you will need later.
The rest of the procedure you have to write down on a piece of paper ;) if you don't have a second computer open with this page available or ... good memory: 8)
3. logout of your Cinnamon session
4. Press Ctrl+Alt+F2 (or another F-key except F7) to switch to a console screen and there you login as the user that you want to reset the settings for (!) (do not login as root!)
5. run
Code: [Select]
cd .config/dconf
mv user user.bak
reset-gsettings
_DONE_
Now you can return to the graphical tty with Ctrl+Alt+F7 and log back in to your Cinnamon session and your desktop should look exactly like a brandnew manjaro ISO >:D
Good luck!
« Last Edit: 26. February 2016, 01:03:10 by oberon »
manjaro is addictive ::)
* manjaro-i3  * manjaro-cinnamon  * manjaro-deepin
Offline Uncle Spellbinder
  • Vollwertiges Mitglied
  • IPA!
    • Hallucination Layer
  • Branch: Testing
  • Desktop: KDE
  • GPU Card: AMD Kaveri Quad-Core A10-7800 Radeon R7 Series
  • GPU driver: Non-Free
  • Kernel: x86_64 Linux 4.1.19-1-MANJARO
Re: [How to] get Manjaro Cinnamon default desktop settings
« Reply #1 on: 25. February 2016, 23:38:29 »
or
and
1. run
Code: [Select]
2. install
Code: [Select]
sudo pacman -S manjaro-cinnamon-settings(the latest version 20160223-1 already pulls in all necessary dependencies, so you don't have to worry about any other packages...)
3. create a little script (will be included in the above mentioned package in the near future)
  3.a
Code: [Select]
sudo nano /usr/local/bin/default-gsettings
  3.b paste in this code:
Code: [Select]
#!/bin/bash
for i in $(gsettings list-schemas | grep cinnamon)
do
        gsettings reset-recursively $i
done
  3.c press Ctrl+o, followed by <Enter>, followed by Ctrl+x to save the script and to exit the editor
  3.d make the script executable with
Code: [Select]
sudo chmod +x /usr/local/bin/default-gsettings
The rest of the procedure you have to write down on a piece of paper ;) if you don't have a second computer open with this page available or good memory: 8)
4. logout of your Cinnamon session
5. Press Ctrl+Alt+F2 (or another F-key except F7) to switch to a console screen and there you login as the user that you want to reset the settings for (!) (do not login as root!)
6. run
Code: [Select]
cd .config/dconf
mv user user.bak
default-gsettings
_DONE_
Good luck!
Code: [Select]
[unclespellbinder@manjarocinnamon ~]$ sudo rm -rf /etc/skel
[sudo] password for unclespellbinder:
[unclespellbinder@manjarocinnamon ~]$ sudo pacman -S manjaro-cinnamon-settings
resolving dependencies...
Packages (3) artwork-cinnamon-minimal-20160223-1  vertex-maia-themes-20160212-1
             manjaro-cinnamon-settings-20160224-0.1
Total Download Size:   1.37 MiB
Total Installed Size:  6.67 MiB
:: Retrieving packages ...
 artwork-cinnamon-mi...   698.6 KiB  1354K/s 00:01 [######################] 100%
 vertex-maia-themes-...   697.9 KiB  3.46M/s 00:00 [######################] 100%
 manjaro-cinnamon-se...    11.4 KiB  3.71M/s 00:00 [######################] 100%
(3/3) checking keys in keyring                     [######################] 100%
(3/3) checking package integrity                   [######################] 100%
(3/3) loading package files                        [######################] 100%
(3/3) checking for file conflicts                  [######################] 100%
error: failed to commit transaction (conflicting files)
artwork-cinnamon-minimal: /usr/share/icons/manjaro-cinnamon.png exists in filesystem
Suggestions?
“Without deviation from the norm, progress is not possible.” -  Frank Zappa
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #2 on: 25. February 2016, 23:46:54 »
remove the conflicting file /usr/share/icons/manjaro-cinnamon.png and install the package again
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
  • IPA!
  • Branch: Testing
  • Desktop: KDE
« Reply #3 on: 25. February 2016, 23:56:11 »
I thought it might be that simple. THANKS for confirming.
Worked like a charm!
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #4 on: 26. February 2016, 00:53:59 »
Ok. Meanwhile I have simplified that.
The updated package manjaro-cinnamon-settings 20160226-0.2 now pulls in the script, too, and you can simply call it with
Code: [Select]
reset-gsettings
It also contains three additional lines that I figured out to reset the settings of gnome-terminal >:D
Code: [Select]
default_profile=$(gsettings get org.gnome.Terminal.ProfilesList default)
profile=${default_profile:1:-1}
gsettings reset-recursively "org.gnome.Terminal.Legacy.Profile:/org/gnome/terminal/legacy/profiles:/:$profile/"
Just remember to logout of the session first and then rm ~/dconf/user before you run reset-gsettings !!
I'll modify the original post accordingly.
« Last Edit: 26. February 2016, 01:11:10 by oberon »
Offline oberon
  • Core Team
  • I'm nice. Be new!
  • Branch: unstable
  • GPU driver: Intel
  • Kernel: 4.1 / 4.4
« Reply #5 on: 26. February 2016, 01:05:27 »
I've also renamed that icon so it won't conflict with the old one in the future. :)
