Poll
Did you experience any issue with this update?
No issues, everything went smoothly.
109 (91.6%)
Yes there was an issue. I was able to resolve it myself. (Please post your solution)
1 (0.8%)
Yes I am currently experiencing an issue due to the update. (Please post about it)
9 (7.6%)
Total Members Voted: 119
Author Topic: [Update] 2016-01-05 - OpenRC, Deepin, Budgie, Bumblebee, PHP7, Wine  (Read 9724 times)
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • GPU Card: Geforce GTX 650
  • GPU driver: non-free
  • Kernel: Maintainer - so all ;)
  • Skill: Guru
I'm happy to announce our second update of Manjaro 15.12 (Capella)!
Packages of the new major version of PHP have been released into all our repositories. Besides the new PHP 7 features there are the following packaging changes. In general the package configuration is now closer to what was intended by the PHP project. Also refer to the PHP 7 migration guide for upstream improvements.
Removed packages
  • php-pear
  • php-mssql
  • php-ldap:   The module is now included in the php package
  • php-mongo:  The new php-mongodb might provide an alternative even though it is not a compatible drop-in replacement
  • php-xcache: Consider using the included OPcache and optionally APCu for user data cache
  • graphviz:   The PHP bindings had to be removed
New packages
  • php-apcu-bc: Install and enable this module if the apc_* functions are needed
  • php-mongodb
Configuration changes
  • open_basedir is no longer set by default
  • openssl, phar and posix extensions are now built in
  • php-fpm does no longer provide a logrotate configuration. Instead syslog/journald is used by default
  • php-fpm's service file does no longer set PrivateTmp=true
  • The configuration and module of php-apache have been renamed to php7_module.conf and libphp7.so
Beside the PHP 7 changes we also added some fixes to Plasma 5 OpenRC, Deepin, Budgie and Bumblebee. Some additional fixes went into our graphical installers.
We fixed a bug in grub, updated the kernel to 4.4-rc8, added some new haskell packages and python packages plus renewed the linux firmware.
Archlinux upstream fixes are now from: Tue Jan 5 09:22:24 CET 2016.
It is always good to check for updated packages, even we don't notify you about them. As usual people using our testing branch will help us to get snaps over to our stable branch almost smoothly. For notifications on daily bases please take a look at our mailing list.
Kind regards,
Philip Müller and the Manjaro Development Team
Current supported kernels
  • Linux310 3.10.94
  • Linux312 3.12.51
  • Linux313 3.13.11.32
  • Linux314 3.14.58
  • Linux316 3.16.7.21
  • Linux318 3.18.25
  • Linux319 3.19.8.12
  • Linux41  4.1.15
  • Linux42  4.2.8
  • Linux43  4.3.3
  • Linux44  4.4-rc8
Package changes
  • stable community i686:  385 new and 362 removed package(s)
  • stable community x86_64:  384 new and 361 removed package(s)
  • stable core i686:  14 new and 14 removed package(s)
  • stable core x86_64:  14 new and 14 removed package(s)
  • stable extra i686:  180 new and 188 removed package(s)
  • stable extra x86_64:  180 new and 188 removed package(s)
  • stable multilib x86_64:  7 new and 8 removed package(s)
« Last Edit: 05. January 2016, 17:04:32 by philm »
Offline wordler
  • Vollwertiges Mitglied
  • I can wire a plug
  • Branch: Stable
  • Desktop: Fluxbox & Xfce
  • GPU Card: Nvidia GT720 1gb ddr5
  • Kernel: linux4.4-x64
  • Skill: Novice
Re: [Update] 2016-01-05 - OpenRC, Deepin, Budgie, Bumblebee, PHP7, Wine
« Reply #1 on: 05. January 2016, 12:11:47 »
Smooth fast update, no issues. Everything running as normal. Thanks Manjaro Team  :)
Fear is the mind killer.
Offline KabirGandhiok
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Gnome / Xfce
  • GPU driver: Free
  • Kernel: 41 / 44
  • Skill: Novice
« Reply #2 on: 05. January 2016, 12:42:43 »
Hi,
I'm wondering why I'm not seeing this update on my system. Have updated my mirrors twice, but still it says "there is nothing to do". Any ideas?
Thanks for your help
Offline Kelaun
  • Jr. Mitglied
  • Branch: Stable
  • Desktop: Gnome
  • GPU Card: nVidia GTX 730m
  • GPU driver: Non-free
  • Kernel: 4.5.3-1-MANJARO x86_64
  • Skill: Intermediate
« Reply #3 on: 05. January 2016, 12:52:33 »
Everything works fine here. I just had to wait longer than expected for wine to start some games, but I suppose this is due to the update of wine-staging.
Kelaun
Offline llogg
  • Sr. Mitglied
  • Skill: Novice
« Reply #4 on: 05. January 2016, 13:12:17 »
Hi,
Just wait.
Laptop: Ideapad U310, Kernel 4.1, 4.3, MDM, XFCE
Desktop: Kernel 4.0, 4.1, MDM, XFCE, Nvidia non-free drivers
Offline viking60
  • Sr. Mitglied
    • bjoernvold.com
  • Branch: stable
  • Desktop: openbox
  • GPU Card: NVIDIA GT200b [GeForce GTX 275]
  • GPU driver: nonfree
  • Kernel: linux4.1-x86_64
« Reply #5 on: 05. January 2016, 14:21:34 »
Yes I sure had to wait..
I Booted and that Intel firmware Bios flash screen stayed "forever". Hitting Del to run Bios setup did not respond.
Several Ctrl+Alt+Del later it finally booted.
When I try to enter Openbox X seems to fail after 10 sec or something so I have to use Xfce (I'll dive into that later).
So everything looks fairly good now.
Code: [Select]
CPU~Quad core Intel Core i7 920 (-HT-MCP-) speed/max~1600/2668 MHz Kernel~4.2.8-1-MANJARO x86_64
  • Jr. Mitglied
  • Branch: Stable
  • GPU driver: Free
  • Kernel: 41 / 44
  • Skill: Novice
« Reply #6 on: 05. January 2016, 14:40:17 »
Update received thanks!! All smooth :) Awesome!!
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #7 on: 05. January 2016, 15:00:35 »
Hi,
well, check our service if you mirror had synced yet: http://repo.manjaro.org/
Offline ruziel
  • Held Mitglied
  • Those who know, laugh.
    • Coffee & Manjaro
  • Branch: Stable
  • Desktop: Xfce
  • Kernel: 4.4 / 4.9
  • Skill: Novice
« Reply #8 on: 05. January 2016, 16:08:30 »
100% on my machine.
Big thanks to Phil, team & anyone who helped with user testing.
More power to Manjaro!
Ruziel :-)
"There is no complete theory of anything." (Robert Anton Wilson)
Offline CyberWolf2k14
  • Held Mitglied
  • Computers make very fast, very accurate mistakes.
  • Branch: Stable-sysd229-LightDM
  • Desktop: MATE/Cinnamon/GNOME
  • GPU Card: nVidia GeForce GT740
  • GPU driver: nVidia-NF-364.19
  • Kernel: 4.4.9x64 / 4.2.8.9x64 / 4.1.23x64
« Reply #9 on: 05. January 2016, 16:43:36 »
Oh my yes, ANOTHER smooth update. I really love it when the updates are smooth. ;D 8)
I hate bumpy updates.  :o ::) 8)
PowerSpec Quad core Intel Core i5-4690K w/ 16GB RAM
Dual Boot = Win 7 Ult x64 and Manjaro 15.12 x64
"A computer lets you make more mistakes faster than any invention in human history...
with the possible exceptions of handguns and tequila".
Offline Chazy Chaz
  • Jr. Mitglied
  • I'm new. Be nice! :P
  • Branch: Stable
  • Desktop: Cinnamon
  • GPU Card: AMD R9 290
  • GPU driver: Free
  • Kernel: Linux44-x64
« Reply #10 on: 05. January 2016, 17:07:55 »
I like this, smoothness  ;D
Thanks Manjaro team!
Offline philm
  • Core Team
    • Manjaro Linux
  • Branch: Unstable
  • Desktop: XFCE
  • Skill: Guru
« Reply #11 on: 05. January 2016, 17:11:30 »
The focus is more on PHP7, but not all of you use it ...
Offline viking60
  • Sr. Mitglied
    • bjoernvold.com
  • Branch: stable
  • Desktop: openbox
« Reply #12 on: 05. January 2016, 17:33:12 »
I use php but some time ago everything went "blank" as in non of my scripts show. It must be a config error somewhere but I can't find it so I guess I will have to delete the lamp server and start from scratch.
(I have it working on pure Arch boxes, Debian and Centos - but one small config error is like a needle in a haystack)
« Last Edit: 05. January 2016, 17:35:09 by viking60 »
Offline mark.opensource
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce
  • GPU Card: ATI
  • Kernel: x64 stable current
  • Skill: Novice
« Reply #13 on: 05. January 2016, 17:41:23 »
Owncloud server is no longer working after this update. Given that there are changes with PHP I would assume it caused the problem. After consulting https://wiki.archlinux.org/index.php/Apache_HTTP_Server#PHP all that is needed to get it working again is changing some of the values in /etc/httpd/conf/httpd.conf
Specifically:
To enable PHP, add these lines to /etc/httpd/conf/httpd.conf:
Place this in the LoadModule list anywhere after LoadModule dir_module modules/mod_dir.so:
Code: [Select]
LoadModule php7_module modules/libphp7.so
Place this at the end of the Include list:
Code: [Select]
Include conf/extra/php7_module.conf
Then Restart httpd.service using systemd
« Last Edit: 06. January 2016, 10:02:25 by philm »
Offline Foxwater
  • Neuling
  • I'm new. Be nice!
  • Branch: Stable
  • Desktop: Xfce, KDE
  • GPU Card: ATi 7950
  • GPU driver: Free
  • Kernel: 4.1-x64
  • Skill: Novice
« Reply #14 on: 05. January 2016, 18:20:43 »
Smooth update both KDE & Xfce.  Thank you
There is only one corner of the universe you can be certain of improving, and that's your own self.
Aldous Huxley
