Author Topic: [ Dev X ] Development build Cinnamon  (Read 1621 times)
Offline ringo
  • Held Mitglied
  • www.manjaro-nl.org
    • Manjaro Belgium + forum
  • Branch: unsourced
  • Desktop: xfce
  • GPU Card: Nvidia Geforce 8600 GT (acer 23inch)
  • GPU driver: Free*
  • Kernel: linux kernel
  • Skill: Novice
« on: 09. January 2016, 17:26:12 »
So going forward, this is just a development build...
is just a try out...
arc-themes
nitrux
noto sanse  fonts
l3afpad text editior
libreoffice-next
Next build so to more internally with glibc but have to seee :p
16.x1.dev-1/
Dutch go the dutch site :)
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
Re: [ Dev X ] Development build Cinnamon
« Reply #1 on: 09. January 2016, 20:01:34 »
contains also a failed installed plymouth theme,
calamares-dev and latest thus to try out.. !! :)
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
  • Desktop: Xfce 16.06 pre2
  • Skill: Intermediate
« Reply #2 on: 11. January 2016, 10:26:43 »
Why leafpad?
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #3 on: 11. January 2016, 13:32:58 »
just to experiment .. Dev is just to expiriment , still have to work a new Dev build.. for the glib-2.0 schemas
need some sounds.....
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
« Reply #4 on: 11. January 2016, 14:11:43 »
If you are experimenting, please try to get gnote to work completely.  Some of the functions are not working.  Even after manually downloading the 3 additional dependencies from the arch site, it still is not right.
Tomboy is a replacement, but it needs mono to work.  That is a lot of overhead for just one program.
And, please check the theme Windows10-Optimized-Green and see if it works for you.
« Last Edit: 11. January 2016, 14:18:22 by k357k9 »
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #5 on: 11. January 2016, 14:22:03 »
on themes i need just a steady theme maintainance not sort of community stuf that goes dead end in a while !
i revert changed to standard, most comes from the two installers it seems that the iso is big..does not make sense afterall could be 0.1 smaller if put abiword and gnumeric but who want that :p
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
« Reply #6 on: 11. January 2016, 14:55:32 »
Apparently, it is very difficult to reduce the ISO size at this time.  It is almost impossible to get below 700 MB in order to fit on a CD.  Why worry about 0.1 MB? The people who use Cinnamon and Mate want top of the line applications.
Offline ringo
  • Held Mitglied
  • Branch: unsourced
  • Desktop: xfce
  • GPU driver: Free*
  • Skill: Novice
« Reply #7 on: 11. January 2016, 23:28:33 »
was more thinking about a range 1.3gb -1.4gb but mainreason is two installers, removing MSM and Calamares would lighten te iso much.. but then you remove more manjaro specifik thinks.. :)
Offline k357k9
  • Sr. Mitglied
  • Branch: Stable
« Reply #8 on: 12. January 2016, 12:42:36 »
I do not think that you should worry about it until you get over 1.5 MB.
BTW, cinnamon is using 384 MB right now.  I have not seen it that high before this.  Restarting dropped it to 85 MB.
Offline Rocky-IV
  • Jr. Mitglied
  • Life is Good on Manjaro
  • Branch: Unstable
  • Desktop: Cinnamon, Fluxbox, Enlightenment
  • GPU Card: i7-4790S / ATI Radeon R7
  • GPU driver: Free
  • Kernel: 4.6RC-x64
« Reply #9 on: 05. February 2016, 01:51:29 »
     Lets see ~ On this computer I have 8GB of RAM Memory together with Intel Core i7-4790 processor & Samsung 850-EVO SSD.
In other words I have nearly unlimited resources.
Greetings
