Author Topic: Testing Repositories  (Read 6299 times)
Offline Roland
  • Administrator
    • Manjaro Linux
Re: Testing Repositories
« Reply #45 on: 03. October 2012, 10:55:29 »
@Verändert: All is fine now. But there will be some further changes in how we will check things before pushing to testing...
Quote
resume from suspend to RAM is not working anymore.
after resume it says "ACPI: Unable to dock" and then goes back to sleep. After pressing the power button again it resume normally back to kdm login screen
Which kernel do you use? The 3.6 kernel has new features for suspending....
Offline Allaman
  • Neuling
« Reply #46 on: 03. October 2012, 11:11:33 »
3.5.4-1-MANJARO :)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #47 on: 03. October 2012, 15:02:20 »
This should be fixed in linux36:
Code: [Select]
sudo mhwd-kernel linux35 linux36 no
Offline Allaman
  • Neuling
« Reply #48 on: 03. October 2012, 22:00:18 »
Code: [Select]
I'm affraid not. I think it must be another issue cause it worked fine also with 3.5 kernel...
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #49 on: 15. October 2012, 00:59:10 »
Hmm, then I don't know ...  :o
