Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
138 (73%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
11 (5.8%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
40 (21.2%)
Total Members Voted: 189
Author Topic: [Update] 2016-02-21 - Kernels, KDE, Pamac, Firefox, Thunderbird, Lumina, Intel  (Read 24745 times)
Offline Max
  • Neuling
  • Skill: Novice
Just an info:
Experiencing a minor bug with font Cantarell
Ü and ü seem to have zero width and the following character overlaps
I guess the next update will take care of it...
https://bugzilla.gnome.org/show_bug.cgi?id=762386
The most interesting information comes from children, for they tell all they know and then stop. (Mark Twain, 1835-1910)
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Desktop: KDE Plasma Version 5.6.3
  • GPU Card: Intel Quad Core i7-4790K - NVIDIA GeForce GTX 745
  • GPU driver: non-free
  • Kernel: 4.4.9-1 Manjaro
  • Skill: Novice
I think in your case it should be
Code: [Select]
# cryptsetup open --type luks /dev/sda2 rootfor  # cryptsetup open --type luks /dev/<partition name> <device-mapper name>
I typed as you mentioned, but it simply goes to [manjaro@manjaro `]$
What do I do after that?
@ AJSly,
You have come to my resue several times in the past few years, and I'm geratful to your help and everyone else involved. Could you tell me what is the commandd that I need to type. the luks key is set on /dev/sda2 by defualt when you use the installer to encrypt the hard drive during the initial installation. I have successfully been able to change the encryption key by this command:
sudo cryptsetup luksAddKey /dev/sda2
Or, sudo cryptsetup luksRemoveKey /dev/sda2
I can only get to a terminal using the Manjaro 15.12 usb stick.
Could you tell me what do I need to type to delete the luks key. I'm following the installation with no success.
« Last Edit: 21. February 2016, 21:13:00 by fredhoud »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
@fredhoud: seems you need a one-on-one session with us. Join the #manjaro IRC channel on freenode.net and talk to us. Simply ping me and I help you out.
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Skill: Novice
Thank you philm. I'm on it as we're speaking, but I don't see any response.
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
@fredhoud: what is your nick there? As I'm in the channel. Simply ping phil_m.
Offline fredhoud
  • Sr. Mitglied
  • King of Liunx!
  • Branch: Stable
  • Skill: Novice
I'm just using fredhoud.
Offline ata
  • Neuling
  • I'm new. Be nice!
  • Desktop: xfce
  • GPU Card: amd/ati
  • Kernel: 41
  • Skill: Novice
After update information in the font issue
4.1.8-1-lts -ARCH & Manjaro Xfce RedWhite 15.12
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
@fredhoud: you're sure that you're in the channel?
1) http://webchat.freenode.net/
2) nickname: fredhoud
3) channel: #manjaro
4) check the no-robot checkbox
5) click on connect
6) write ping phil_m
Offline Ya Qiao
  • Jr. Mitglied
  • I live in Asia
    • Qiao Now
  • Branch: stable
  • Desktop: openbox
  • Kernel: 38-64 15
  • Skill: Intermediate
Multiple machines (64 and 32 bit): no KDE, no encryption= no problems.
Thank you for all your hard work, Manjaro Team
我住在亞洲
Offline heyne001
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
Hi! New to the forums - took me about 10 or something tries to register here (that captcha is unreal :S).
I use encryption. Before the update I edited the /etc/pacman.conf file and added "linux" after the IgnorePkg (IgnorePkg   = linux). Because I knew if my kernel gets updated to 4.1.18, I'm fucked (had this issue on Antergos - lts kernel update).
As I understand 4.1.17 isn't supported anymore. My question is, what should I do now? is it okay if I remove the kernel from the ignore list of pacman and let it to update itself? is the bug fixed now?
Essentially I don't want to have regular kernel updates - i just want to have a fairly recent kernel that works and is supported for quite a while and just stick with it. i also don't want to have the newest kernel, cause that one broke my wifi. Had an interesting situation on Antergos - couldn't use the 4.4.2. kernel, cause that broke my wifi and couln't use the lts kernel (.18), cause that broke my cryptsetup.
Some background:
Code: [Select]
$ uname -r
4.1.17-1-MANJARO
Code: [Select]
$ lsb_release -a
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 15.12
Codename: Capella
Code: [Select]
$ cryptsetup --version
cryptsetup 1.7.0
* sidenote, geesus christ dudes - why all the hurdles to just register and post on this forum - first, third and whatever letters of manjaro. why?? :SS
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
Hello and welcome, heyne001!
The hurdle to register prevent us from spammers.
Good that you took measures before the update!
You need now a newer version of cryptsetup which resolves the issue:
Code: [Select]
sudo pacman -U http://repo.manjaro.org.uk/pool/overlay/cryptsetup-1.7.0-1.1-$(uname -m).pkg.tar.xzThen you should be able to update the kernel.
PS: You can also install kernel 4.4 which isn't affected by the issue.
« Last Edit: 21. February 2016, 22:15:54 by eugen-b »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Aldhelm
  • Neuling
  • Branch: Stable
  • Desktop: KDE, i3
  • GPU Card: Mesa DRI Intel(R) Ivybridge Mobile
  • Kernel: 4.2.1-1
Everything went great on three machines. Thanks Phil and team!
And thanks for all your help and dedication to the project. I really appreciate it. The forums and wikis are very useful.  :D
Offline boletus
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Xfce+Compiz
  • GPU Card: ATi
  • GPU driver: free
  • Kernel: linux4.4-x64
No issues here, thanks
Offline neil1969
  • Neuling
  • Branch: All
  • Desktop: XFCE 4.12
  • GPU Card: Intel Ivybridge Mobile / AMD R7 250X
  • GPU driver: Free / Non-Free
  • Kernel: Linux44-x64 / Linux 44-x64
Everything went great for me.  I made the jump to all SSD for OS drives with built in device enabled encryption, specifically to avoid the performance hit and to avoid any issues created by LUKS.  I tend to use truecrypt containers for data I want to safeguard, but outside of my home folder which is on the primary OS drive I only really have to use this for protecting backup images.
Offline mgundogdu
  • Vollwertiges Mitglied
  • Learn and share and be nice with that!
  • Branch: Unstable
  • Desktop: Xfce
  • GPU Card: AMD/ATI RV710/M92
  • GPU driver: ATİ
  • Kernel: linux44-x64
  • Skill: Novice
Thanks team Great smoth update I just have @ata and @Max mentioned above some canterall charecter issues.
Open knowledge is what open data becomes when it’s useful, usable and used.
https://okfn.org/opendata/
