Author Topic: [Solved]Manjaro fluxbox power indicator problem  (Read 896 times)
Offline ihtiyar
  • Neuling
  • Branch: stable
  • Desktop: XFCE
  • GPU Card: ATI X1600
  • GPU driver: Mesa
  • Kernel: 3.16.7.6.1
  • Skill: Intermediate
« on: 18. February 2016, 11:58:51 »
Hi,
After last update(2016-02-13) a power indicator applet appears on panel with the notification window.
This is a desktop computer.
The problem is,the window never close and open a new one till filling the whole workspace.
Thanks for help.
« Last Edit: 18. February 2016, 14:05:47 by ihtiyar »
Offline wordler
  • Vollwertiges Mitglied
  • I can wire a plug
  • Branch: Stable
  • Desktop: Fluxbox & Xfce
  • GPU Card: Nvidia GT720 1gb ddr5
  • GPU driver: non-free
  • Kernel: linux4.4-x64
  • Skill: Novice
Re: Manjaro fluxbox power indicator problem
« Reply #1 on: 18. February 2016, 13:22:41 »
Hi.
Go to the .fluxbox folder inside your home folder. Inside there is a startup file. Open this with a text editor. There is a list of applications to startup when you login. One of these is call cbatticon. If you place a # then a space before cbatticon then it will not load at startup. I think this should solve your problem.
Fear is the mind killer.
Offline ihtiyar
  • Neuling
  • Branch: stable
  • Desktop: XFCE
  • GPU driver: Mesa
« Reply #2 on: 18. February 2016, 14:04:45 »
Thank you @wordler,problem solved.
