Author Topic: How to install Manjaro on btrfs subvolumes with CLI installer  (Read 10388 times)
0 Members and 2 Guests are viewing this topic.
Offline Chrysostomus
  • Maintainer
  • Neckbeards are cool
    • Git
  • Branch: unstable
  • Desktop: Gnome, bspwm
  • GPU Card: Intel HD4000
  • GPU driver: free
  • Kernel: linux44-x64
  • Skill: Intermediate
Re: How to install Manjaro on btrfs subvolumes with CLI installer
« Reply #30 on: 04. March 2016, 08:11:48 »
It is not related to resume option, but to grub remembering your last boot choice. For me problem vent away when I disabled that option. You can still hibernate.
Comment out
Code: [Select]
#GRUB_SAVEDEFAULT=true
in
Code: [Select]
/etc/default/gruband run
Code: [Select]
sudo update-grub
This should solve the issue without taking away your ability to hibernate.
« Last Edit: 04. March 2016, 08:48:08 by Chrysostomus »
Offline gohlip
  • Held Mitglied
  • Desktop: OpenBox
  • GPU Card: nvidia
  • GPU driver: nonfree
  • Kernel: linux46 - x64
« Reply #31 on: 04. March 2016, 09:01:56 »
I think you need these two lines for 'save default' to work. Haven't used it for some time. If it works for just one line, appreciate the correction.
Code: [Select]
  GRUB_DEFAULT=saved
ps: re: resume - maybe I don't understand clearly, but we need 'resume=UUID=xxxxxxxx' in grub.cfg as well for hibernation to work.
But I guess you're saying this is not related to the issue at hand. Then, okay.
Life is a sexually transmitted disease with a 100% mortality rate.
  • Maintainer
    • Git
  • Branch: unstable
  • GPU driver: free
« Reply #32 on: 04. March 2016, 09:49:15 »
Yeah, you should comment out both of those lines to be sure that grub does not try to save the previous choice. Thst way btrfs should not give the sparse files error.
Offline klepto
  • Neuling
  • De Omnibus Dubitandum
  • Branch: Unstable
  • Desktop: Cinnamon/LXQT
  • GPU Card: Quadro K1100M
  • GPU driver: Nonfree
« Reply #33 on: 14. April 2016, 09:41:56 »
I've been trying to get Btrfs to work with Manjaro for a while. I followed the guide but I too got the sparse error.
Then I added a boot partition in ext4 and that fix the prob but then I got some VFS error and kernel panic.
I have yet to get it to work properly.
I remember using Slackware in the 90's on my 386sx but somehow I became a Linux newb. Am I just getting old?
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #34 on: 14. April 2016, 11:40:07 »
As Chrysostomus wrote, setting   GRUB_SAVEDEFAULT=false in /etc/default/grub and running update-grub would have resolved it.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
