Author Topic: Post install script  (Read 904 times)
Offline BlackHippy
  • Neuling
  • I'm new. Be nice!
  • Desktop: KDE
  • Skill: Novice
Post install script
« on: 22. January 2016, 01:33:19 »
I'm getting a error on the install script. Here is the error http://i67.tinypic.com/2ihrwj4.jpg
Edit: installed pacman -Sy archlinux-keyring
Now only get the error on key "Bernhard Landauer...
« Last Edit: 22. January 2016, 01:56:53 by BlackHippy »
Offline scachemaille
  • Held Mitglied
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: Plasma 5
  • GPU Card: nVidia GT 330M
  • GPU driver: Nouveau
  • Kernel: 4.8_x64
  • Skill: Intermediate
Re: Post install script
« Reply #1 on: 22. January 2016, 02:13:39 »
I'm not sure to be able to help you.. but there is a problem with the link of the picture of the errors. it don't show me anything
Offline BlackHippy
  • Neuling
  • I'm new. Be nice!
  • Desktop: KDE
  • Skill: Novice
« Reply #2 on: 22. January 2016, 02:42:49 »
Can you see this pic http://s12.postimg.org/4nworpsm5/tmp_20596_IMG_20160121_1825441505135193.jpg
  • Held Mitglied
  • I'm new. Be nice!
  • Branch: Unstable
  • Desktop: Plasma 5
  • Kernel: 4.8_x64
« Reply #3 on: 22. January 2016, 03:07:55 »
yes I see..
try the following command.
Code: [Select]
sudo pacman -Syy
sudo pacman -S manjaro-keyring
sudo pacman -Suu
Offline BlackHippy
  • Neuling
  • I'm new. Be nice!
  • Desktop: KDE
  • Skill: Novice
« Reply #4 on: 22. January 2016, 09:41:31 »
yes I see..
Code: [Select]
sudo pacman -Syy
sudo pacman -Suu
Thanks alot this fixed my first problem.
I have another problem that the OS will become laggy for no reason and the OS is using only 5% ram and cpu. Does anyone know what maybe causing the problem or how to find out what is?
My screen will cut off, this may be a display driver, but I have used other version of manjaro and never had a problem.
Edit: I updated the kernel from 3.1.3 to 4.3.3 and it seems to be running fine for the past hour.
« Last Edit: 22. January 2016, 11:55:31 by BlackHippy »
