Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
111 (84.1%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
10 (7.6%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
11 (8.3%)
Total Members Voted: 132
Author Topic: [Update] 2016-01-13 - Kernels, Plasma 5.5.3, Firefox 43.0.4, Manjaro-Tools 0.10  (Read 9718 times)
Offline mfom
  • Neuling
  • I'm new. Be nice!
  • Desktop: KDE
  • GPU Card: INTEL
  • GPU driver: non-free driver
  • Kernel: linux_54
  • Skill: Novice
Thanks Phim for your answers,
Here my laptop specs:
System:    Host: michaelf Kernel: 3.18.25-1-MANJARO x86_64 (64 bit gcc: 5.3.0)
           Desktop: KDE Plasma 5.5.3 (Qt 5.5.1) Distro: ManjaroLinux 15.12 Capella
Machine:   Mobo: SAMSUNG model: QX310/QX410/QX510/SF310/SF410/SF510 v: 03MX
           Bios: American Megatrends v: 03MX.M005.20101011.SCY date: 10/11/2010
CPU:       Dual core Intel Core i5 M 480 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10645
           clock speeds: max: 2667 MHz 1: 1199 MHz 2: 1199 MHz 3: 1866 MHz 4: 1199 MHz
Graphics:  Card-1: Intel Core Processor Integrated Graphics Controller bus-ID: 00:02.0
           Card-2: NVIDIA GT218M [GeForce 310M] bus-ID: 01:00.0
           Display Server: X.Org 1.17.4 driver: intel Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile GLX Version: 2.1 Mesa 11.1.1 Direct Rendering: Yes
Audio:     Card Intel 5 Series/3400 Series High Definition Audio driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture v: k3.18.25-1-MANJARO
Network:   Card-1: Intel Centrino Advanced-N + WiMAX 6250 [Kilmer Peak]
           driver: iwlwifi v: in-tree: bus-ID: 02:00.0
           Card-2: Marvell Yukon Optima 88E8059 [PCIe Gigabit Ethernet Controller with AVB]
           driver: sky2 v: 1.30 port: b000 bus-ID: 03:00.0
Drives:    HDD Total Size: 640.1GB (50.1% used) ID-1: /dev/sda model: SAMSUNG_HM641JI size: 640.1GB
Partition: ID-1: / size: 29G used: 24G (87%) fs: ext4 dev: /dev/sda2
           ID-2: /home size: 555G used: 272G (52%) fs: ext4 dev: /dev/sda3
           ID-3: /boot size: 247M used: 41M (18%) fs: ext2 dev: /dev/sda1
           ID-4: swap-1 size: 3.93GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 43.0C mobo: N/A
           Fan Speeds (in rpm): cpu: N/A
Info:      Processes: 148 Uptime: 15 min Memory: 773.5/3745.2MB Init: systemd Gcc sys: 5.3.0
           Client: Shell (bash 4.3.421) inxi: 2.2.32
I followed your answers but I didn't get wireless connection.
Thanks for help,
Michael
Offline Trinakrian
  • Vollwertiges Mitglied
  • Skill: Intermediate
That worked. I edited the grub line that starts with "linux" by pressing "e." I changed the runlevel by adding a 3 at the end of the line.
I logged in and typed:
sudo systemctl enable sddm
sudo systemctl start sddm
SDDM started as usual, I logged in as usual and got to my desktop. Hope that helps someone else.
Not sure how or why SDDM got turned off.
Well seems my problem is persistent. It lasted for one day and now I have to this every time.
Saw a solution that stated that this would work:
Code: [Select]
ln -sf /usr/lib/systemd/system/sddm.service /etc/systemd/system/display-manager.service
Thoughts?
Offline v17564
  • I'm new. Be nice!
  • Skill: Novice
@philm
All OK with updates in OpenRC.
Thanks.
Offline jubileu
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xcfe
Not sure if it's a bug from Xfce or VLC, but lately VLC has been launching as a full screen window by default (showing title bar, hiding xfce-panel). Even after re-sizing it, every time I use the complete full screen (only video, no bars) and go back, it's a full creen window again.
Anyone having the same issue or knows of a fix?
Offline mrbig
  • Neuling
  • Like tears in the rain...
  • Branch: stable
  • Desktop: KDE
What does it mean? I'll upgrade later! But I didn't understand the quoted sentence. KDE is Qt based as I know!!! Do you mean the theme?
it just means that the GTK apps will use GTK3 version. KDE is qt based, but an application can use whatever the developers decide =)
