Author Topic: Encryption password no longer works after update  (Read 2672 times)
bossriger
  • Guest
Re: Encryption password no longer works after update
« Reply #15 on: 15. March 2016, 19:21:06 »
I wrote this in the thread several times, but you didn't read to the end, no wonder the thread is long.
The Arch Wiki would have been a more reliable source of information.
You can try again with the mount commands and it should probably work.
Thank you for your help. I appreciated it. I went back and did all this, including updating linux kernel. Like I said...
Code: [Select]
su
lsblk -f
cryptsetup open --type luks /dev/sda2 root
lsblk -f
mount -t ext4 /dev/mapper/ManjaroVG-ManjaroRoot /mnt
chroot /mnt /bin/bash
exit
mount /dev/sda1 /mnt/boot
mount --bind /dev /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
mount --bind /proc /mnt/proc
mount --bind /sys /mnt/sys
pacman -Syy
pacman -S cryptsetup
pacman -S linux45
This does not fix the issue. I feel I'm left with no option but to dump Manjaro and stop recommending it; that makes it a sad day.  :(
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #16 on: 15. March 2016, 19:36:46 »
Wow 4 posts and 2 hrs
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
  • Skill: Intermediate
« Reply #17 on: 15. March 2016, 19:45:22 »
You need to issue the mount commands before the chroot command!
Yeah it can be tricky sometimes with Manjaro, but not exclusively.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #18 on: 15. March 2016, 20:01:35 »
Yeah, could be a troll, especially considering the last words. ;) :P
