Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
117 (92.1%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
4 (3.1%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
6 (4.7%)
Total Members Voted: 127
Author Topic: [Update] 2016-01-27 - Kernels, Deepin, Plasma5, PulseAudio, JRE  (Read 6592 times)
Offline leledumbo
  • Sr. Mitglied
    • Pascal Warrior's Journey
  • Branch: stable
  • Desktop: KDE
  • GPU Card: Intel HD 4400 + nVidia GeForce GT 740M (HP notebook), Intel HD 5500 + nVidia GeForce GT 940M (ASUS notebook), nVidia GeForce GT 220 (desktop)
  • GPU driver: non-free
  • Kernel: linux-latest-x64 and linux-latest LTS-x64
  • Skill: Intermediate
Re: [Update] 2016-01-27 - Kernels, Deepin, Plasma5, PulseAudio, JRE
« Reply #30 on: 28. January 2016, 17:43:38 »
plasma no longer locks after waking up from suspend, yay!
Manjaro Net edition 64-bit + Self installed KDE
Kernel latest supported + latest LTS
HP Pavilion 14-n038tx
Asus A455LB-WX034D
Self built desktop
Offline varikonniemi
  • Neuling
« Reply #31 on: 28. January 2016, 17:59:07 »
Smooth as silk.
Offline Chazy Chaz
  • Jr. Mitglied
  • I'm new. Be nice! :P
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: AMD R9 290
  • GPU driver: Free
  • Kernel: Linux44-x64
« Reply #32 on: 28. January 2016, 18:58:10 »
Everything ok, thanks again.
Offline george.sterpu
  • Neuling
  • Branch: stable
  • Desktop: Xfce
  • GPU Card: nVidia
  • Kernel: stable
  • Skill: Novice
« Reply #33 on: 28. January 2016, 20:48:54 »
@george.sterpu, try
Code: [Select]
sudo pacman -Sy --force python-pip
If that doesn't work, what does
Code: [Select]
pacman -Qo /usr/lib/python3.5/site-packages/pip/say?
Thanks oberon, it works :D
Code: [Select]
$ sudo pacman -Qo /usr/lib/python3.5/site-packages/pip/
/usr/lib/python3.5/site-packages/pip/ is owned by python-pip 7.1.2-2
$ sudo pacman -Sy --force python-pip
(1/1) upgrading python-pip                         [######################] 100%
/usr/lib/python3.5/site-packages/pip/ is owned by python-pip 8.0.2-1
Never had conflicting files before, so TIL what is the --force option useful for.
Offline lesanglier
  • Neuling
  • Branch: ManjaroLinux 0.8.8 Ascella stable
  • Desktop: OpenBOx 3.5.2
  • GPU Card: Intel Mobile 945GM/GMS 943/940GML Express Integrated Graphics Controller
  • GPU driver: intel (unloaded: vesa)
  • Kernel: linux310-x86
  • Skill: Novice
« Reply #34 on: 28. January 2016, 21:25:41 »
Hello,
Quote
tint2 panel is disappearing after thunar started.
me too  with the terminal :(
Offline MrOats
  • Neuling
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU driver: free
  • Kernel: 4.4.6-1-x64
« Reply #35 on: 29. January 2016, 02:08:30 »
I have a really weird issue, on Cinnamon 2.8.6 and Pamac 2.4.3-5, when the notification about updates being available comes up it goes in the notification tray like it should. But when I hit "Clear Notifications", pamac updater opens up. I have restarted Cinnamon and restarted my computer after the update. Still acts the same.
Offline k0n24d
  • Neuling
  • Skill: Advanced
« Reply #36 on: 29. January 2016, 09:37:38 »
Hi,
gnome-shell is crashing whenever I activate a VPN:
https://bugzilla.gnome.org/show_bug.cgi?id=760924
https://projects.archlinux.org/svntogit/packages.git/commit/trunk?h=packages/gnome-shell&id=715a967d2647c11e05fe31ff15d01d5003c8caee
Could you please pull in the latest gnome-shell update.
EDIT: I just saw the update is already in testing...
« Last Edit: 29. January 2016, 09:54:52 by k0n24d »
Offline mrbig
  • Neuling
  • Like tears in the rain...
  • Branch: stable
  • Desktop: KDE
« Reply #37 on: 29. January 2016, 10:16:46 »
Great release as always phim! No problems here.
Any news on when manjaro is moving to kernel 4.4 branch? Thank you!
Offline kouros17
  • Held Mitglied
  • Branch: Unstable
  • Desktop: Xfce (4.12.3)
  • GPU Card: AMD Radeon HD 8570 / R7 200 Series
  • GPU driver: Non-free (Catalyst)
  • Kernel: 4.6rc7 - x86_64
« Reply #38 on: 29. January 2016, 11:13:43 »
If you want you can move to 4.4 from manjaro-settings-manager/kernel.
Offline Trinakrian
  • Vollwertiges Mitglied
« Reply #39 on: 29. January 2016, 14:41:57 »
Well, I'm back to my reboot loop that started after the last big update. I never reach the login manager (SDDM). I edited GRUB, added a "3" to the line that started with "Linux" to get to run level 3. I enabled and restarted SDDM and it worked for almost two weeks. This update, it's back, and editing GRUB no longer works.
Any suggestions?
Addendum: this time around I tried something different and it worked. Not sure which one did it, but maybe this will help someone else.
01. Edited GRUB to get to run level 3.
02. sudo systemctl disable sddm
03. # systemctl enable sddm -f
04. # systemctl enable sddm.service
05. # systemctl start sddm
I'm in.
« Last Edit: 29. January 2016, 16:56:04 by Trinakrian »
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
« Reply #40 on: 30. January 2016, 09:45:13 »
@Trinakrian: please move to testing branch. We added some fixes regarding mesa there.
Offline Adr1an
  • Kudos to the Devs
  • Branch: Stable
  • Desktop: Gnome-LightDM
  • GPU Card: AMD/ATI
  • GPU driver: Free
  • Kernel: 344 LTS
« Reply #41 on: 30. January 2016, 15:42:57 »
Very smooth!! Many thanks.
Win7 & Manjaro Gnome dual boot; 2011 Dell Studio 15; Intel Core i5 M450 @ 2.40GHz × 4; 4GB RAM; AMD ATI Mobility Radeon HD 5400 series
Offline Sothis6881
  • Neuling
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: nVidia GTX 660 Ti
  • Kernel: 44, 41
« Reply #42 on: 31. January 2016, 02:28:16 »
Another smooth update here as well. Thanks everyone!
Offline eduardo
  • Sr. Mitglied
  • Branch: testing
  • Desktop: KDE plasma 5
  • GPU Card: Intel HDGraphics 4400 / Nvidia Geforce 960M
  • GPU driver: non-free on nvidia
  • Kernel: linux44, linux45_RC
  • Skill: Novice
« Reply #43 on: 31. January 2016, 18:13:31 »
Everything ok, the nvidia driver seems to be an older release but I guess the manjaro people is waiting for the next stable driver. I hope that will happen soon.
Offline zzz
  • Skill: Novice
« Reply #44 on: 31. January 2016, 23:24:07 »
At last, able to move beyond kernel 4.1.1-1 after resolving catalyst driver issue.
