Hi!
I really often see that users don't use our "Topic Solved" Button near the bottom of the topic.
So please, don't write [Solved] into the subject, use our "Topic Solved" Button.
Only the creator of the topic can mark it as solved, and for this it's not necessary to have a longer edit time because this button will always work.
In the next few days i will go through all solved topics and remove [Solved] in the subject and mark it as solved. If you see a topic with [Solved] in the subject you can write me a PM, or if you the owner or a Mod, you can do it on your own.
Thanks.
And btw: please don't use the report function only to tell me something like a mistake you made or a double post. The report function is to report spam or something else. Thanks.
