Author Topic: Sometimes system hangs - baytrail - help to find out the reason and to fix  (Read 7235 times)
Offline mark001
  • Sr. Mitglied
  • Branch: stable
  • Desktop: xfce4
  • GPU Card: Intel HD Graphics
  • GPU driver: i915
  • Skill: Novice
Is that should be really a service? I am not really good with scripts in this way :S I mean could it be a compilable patch for example? I run kernel 4.0.9 with cstate=1 and
the baytrail started working with no freezing since then ... I am not sure about patch but it would be cool make possible just to patch a kernel in case you have CPU N3520 BayTrail or
similar series?
