Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
116 (91.3%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
6 (4.7%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
5 (3.9%)
Total Members Voted: 127
Author Topic: [Update] 2016-02-09 - Kernels, Pamac 3.0, Pacman 5.0, Calamares, Manjaro-Tools  (Read 6195 times)
Offline lunareth
  • Neuling
  • Branch: stable
  • Desktop: KDE
  • GPU Card: nVidia 9800GT
  • GPU driver: non-free
  • Kernel: 3.16
  • Skill: Novice
Everything works fine for me :D.
Offline boletus
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Xfce+Compiz
  • GPU Card: ATi
  • GPU driver: free
  • Kernel: linux4.4-x64
  • Skill: Intermediate
No problem on my machines.
Offline adreampuppet
  • Neuling
  • Branch: Stable, Testing
  • Desktop: XFCE & KDE stable, Cinnamon & LXDE (2) testing
  • GPU Card: AMD Kaveri (Radeon R6 Graphics)
  • GPU driver: free (on testing) & non-free (stable, to run Steam)
  • Kernel: linux318, linux41 & linux 44
  • Skill: Novice
Two laptops -- two XFCE stable installs, two KDE stable installs -- all is well after two days' usage.  Just amazing how Manjaro keeps chuggin' along....
"Anxiety is the dizziness of freedom." Kierkegaard
Offline joshuadunamis
  • Vollwertiges Mitglied
  • Finally on the Arch Linux world with Manjaro KDE
  • Branch: stable
  • Desktop: Plasma 5.6.3
  • GPU Card: Intel HD Graphics 4000
  • GPU driver: free
  • Kernel: Kernel: 4.4.8-1-MANJARO x86_64
Well... Another very smooth update!!!
Since nearly 2003 to today I never installed anyelse than GNU/Linux OS...
 My actual OS: Manjaro Linux 15.12 KDE (Capella) on Asus X551CA-SX024D
Italian IRC channel on Freenode: #manjaro-it
Offline kmartin
  • Branch: stable
  • Desktop: Xfce 4.12.3
  • GPU Card: Intel Xeon E3-1200 v3/4th Gen Core Processor Integrated Graphics Controller
  • GPU driver: video-intel 2013.01.12 true PCI
  • Kernel: 4.2.8-4.1-MANJARO x86_64
  • Skill: Novice
Thanks once again Development Team, perfect. ;D
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
After updating got this on next boot, after GRUB menu: "ERROR: Unable to find root device 'UUID=xxxxxx'. You are being dropped to a recovery shell. Type 'exit' to try and continue booting", and there's no keyboard input at all in the resulting command line.
My root and partitions are both encrypted, but I get access to them both from a live session. Thanks in advance for your help!
Hmm, that is not good. Can you post me your current partition layout with sudo parted -l && sudo blkid plus the content of your current /boot/grub/grub.cfg.
Offline Kelaun
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Gnome
  • GPU Card: nVidia GTX 730m
  • GPU driver: Non-free
  • Kernel: 4.5.3-1-MANJARO x86_64
I have a minor issue where, every time I reboot, my keyboard layout is reset to qwerty. When X is started the layout is set to azerty.
This is easily solved by: localectl set-keymap --no-convert <keymap>
Kelaun
Offline ruziel
  • Held Mitglied
  • Those who know, laugh.
    • Coffee & Manjaro
  • Branch: Stable
  • Desktop: Xfce
  • Kernel: 4.4 / 4.9
  • Skill: Novice
The usual super-smooth update on my machine. Thanks to Phil, team & everyone who contributed to this latest release.
Manjaro just gets better & better.
Much appreciated!!!
Ruziel  ;)
"There is no complete theory of anything." (Robert Anton Wilson)
Offline AndrésGabriel
  • Neuling
  • I'm new. Be nice!
  • Branch: stable
  • Desktop: XFCE4
  • GPU Card: Nvidia GTX330m
  • Kernel: x86_64 Linux 4.1.15-1-MANJARO
Everything okay least these two updates
Offline omnimoon
  • Neuling
  • Former distrohopper
  • Branch: stable
  • Desktop: KDE / Xfce
  • GPU Card: Nvidia GeForce 940M / ATI Radeon HD 6310
  • Kernel: linux44-x64 / linux43-x64
  • Skill: Novice
Thanks, Philm. Here are the results:
Code: [Select]
Model: ATA TOSHIBA MK5075GS (scsi)
Disk /dev/sda: 500GB
Partition Table: msdos
Disk Flags:
Numero  Inicio  Fin     Tamaño  Typo      Sistema de ficheros  Banderas
 1      1049kB  268MB   267MB   primary   ext2                 arranque
 2      268MB   31,7GB  31,5GB  primary
 3      31,7GB  497GB   466GB   primary
 4      497GB   500GB   2740MB  extended                       lba
 5      497GB   500GB   2739MB  logical   linux-swap(v1)
Model: TSSTcorp CDDVDW TS-L633F (scsi)
Disk /dev/sr0: 1946MB
Sector size (logical/physical): 2048B/2048B
Disk Flags:
 2      451kB   130MB  130MB   primary                       esp
/dev/sr0: UUID="2015-12-22-16-57-08-00" LABEL="MJRO1512" TYPE="iso9660" PTUUID="70f56db4" PTTYPE="dos"
/dev/sda1: LABEL="ManjaroBoot" UUID="ada875ef-93fd-4950-944a-4d5c1733f72a" TYPE="ext2" PARTUUID="4ac358c1-01"
/dev/sda2: UUID="b2b8e393-201c-4fc1-9d28-0b604302fca3" TYPE="crypto_LUKS" PARTUUID="4ac358c1-02"
/dev/sda3: UUID="aaa44172-e9fd-477d-a402-7c3b8a12d569" TYPE="crypto_LUKS" PARTUUID="4ac358c1-03"
/dev/sda5: LABEL="ManjaroSwap" UUID="2e5bccd5-928b-41be-b755-0ad7689610f5" TYPE="swap" PARTUUID="4ac358c1-05"
/dev/loop0: TYPE="squashfs"
/dev/loop1: TYPE="squashfs"
/dev/loop2: TYPE="squashfs"
/dev/loop3: TYPE="squashfs"
And the content of grub.cfg:
Code: [Select]
### BEGIN /etc/grub.d/00_header ###
insmod part_gpt
insmod part_msdos
if [ -s $prefix/grubenv ]; then
  load_env
fi
if [ "${next_entry}" ] ; then
   set default="${next_entry}"
   set next_entry=
   save_env next_entry
   set boot_once=true
else
   set default="${saved_entry}"
fi
if [ x"${feature_menuentry_id}" = xy ]; then
  menuentry_id_option="--id"
else
  menuentry_id_option=""
fi
export menuentry_id_option
if [ "${prev_saved_entry}" ]; then
  set saved_entry="${prev_saved_entry}"
  save_env saved_entry
  set prev_saved_entry=
  save_env prev_saved_entry
  set boot_once=true
fi
function savedefault {
  if [ -z "${boot_once}" ]; then
    saved_entry="${chosen}"
  fi
function load_video {
  if [ x$feature_all_video_module = xy ]; then
    insmod all_video
  else
    insmod efi_gop
    insmod efi_uga
    insmod ieee1275_fb
    insmod vbe
    insmod vga
    insmod video_bochs
    insmod video_cirrus
  fi
set menu_color_normal=light-gray/black
set menu_color_highlight=green/black
if loadfont unicode ; then
  set gfxmode=auto
  load_video
  insmod gfxterm
  set locale_dir=$prefix/locale
  set lang=es_AR
  insmod gettext
fi
terminal_input console
terminal_output gfxterm
if [ x$feature_timeout_style = xy ] ; then
  set timeout_style=menu
  set timeout=5
# Fallback normal timeout code in case the timeout_style feature is
# unavailable.
else
  set timeout=5
fi
### END /etc/grub.d/00_header ###
### BEGIN /etc/grub.d/10_linux ###
menuentry 'Manjaro Linux' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-6a4db0be-a754-4a57-a47a-7bab351177d6' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
set root='hd0,msdos1'
if [ x$feature_platform_search_hint = xy ]; then
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  ada875ef-93fd-4950-944a-4d5c1733f72a
else
  search --no-floppy --fs-uuid --set=root ada875ef-93fd-4950-944a-4d5c1733f72a
fi
echo 'Cargando Linux 4.1.17-1-MANJARO x64...'
linux /vmlinuz-4.1-x86_64 root=UUID=6a4db0be-a754-4a57-a47a-7bab351177d6 rw cryptdevice=/dev/disk/by-uuid/b2b8e393-201c-4fc1-9d28-0b604302fca3:cryptManjaro resume=UUID=2e5bccd5-928b-41be-b755-0ad7689610f5 quiet splash
echo 'Cargando imagen de memoria inicial...'
initrd /intel-ucode.img /initramfs-4.1-x86_64.img
submenu 'Opciones avanzadas para Manjaro Linux' $menuentry_id_option 'gnulinux-advanced-6a4db0be-a754-4a57-a47a-7bab351177d6' {
menuentry 'Manjaro Linux (Kernel: 4.1.17-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.1.17-1-MANJARO x64-advanced-6a4db0be-a754-4a57-a47a-7bab351177d6' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
menuentry 'Manjaro Linux (Kernel: 4.1.17-1-MANJARO x64 - fallback initramfs)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.1.17-1-MANJARO x64-fallback-6a4db0be-a754-4a57-a47a-7bab351177d6' {
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
else
fi
initrd /intel-ucode.img /initramfs-4.1-x86_64-fallback.img
### END /etc/grub.d/10_linux ###
### BEGIN /etc/grub.d/20_linux_xen ###
### END /etc/grub.d/20_linux_xen ###
### BEGIN /etc/grub.d/30_os-prober ###
### END /etc/grub.d/30_os-prober ###
### BEGIN /etc/grub.d/40_custom ###
# This file provides an easy way to add custom menu entries.  Simply type the
# menu entries you want to add after this comment.  Be careful not to change
# the 'exec tail' line above.
### END /etc/grub.d/40_custom ###
### BEGIN /etc/grub.d/41_custom ###
if [ -f  ${config_directory}/custom.cfg ]; then
  source ${config_directory}/custom.cfg
elif [ -z "${config_directory}" -a -f  $prefix/custom.cfg ]; then
  source $prefix/custom.cfg;
fi
### END /etc/grub.d/41_custom ###
### BEGIN /etc/grub.d/60_memtest86+ ###
if [ "${grub_platform}" == "pc" ]; then
    menuentry "Memory Tester (memtest86+)" --class memtest86 --class gnu --class tool {
        search --fs-uuid --no-floppy --set=root --hint-bios=hd0,msdos1 --hint-efi=hd0,msdos1 --hint-baremetal=ahci0,msdos1  ada875ef-93fd-4950-944a-4d5c1733f72a
        linux16 /memtest86+/memtest.bin
fi
### END /etc/grub.d/60_memtest86+ ###
In the boot error the UUID shown is 6a4db0be-a754-4a57-a47a-7bab351177d6. It's a bit funny, but I also see in this live session several "Loop devices" in Dolphin, listed along with the usual drives. I haven't seen them before, and honestly I really don't know what they are or what does it means...
Offline newick
  • Neuling
  • Branch: stable
  • Desktop: awesome
  • GPU Card: nVidia GeForce GTX 560 Ti
  • GPU driver: nouveau
Hello everyone,
first post here, to report the same problem as omnimoon. My laptop can't boot on encrypted volume, i can get access to it with a live distrib.
The error message after entering the passphrase is "Failed to setup dm-crypt key mapping for device /dev/(...) Check that kernel supports aes-xts-plain cipher"
My current kernel on this computer is 3.16
Thanks for help
« Last Edit: 11. February 2016, 18:59:16 by newick »
Offline Adr1an
  • Kudos to the Devs
  • Branch: Stable
  • Desktop: Gnome-LightDM
  • GPU Card: AMD/ATI
  • GPU driver: Free
  • Kernel: 344 LTS
As far as I'm concerned: flawless!
Win7 & Manjaro Gnome dual boot; 2011 Dell Studio 15; Intel Core i5 M450 @ 2.40GHz × 4; 4GB RAM; AMD ATI Mobility Radeon HD 5400 series
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
@omnimoon: seems your UUID has changed somehow. this is what I have on my end:
Code: [Select]
menuentry 'Manjaro Linux (Kernel: 4.1.17-1-MANJARO x64)' --class manjaro --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-4.1.17-1-MANJARO x64-advanced-fcd883f2-5d60-4b71-9d17-1a24e210d2b6' {
savedefault
load_video
set gfxpayload=keep
insmod gzio
insmod part_msdos
insmod ext2
set root='hd0,msdos6'
  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos6 --hint-efi=hd0,msdos6 --hint-baremetal=ahci0,msdos6  fcd883f2-5d60-4b71-9d17-1a24e210d2b6
else
  search --no-floppy --fs-uuid --set=root fcd883f2-5d60-4b71-9d17-1a24e210d2b6
fi
echo 'Linux 4.1.17-1-MANJARO x64 wird geladen …'
linux /boot/vmlinuz-4.1-x86_64 root=UUID=fcd883f2-5d60-4b71-9d17-1a24e210d2b6 rw  resume=UUID=6dd17673-7ddb-4fd5-9c83-e3ef0116a872 quiet splash
echo 'Initiale Ramdisk wird geladen …'
initrd /boot/intel-ucode.img /boot/initramfs-4.1-x86_64.img
And here my blkid:
Code: [Select]
/dev/sda2: LABEL="swap" UUID="6dd17673-7ddb-4fd5-9c83-e3ef0116a872" TYPE="swap" PARTUUID="48afb528-02"
/dev/sda5: LABEL="root" UUID="d515079a-57d4-4aa9-9a18-c75e7776ace6" TYPE="ext4" PARTUUID="48afb528-05"
/dev/sda6: LABEL="root64" UUID="fcd883f2-5d60-4b71-9d17-1a24e210d2b6" TYPE="ext4" PARTUUID="48afb528-06"
/dev/sda7: LABEL="home" UUID="02b039ac-cc48-45a7-9f0b-61abb5360899" TYPE="ext4" PARTUUID="48afb528-07"
So root=UUID=6a4db0be-a754-4a57-a47a-7bab351177d6 is wrong and should be root=UUID=ada875ef-93fd-4950-944a-4d5c1733f72a. Please double check the UUID for your root partition.
« Last Edit: 11. February 2016, 21:00:00 by philm »
Offline omnimoon
  • Neuling
  • Branch: stable
  • Skill: Novice
I've just tried replacing every root=UUID=6a4db0be-a754-4a57-a47a-7bab351177d6 entry with root=UUID=ada875ef-93fd-4950-944a-4d5c1733f72a in grub.cfg, but I get once again the same message on boot, this time mentioning the latter UUID:
"ERROR: Unable to find root device 'UUID=ada875ef-93fd-4950-944a-4d5c1733f72a'. You are being dropped to a recovery shell. Type 'exit' to try and continue booting"
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
You should not use UUID=ada875ef-93fd-4950-944a-4d5c1733f72a because that is the /boot UUID.
You need to look for the root / partition.
You should use either one of these UUID's
But I don't know which one is the root partition. - do you know which is the /root partition and is the other partition some other partition, say /home or other data partition?
But from your grub.cfg, most likely it is "b2b8e393-201c-4fc1-9d28-0b604302fca3"
So, change the UUID to this one, but remember should be only at the linux line, not the search line.
Search line remains the same as "ada875ef-93fd-4950-944a-4d5c1733f72a"
Good luck.
If booted,
Code: [Select]
sudo grub-install /dev/sda
sudo update-grub
  and see if UUID has been corrected.
And check fstab entries also.
« Last Edit: 11. February 2016, 22:07:44 by gohlip »
Life is a sexually transmitted disease with a 100% mortality rate.
