Author Topic: Testing Repositories  (Read 6352 times)
Offline Roland
  • Administrator
    • Manjaro Linux
Re: Testing Repositories
« Reply #30 on: 21. September 2012, 12:36:32 »
I am planing to merge them soon, if no more problems occur. My testing machines are running just fine. However I need some more reports about KDE and Gnome/Cinnamon!
Offline eskaini
  • Security Team
  • I eat deleted accounts
  • Skill: Novice
« Reply #31 on: 21. September 2012, 16:08:51 »
Hello. Got a mail with ISOs (gnome ones) to test, but they do not start, an error with syslinux.
Code: [Select]
No DEFAULT or UI configuration directive found !
boot:
Got this with x86_64 ISO. Known bug ?
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #32 on: 21. September 2012, 16:37:57 »
I'll check this. I think phil was too fast at the end just before he left for vacation.
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #33 on: 21. September 2012, 16:59:58 »
Thanks. Having some testing ISO in order to debug this problem could be great too.
Offline YFDogan
  • Support Team
    • http://www.manjaro-tr.org/
  • Branch: Stable
  • Desktop: KDE
  • GPU Card: Optimus (GeForce GT 540M)
  • GPU driver: Non-free
  • Kernel: Linux manjaro 3.14.4-1-MANJARO #1 SMP PREEMPT Mon May 19 15:45:30 EST 2014 x86_64 GNU/Linux
  • Skill: Novice
« Reply #34 on: 21. September 2012, 18:24:34 »
Since Wednesday ehen I updated to KDE 4.9.1, there are no erors, freezes, issues I met with x86-64 and bumblebee. may be you may release the new KDE ISO friend :)
Manjaro Linux with DELL Insipiron N5110 i7 8GB Ram, Nvidia-Optimus
http://manjaro-tr.org/forum/index.php
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #35 on: 21. September 2012, 18:51:43 »
Happy to hear this. To have the new KDE as LiveCD we have to merge testing first. So is somebody against a merge? I will also speak with guillaume...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #36 on: 21. September 2012, 18:57:50 »
Only one thing I just met is, when ı use the mobile broadband connection it is allwayse unselect with startup. With every connection ı select and enable it and after reboot it is lost.
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #37 on: 21. September 2012, 19:03:31 »
hmm. I don't have experience with mobile broadband connections. did this problem occur after the update? I will see what I can find in google...
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #38 on: 21. September 2012, 19:08:01 »
Yes after update this occur. And , I changed the policy accesses to the disks, after update this is missing too and dolphin is asking me password to acces the disk partitions.
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #39 on: 21. September 2012, 19:12:13 »
This could be the problem. Your keyring isn't unlocked after login and that's why it doesn't autoconnect.
Offline YFDogan
  • Support Team
  • Branch: Stable
  • Desktop: KDE
  • Skill: Novice
« Reply #40 on: 22. September 2012, 10:56:16 »
Code: [Select]
And the solution is?
Offline Roland
  • Administrator
    • Manjaro Linux
« Reply #41 on: 22. September 2012, 11:59:43 »
Don't know. I am not a KDE user. Did you were asked to save any passwords as soon as you did setup and connect to your mobile broadband connection?
Offline eskaini
  • Security Team
  • Skill: Novice
« Reply #42 on: 30. September 2012, 10:10:17 »
Is this still an issue since the repos are merged ? I would otherwise set up a "test system" for Manjaro testing where it doesn´t matter if i screw it up.
Offline Allaman
  • Neuling
« Reply #43 on: 01. October 2012, 15:44:40 »
I dont think so, see also here http://forum.manjaro.org/index.php?topic=416.0
Currently I am running manjaro with testing repos as my primary productive system :)
Offline Allaman
  • Neuling
« Reply #44 on: 03. October 2012, 10:00:52 »
resume from suspend to RAM is not working anymore.
after resume it says "ACPI: Unable to dock" and then goes back to sleep. After pressing the power button again it resume normally back to kdm login screen
