Author Topic: Budgie logs out immediately.  (Read 2163 times)
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
  • Skill: Intermediate
« on: 08. February 2016, 12:59:11 »
Hey guys. Hopefully someone can help with this.
I have dowloaded the Manjaro budgie iso and put it on a usb stick with unetbootin.  The system boots, but doesn't auto-login, falling back to the login screen. When I try to login, the desktop appears briefly then goes back to the login screen.
The .Xsession-errors shows a whole bunch of new Files miner errors, but other than that I can't find anything wrong.
I don't have access to a wired connection, only Wi-Fi but can't quite work out how to connect via command line.  I tried the solution mentioned here on another post of removing the evopop-gtk-themes but this didn't work either.
Someone help, please.
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
Re: Budgie logs out immediately.
« Reply #1 on: 08. February 2016, 13:23:33 »
Have you already installed or are you writing about the live session?
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #2 on: 08. February 2016, 13:28:36 »
I haven't installed it yet, I wanted to see what it was like first.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #3 on: 08. February 2016, 13:46:33 »
Ok, the I must tell you a sad thing that Unetbootin is a bad option for creating a bootable USB stick for Manjaro, see here: https://wiki.manjaro.org/index.php?title=Burn_an_ISO_File
Try a different option, please. Sorry!
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #4 on: 08. February 2016, 14:59:59 »
I'll give that a go and get back to you.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #5 on: 08. February 2016, 15:06:47 »
I don't guarantee that the same issue won' happen if you burn the stick with dd command. I had a similar issue with a different ISO, but not with Budgie. So it could be s.th. else.
« Last Edit: 08. February 2016, 15:09:36 by eugen-b »
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #6 on: 08. February 2016, 15:34:15 »
unfortunately, same problem! I'm outta ideas.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #7 on: 08. February 2016, 15:37:34 »
Can you post your hardware? inxi -F
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #8 on: 08. February 2016, 17:24:32 »
Okay.
Here is the inxi file, also the result of the xsession errors log.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #9 on: 08. February 2016, 17:33:15 »
You have an NVIDIA NV34 GeForce FX 5200. I don't know whether Budgie ISO has non-free drivers boot option. I don't have any experience with Nvidia. I hope others can help further.
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #10 on: 08. February 2016, 17:41:35 »
It does indeed have a non-free drivers option, but all that gives me is a black screen. And no access to tty.
Offline eugen-b
  • Support Team
  • Branch: testing
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #11 on: 08. February 2016, 17:48:20 »
Maybe choose non-free drivers but enter nomodeset modprobe.blacklist=nouveaufb into the text field before hitting Enter.
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #12 on: 08. February 2016, 18:09:15 »
Well, that still gave me a black screen, but I had access to tty again.
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #13 on: 08. February 2016, 18:41:40 »
Hi .. strange error .. in this iso not included the closed driver , only free .. i not experience with nvidia because my pc is an hybrid intel/amd gpu .. but you have try  to start the iso with vesa driver ? At the boot stop the countdown ( move arrow ) and type
Code: [Select]
xdriver=vesathen enter .. now the system boot with universal vesa driver ...
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline Zpfield
  • Neuling
  • I'm new. Be nice!
« Reply #14 on: 08. February 2016, 19:13:09 »
Ste74 you are a genius. Now, how do I make that permanent when I install it on the hard-drive?
