Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
116 (91.3%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
6 (4.7%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
5 (3.9%)
Total Members Voted: 127
Author Topic: [Update] 2016-02-09 - Kernels, Pamac 3.0, Pacman 5.0, Calamares, Manjaro-Tools  (Read 5385 times)
Offline Shadow Warrior
  • Mirror Support Team
  • Branch: Testing
  • Desktop: openbox from first ever version
  • GPU Card: Advanced Micro Devices [AMD/ATI] Wrestler [Radeon HD 6250]
  • GPU driver: non free
  • Kernel: Linux manjaro 4.4.8-1-MANJARO i686
  • Skill: Novice
Bit late  after recent update... but for some reason whenever i open a terminal i get Tint2 crashing and wont restart (Segfault core dumped)  if i have browser open and i reduce screen i can still hear anything like you tube..but cat get it back unless i restart comp...
Code: [Select]
xRandr: Found crtc's: 1
xRandr: Linking output LVDS with crtc 0
No XSETTINGS manager, tint2 uses config option 'launcher_icon_theme'.
real transparency on... depth: 32
panel items: TSB
Systray composited rendering on
found mains "ACAD"
found battery "BAT1"
tint2 : nb monitor 1, nb monitor used 1, nb desktop 4
Segmentation fault (core dumped)
Code: [Select]
Feb 12 16:43:25 manjaro kernel: [  786.592943] tint2[2025]: segfault at b5f72430 ip b71da75f sp bfe6b98c error 4 in libImlib2.so.1.4.7[b7192000+5d000]
any ideas ?????
Offline omnimoon
  • Neuling
  • Former distrohopper
  • Branch: stable
  • Desktop: KDE / Xfce
  • GPU Card: Nvidia GeForce 940M / ATI Radeon HD 6310
  • GPU driver: non-free
  • Kernel: linux44-x64 / linux43-x64
  • Skill: Novice
Yes, I see nothing wrong too. You can always try with other kernels if nothing else work.
Sorry, my skills here are much worse. I don't use encrypt.
Maybe if you start a new topic, others (with better skills) may help.
So good luck and cheers.
Will do, thanks a lot for all of your assistance!
Cheers
Offline Duramin
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • GPU Card: nvidia
  • Skill: Advanced
Cheers
Perhaps your problem is solved?
Try this: update cryptsetup to version 1.7.0-1.1. After it appears in the repository or try
Code: [Select]
sudo pacman -U http://repo.manjaro.org.uk/pool/overlay/cryptsetup-1.7.0-1.1-$(uname -m).pkg.tar.xzNow rebuild your wanted kernel
Code: [Select]
sudo mkinitcpio -p linux316Then reboot.
For more information see this thread please:
https://forum.manjaro.org/index.php?topic=31031.0
Hope it helps.
