Author Topic: Want to Install Budgie DE Alongside Manjaro-Fluxbox  (Read 1458 times)
Offline Rocky-IV
  • Jr. Mitglied
  • Life is Good on Manjaro
  • Branch: Unstable
  • Desktop: Cinnamon, Fluxbox, Enlightenment
  • GPU Card: i7-4790S / ATI Radeon R7
  • GPU driver: Free
  • Kernel: 4.6RC-x64
  • Skill: Intermediate
« on: 10. January 2016, 02:09:24 »
          Hello fellow Budgie users
          I'd like to address this post mainly to Ste74 if possible.
Are there any pre-cautions needed before installing (Budgie Desktop Enviroment) to an existing running Manjaro Fluxbox.
I know that pacman -S can be used for installation. Should I install the standard Budgie Package or git version of Budgie.
Am i best to install the standard Budgie Package and then update to git version of Budgie.
Or can I just directly install git Budgie edition directly.
Which login window enviroment does Budgie need and would it conflict with current Fluxbox login
Thanks for your feedback
« Last Edit: 10. January 2016, 14:56:15 by oberon »
Greetings
Offline simgin
  • Held Mitglied
  • Branch: All.
  • Desktop: XFCE+Alpine Linux, Mate+Fedora, Ubuntu Server + Mate and NoX+LinuxBBQ
  • GPU Card: GeForce 8600M & GT 555M 2GB
Re: Want to Install Budgie DE Alongside Manjaro-Fluxbox
« Reply #1 on: 10. January 2016, 14:01:12 »
I can only comment on the login manager. You should be able to use whatever you want there. As for edition, I think someone will come by very soon.
cheerio
simgin
« Last Edit: 10. January 2016, 14:56:29 by oberon »
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #2 on: 10. January 2016, 14:08:54 »
The last Budgie 16.01 has LightDM.
« Last Edit: 10. January 2016, 14:55:51 by oberon »
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
« Reply #3 on: 10. January 2016, 15:21:56 »
Hi..you can use all dm what  you want. In my ISO used lightdm because gdm at fresh install not. Recognize budgie.you can install budgie from our repo but only with 10.2.2-2 the nm-applet show in the panel.if this version is not in stable you can download form pur unstable repo.
After that i think no problem to add budgie at fluxbox but remember for simply manage budgie install also. Gnome tweak tools
Stefano
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
