Author Topic: manjaro-mate-15.12-i686.iso - something goes wrong ?  (Read 1233 times)
Offline aras
  • Neuling
  • maybe maybe make you baby
  • Branch: stable
  • Desktop: mate
  • GPU Card: Intel 965GM Express
  • GPU driver: video-intel
  • Kernel: 3.18.26-1 LTS i686
  • Skill: Intermediate
« on: 08. February 2016, 16:01:39 »
Hello there. First I need to say the manjaro  is the best linux distribution and mate edition look fucking briliant I using it all the time. But i installed manjaro-mate-15.12-i686.iso and it's  slower a lot than upgraded manjaro-xfce-minimal-16.06-dev-i686.iso with installed mate desktop environment.
Look here on the screen:
it's manjaro-xfce-minimal and on the screen I have opened firefox, chromium, xnoise, photoshop cc on wine, at the moment compilation of brave-browser-git and few small aplication it works pretty good, but when I worked on manjaro-mate-15.12-i686 it was horrible because with opened photoshop, chromium, deeadbeef I could not work it's freezen so that I could not turn off the chromium.
which pkg I need to remove to have the same effect of responsively and affect memory free ?
Is it possible to make mate minimal live iso with the same look ?
Sory for my english
Regards ! Thanks for good job !
Offline aras
  • Neuling
  • Branch: stable
  • Desktop: mate
Re: manjaro-mate-15.12-i686.iso - something goes wrong ?
« Reply #1 on: 10. February 2016, 23:18:16 »
any sugestions ?
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #2 on: 10. February 2016, 23:32:44 »
There are budgie-minimal, kde-minimal, lxqt-minimal, net-minimal and xfce-minimal.
I think your question doesn't have a definitive answer. Try removing everything you don't need. But rather than removing packages which usually don't require resources when you don't launch them, take a look at startup processes and deactivate those which you don't need.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline withjaro
  • Held Mitglied
  • 360
  • Branch: unstable
  • Desktop: openrc
  • GPU Card: geforce7150/ATIx2300
  • GPU driver: free
  • Kernel: linux4xxx-x64
  • Skill: Novice
« Reply #3 on: 10. February 2016, 23:47:02 »
just feeling i was thinking of the audio plugins you have an how they are interacting with the browsers ... Wine relies on dsst-vst ..ladspa ... and jack .... Chromium has inbuilt media codecs ...so maybe could be some fight for resources thats causing critical memory leaks  ... do you have the same freezing issues without browsers open?
Wish i could think of a soundcard diagnostic display ... but nothing comes to mind at the moment.
PS . im trying t get my head around what contained in your Waves plug-ins http://www.waves.com/plugins ... you are running FL Studio in Wine too ? which processor do you have ?
« Last Edit: 11. February 2016, 00:01:14 by withjaro »
< insert your own inspiring quotation - and smile :) >
Offline aras
  • Neuling
  • Branch: stable
  • Desktop: mate
« Reply #4 on: 11. February 2016, 00:29:06 »
Look it's easy example what I mean:
It's fresh install and I removed:
Code: [Select]
[2016-02-10 20:41] [ALPM] removed pulseaudio-bluetooth (7.1-3)
[2016-02-10 20:41] [ALPM] removed manjaro-printer (2015.06-2)
[2016-02-10 20:41] [ALPM] removed cups-pdf (2.6.1-2)
[2016-02-10 20:41] [ALPM] removed libreoffice-still (4.4.7-2)
[2016-02-10 20:41] [ALPM] removed blueman (2.0.2-1)
[2016-02-10 20:41] [ALPM] removed flashplugin (11.2.202.554-1)
[2016-02-10 20:41] [ALPM] removed thunderbird (38.4.0-2)
[2016-02-10 20:41] [ALPM] removed cups (2.1.2-3)
[2016-02-10 20:41] [ALPM] removed manjaro-welcome (15.12-1)
[2016-02-10 20:41] [ALPM] removed system-config-printer (1.5.7-2)
[2016-02-10 20:41] [ALPM] removed splix (2.0.0-13)
[2016-02-10 20:41] [ALPM] removed bluez (5.36-1.1)
[2016-02-10 20:41] [ALPM] removed hplip (3.15.11-2)
[2016-02-10 20:41] [ALPM] removed foomatic-db-engine (3:20151108-1)
[2016-02-10 20:41] [ALPM] removed cups-filters (1.5.0-2)
[2016-02-10 20:41] [ALPM] removed mate-user-guide (1.12.0-1)
[2016-02-10 20:41] [ALPM] removed cups-pk-helper (0.2.5-1)
[2016-02-10 20:41] [ALPM] removed python-pycups (1.9.73-2)
[2016-02-10 20:42] [ALPM] removed modem-manager-gui (0.0.18-2)
Here I have just firefox, pragha, photoshop and mate-monitor and it's 68% of ram. Now look on the first screen there is a lot of aplication and just 1% more.
@withjaro
Code: [Select]
winetricks atmlib gdiplus msxml3 msxml6 vcrun2005 vcrun2005sp1 vcrun2008 ie6 fontsmooth-rgb gecko
winecfg
Intel® Core™2 Duo CPU T7100 @ 1.80GHz × 2
https://appdb.winehq.org/objectManager.php?sClass=version&iId=32045
« Last Edit: 11. February 2016, 00:47:14 by aras »
Offline mandog
  • Held Mitglied
  • Architect Forum And G+ Forum Owner With Daniel S
  • Branch: All
  • Desktop: Gnome, Mate, E19, Openbox,FLuxbox,Budgie, XFCE openRC,
  • GPU Card: nvidia
  • GPU driver: Non Free
  • Kernel: latest
  • Skill: Advanced
« Reply #5 on: 11. February 2016, 01:47:21 »
How much ram have you got installed, Most of what you have removed has nothing to do with resources if they are not running
A ENGLISHMAN IN PERU
I'm dyslexic Please do not complain about punctuation or spelling,
FANBOY,Taken from the urban dictionary
 A pathetic insult often used by fanboys themselves to try and put down people who don't like whatever it is they like.
Offline aras
  • Neuling
  • Branch: stable
  • Desktop: mate
« Reply #6 on: 11. February 2016, 02:17:07 »
It's 2Gb.
Yes, you right but still I can do less operation than previously. That's a reason why I asked what I can remove. You know I can't to check what Was previously because it's formated and fresh installed. I tried to run net-install but I cant't to create two particion's without label and NEXT button was unactive. I think the best option is to check what new packages was added.
But thanks for all you wrote something.
Offline withjaro
  • Held Mitglied
  • 360
  • Branch: unstable
  • Desktop: openrc
  • GPU driver: free
  • Skill: Novice
« Reply #7 on: 11. February 2016, 07:58:16 »
Hi aras ...
Other from the RAM issue,mandog brought up ...
And before getting into a quagmire of Actionscript and Plugin architecture conflicts that might be occuring ..
The only other quick and easy suggestion i could make is just 'lock down' FL Studio and Photoshop in Wine ... bar all settings that try to make a connection to the internet (their attempts to 'phone home' will cause issues,even if you are offline) ... and keep any connectivity restricted to the Linux userspace.
Best of luck ... you have certainly tempted me to install Wine and run AVmedia files just see the dynamics ... the one and only time ive ever used Wine was to transfer jet.files ... i just transitioned to Linux and never looked back ... im not evangelistic though ... and whatever setup other people have,its the right one for them :)
Keep in touch,i have a similar Core Duo ... be interested to see if i can replicate your issues
« Last Edit: 11. February 2016, 08:29:17 by withjaro »
Offline aras
  • Neuling
  • Branch: stable
  • Desktop: mate
« Reply #8 on: 11. February 2016, 13:00:17 »
Thx for reply. My point is it's the same project on photoshop, the same version of photoshop and the same version of wine. My question is why on manjaro-mate-15.12-i686.iso the oportunity is to run three the same aplication and on manjaro xfce-minimal-16.06-dev-i686.iso with instlled mate I can run three more and it's the same memory status.
« Last Edit: 11. February 2016, 13:02:58 by aras »
