Author Topic: [Testing] Manjaro Budgie 16.01 with budgie V10.2.2  (Read 16224 times)
Offline Ste74
  • Support Team
  • sudo pacman -Rs windows && sudo pacman -S manjaro
  • Branch: unstable
  • Desktop: Budgie / Gnome / Pantheon (testing)
  • GPU Card: ATI/Intel mobility radeon hd 5400
  • GPU driver: free
  • Kernel: linux4.x -x86_64 series
  • Skill: Advanced
Re: [Testing] Manjaro Budgie 16.01 with budgie V10.2.2
« Reply #15 on: 05. January 2016, 18:51:52 »
Hi in livecd ? It is set to automatic login..
Pantheon Community Edition & Budgie Desktop Edition
www.forum.manjaro-it.org
Canale IRC italiano
#manjaro-it
Offline diVinae
  • Neuling
  • Branch: testing
  • Desktop: Xfce
  • GPU Card: intel/nvidia(optimus)
  • GPU driver: non-free
  • Kernel: linux44-x64
  • Skill: Intermediate
« Reply #16 on: 05. January 2016, 19:03:15 »
It was problem with nofree drivers flag
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #17 on: 05. January 2016, 19:06:54 »
in this iso is present only free driver .. install with free driver and after use Manjaro setting manager gui to install .. This is a test iso so not all function is present .. If you check the livecd menu you not see the nonfree option to start  ;)
Canale IRC italiano
#manjaro-it
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • GPU Card: Intel HD4400M CPU: Core i7-4510U
  • GPU driver: Intel/Free
  • Kernel: 4.4-lts & 4.5
  • Skill: Novice
« Reply #18 on: 05. January 2016, 21:11:22 »
I cant login into x session
lightDM show "something goes wrong"
Is Budgie Desktop selected in the LightDM login screen?
“What, me worry?” ― Alfred E. Newman
Manjaro Wiki: https://wiki.manjaro.org/
Arch Wiki: https://wiki.archlinux.org/
Pacman Rosetta: https://wiki.archlinux.org/index.php/Pacman/Rosetta
Offline feskyde
  • Neuling
  • The life is hard, but more hard is this...
    • A webpage about me
  • Branch: Unstable
  • Desktop: Budgie
  • GPU Card: AMD Radeon Graphics
  • GPU driver: Free
« Reply #19 on: 06. January 2016, 02:31:28 »
Please do not use EvoPop themes (Icons and GTK) for Budgie, they're currently unmantained :)
Be kawaii, be code (Kodewaii developer).
Offline balloon
  • Neuling
  • Skill: Novice
« Reply #20 on: 06. January 2016, 09:03:16 »
I have tried it in Japanese.
When I have to proceed with the installation, I encountered such a state.
It may be necessary to adjust the theme and setting.
Offline eugen-b
  • Support Team
  • Branch: testing
  • Desktop: LXDE, Fluxbox, JWM, LXQt, bspwm
  • GPU Card: Intel 82945G/GZ
  • GPU driver: free
  • Kernel: 4.5, 4.6
« Reply #21 on: 06. January 2016, 09:43:22 »
What's actually the problem, it's just icons.
MSI Wind Nettop, Intel Atom 230 1.6GHz (64bit), 2GB RAM
DEs: NET-minimal + (LXDE / Fluxbox / JWM); LXQt OpenRC
how to install on btrfs subvolumes
http://manjaro.github.io/donate/
Offline ctkaizer
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #22 on: 06. January 2016, 10:44:30 »
looks sleek :D the only downside imo is the lack of scale/expo but they'll fix that soon enough. Great work. Thanks!
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #23 on: 06. January 2016, 13:48:41 »
Dunno if anyone else has this problem--and there is no way to Google it--all Budgie knowledge resides here or @ Solus...
The darn panel indicator icons in the upper RH corner tend to reset themselves back to an arrangement they like, rather than how I arrange them. Re-arranging works, but doesn't survive a logout/reboot. It's a minor, niggling thing, and I'm sure at some point Ikey will do something about it.
Does this behavior happen to other Budgie adopters?
In the meantime, it is an irritant and a stern glare does not seem to threaten them much...
Offline c00ter
  • Held Mitglied
  • Towelie's cupcake
  • Branch: ☮Olive☮
  • Desktop: Depends©
  • Skill: Novice
« Reply #24 on: 06. January 2016, 13:52:02 »
Yep, it's not half-bad for a brand new DE! I love Budgie. GNOME at half the calories. Ikey & Co.--and Stefano--have done a lot of good work here. :D
Offline klaatu
  • Neuling
  • I'm an alien. Be nice!
  • Skill: Novice
« Reply #25 on: 06. January 2016, 16:01:56 »
Last time I tried Budgie (a few month ago on Solus) the keyboard shortcuts didn't work at all, do they work now?
Thanks
Offline diVinae
  • Neuling
  • Branch: testing
  • Desktop: Xfce
« Reply #26 on: 06. January 2016, 16:56:51 »
So i have no wifi icon in panel.
I have one question - its normal to Budgie using 550+ RAM after system start with gnome-tracker disable ?
Offline jordan
  • Vollwertiges Mitglied
  • Skill: Advanced
« Reply #27 on: 06. January 2016, 18:40:20 »
Hi!
After having burned *.iso with "dd" and booted, I installed Calamares 1.9.2.0.r183 (+ 30 packages - autom.), prepared partition (ext4) with GParted.
Installation : root partition, home partition shared with "old Manjaro Budgie" - but other username, Grub into system partition without a problem from USB2 to SSD: 4 minutes.
Main Grub (Manjaro Cin. / MATE) detected and run Manjaro Budgie 16.01.
Updates: 16 packages / 53 MB.
Onlz (Only!) one problem detected: keyboard (chosen German): z and y inverted.
« Last Edit: 06. January 2016, 18:42:16 by jordan »
Jordan @ Linux multi boot
Offline ctkaizer
  • Neuling
  • I'm new. Be nice!
  • Skill: Novice
« Reply #28 on: 06. January 2016, 21:27:27 »
i installed budgie on manjaro 15.12 xfce 64bit
budgieDE takes about 270MB. Total used RAM 750. so i guess your 550mb is fine probably has some other manjaro stuff  running in the backround. you can try and go with the i3 respin as base and install budgie if you want low RAM usage or try Arch + budgie.
Offline Ste74
  • Support Team
  • Branch: unstable
  • GPU driver: free
  • Skill: Advanced
« Reply #29 on: 06. January 2016, 21:42:26 »
Hi not understand : this is my installation in vbox : Ram 270/280 mb ..
Canale IRC italiano
#manjaro-it
