Author Topic: Octopi feature request  (Read 709 times)
Offline minMax3
  • Neuling
  • Desktop: KDE
  • GPU Card: Nvidia GF119
  • GPU driver: Non Free
  • Skill: Intermediate
« on: 22. February 2016, 06:47:36 »
Recently I use Manjaro-System gui tool to remove kernel 4.1 and install kernel 4.3 as a backup (currently using kernel 4.4).
I did that because my hard disk is encrypted. I read a forum post where users of the 4.1 kernel with encrypted hard disks experienced problem booting.
I had already switched to kernel 4.4 and had kernel 4.1 as a backup kernel.
Manjaro-System informed that the new kernel was installed. I rebooted and checked to see if kernel 4.3 was present in the grub menu. The only entry was for kernel 4.4.
Then I used "sudo mhwd-kernel -i linux43" And I saw a message about perhaps removing the db lock in /var/lib/pacman.
There was a db.lock (might not be the exact name - writing from memory). I deleted that, and with "sudo mhwd-kernel -i linux43" the new kernel was installed. Checked its presence in the grub menu and it was listed.
My wish/suggestion perhaps to have Octopi check for the presence of this db.lock and let us know, perhaps showing a padlock icon.
...just a suggestion.
[Edit]...Issue posted on Github: https://github.com/aarnt/octopi/issues/154
« Last Edit: 22. February 2016, 15:42:07 by minMax3 »
